May 9th, 2009, 07:19 PM | #201 |
Live Life
Join Date: Nov 2008 Motorcycle(s): 2009 Green SE Ninja 250 Posts: A lot.
I can't tell for sure, has anyone used the kit from DDM Tuning?
They have two models, both the same price. One is for "motorcycles" The other is an automotive but for H7's Thanks in advance.
- ATGATT - Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots |
May 11th, 2009, 10:23 AM | #202 |
Join Date: Apr 2009 Motorcycle(s): 2008 Green 250R and 06 636 maybe? Posts: 16
Which kit seems to be the best guys? I can't find the one from ebay, the link does not work anymore. Some seem to have quality issues, so I'm looking for a quality one. Please post up where I can purchase a setup.
Thanks, Chad |
May 11th, 2009, 10:41 AM | #204 |
Join Date: Mar 2009 Motorcycle(s): '08 blue 250R [sold]. '09 lime ZX-6R [stolen :( ]. '06 blue 636. Posts: 918
I'm using one from a brand called Xentec, with standard size ballasts. Got them on ebay. but you have to add washers to the bulb housing or whatever you call it (just like in the DIY instructions) and what not for a tight and perfect fit.
regular ballasts fit just fine Here's some pictures of my work: Regular ballasts and where I mounted Ghetto style washers and tube for fit.. all rubber After inserting back into headlight mount Crappy picture after finished Last futzed with by paterick4o8; May 12th, 2009 at 10:10 PM. Reason: clarity |
May 11th, 2009, 11:22 AM | #205 |
Join Date: Mar 2009 Motorcycle(s): 2008 kawaski ninja 250R, 2003 kawasaki ninja 636 zx-6r Posts: 10
i just did this mod and THEN i found a diy thread but i got slim ballasts and i ended mounting them in about the same places but i used some cloth as a spacer inbetween the light bulb and the metal bracket thing to hold them in place but i got 8000k and it is the brightest thing on the road took me about an hr to install b/c i already had the bike fully naked
May 25th, 2009, 05:49 PM | #206 |
HID's are installed flawlessly however I have a slight problem. When starting, the low beam flickers and will not start. I shut off and start again but this time holding the starter for a few seconds. When i apply this method, the light usually flickers then stays on.
Today, i no matter how long i held the starter down, the light would not stay on. So i rode around with the highbeam on instead. After riding for a 20min, i restarted the bike using the same procedures, and it worked. Do you think upgrading to 15a fuse will alleviate the startup issue? |
May 25th, 2009, 06:11 PM | #207 |
no. try swapping ballasts between the hi and low.... or even just swapping the bulbs.
I have the same problem on occasion of it not starting with the bike, but a restart always makes the light come on for me. you might have a loose connection in your low light setup, perhaps? |
May 25th, 2009, 06:11 PM | #208 |
Ramen Rider
Join Date: Jan 2009 Motorcycle(s): 2015 BMW R1200R, 08 Honda VFR800A (sold), 09 Ninja 250R (sold) Posts: A lot.
i doubt going to a higher fuse will be of any help.
the only thing i can think of is that your wiring may be loose, or your ballast is bad? i suppose you could try checking the connections or flip flopping the ballasts to see if the lows work and if your high beams have a problem after that. just a thought. |
May 25th, 2009, 06:13 PM | #209 |
Ramen Rider
lol. we pretty much said the same thing at almost exactly the same time.
May 25th, 2009, 06:15 PM | #210 |
I was just a bit quicker cause my bike is green.
May 27th, 2009, 07:39 PM | #211 |
Checked all connections, even swapped ballasts. It still has the occasional issue of flickering and not turning on at all. Is there anything else to consider?
May 27th, 2009, 07:46 PM | #212 |
Ramen Rider
did you try swapping bulbs like kkim suggested?
May 27th, 2009, 07:49 PM | #213 |
when you swapped ballasts, the problem did not follow the ballast? that is, the problem remained on the low light side... is that correct?
if the problem did not follow the ballast switch, swap the bulbs between the high and low lights while leaving everything else the same. |
May 27th, 2009, 07:50 PM | #214 |
Ramen Rider
process of elimination.
May 28th, 2009, 02:40 AM | #215 |
Join Date: May 2009 Motorcycle(s): 2009 ninja 250r Posts: 20
like paterick, i also got xentec off ebay ($50).... it was for use with motorcycles or autos..... came with a little adapter so that washers were not needed for installs on a motorcycle(had to dremel it a bit to fit)...... the adapter also made it so the factory rubber housing would fit snug around it, so no rubber housing mods were needed.....
huge difference, they sure are superbright.... over all a pretty easy install took me about an hr (minus bodywork disassembled).... was taking my time with the wiring (pretty lengthy wiring i must say).... recommended to everyone! for $50 you cant go wrong. |
May 28th, 2009, 07:12 AM | #216 |
When i installed the HID's, i just did the low beam. Haven't had a chance to test another bulb.
June 12th, 2009, 01:42 AM | #217 |
Join Date: Jun 2009 Motorcycle(s): none yet 250r in 2 weeks Posts: 5
I was wondering if you could tell me what to type in exactly on ebay so I get the right part. For one, I don't know what bulb type as I am picking up my 03 pre gen in less than 2 weeks and The ebay link is no longer valid. And this is a sweet diy. I'm good with mods but you just knocked out the guest work. Thanks for saving me some beer time in between steps
Posted via Mobile Device |
June 12th, 2009, 02:04 AM | #218 |
Sorry I missed the post someone answered h7's before as well as you stated but is there any specific company you prefer or wattage.
June 12th, 2009, 03:40 AM | #219 |
Join Date: Nov 2008 Motorcycle(s): Ninja 250R 2009 Posts: A lot.
If you do a search on ebay for "hid lights", you will see many listings. Here is one of several that resembles what I purchased (roughly same price with shipping!!):
http://tinyurl.com/mhbyno And I bought the 4300K in a 35W. Everything in the package looks just like mine. |
June 12th, 2009, 06:25 AM | #220 |
Join Date: Nov 2008 Motorcycle(s): 2008 WR250R, 2006 Ural Raven (Sold), 2009 Versys Green (Sold), 2008 Ninja 250R Green (Sold) Posts: A lot.
Why did you quote the entire DIY?
June 12th, 2009, 07:03 AM | #221 |
Join Date: Feb 2009 Motorcycle(s): 2009 Ninja 250R Posts: 81
i just put the DDM slim line kit in my 09
didnt need to do any crap with those plastic washers just like i thought i wouldnt i just used the spacer that came in the kit, cut one corner off and it fits perfectly havent rode at night yet but its like the freakin sun is comin from my bike when i pull it in the garage lol got 8k or 6k, cant remember i got it off my other forums (mazdas247) for 90 with the lifetime warranty still |
June 12th, 2009, 08:10 AM | #222 |
June 12th, 2009, 09:53 AM | #223 |
June 22nd, 2009, 01:27 PM | #224 |
Join Date: Jun 2009 Motorcycle(s): 08 Candy Plasma Blue Posts: 125
wait, isn't putting HID's in a reflective housing bad? [cuz it causes so much glare?]
June 22nd, 2009, 01:52 PM | #225 | |
Join Date: Apr 2009 Motorcycle(s): '04 sv650s Posts: 438
Retrofitting into H4 or 9007 (or any dual filament halogen system) is the worst since the light source location is extremely critical..and the aftermarket HID's are usually (in my experience) very low quality products since they aren't adhering to any sort of regulation or standards. Retrofitting OEM projectors and oem component is the way to go, without glare, and will deliver superior lighting over cheap plug and play bulbs (but it's still illegal).
There's 2 types of people in this world, those who complain and those who act. |
June 22nd, 2009, 03:22 PM | #226 | |
don't believe everything you read on the Internet... good or bad.... try it yourself, if curious. |
June 22nd, 2009, 03:30 PM | #227 |
from my experience,
1) they do indeed help me see better 2) they help others (especially cagers) see me better in day and night 3) they look cool! |
June 23rd, 2009, 06:18 AM | #228 |
true true, but just for the record, all those damn civics and accords w/ HID's in their reflector housings runnin around NYC blind the CRAP out of oncoming drivers.
Last futzed with by shift_6; June 23rd, 2009 at 07:40 AM. |
June 23rd, 2009, 03:49 PM | #229 |
most times it's due to mis aimed headlights, plus the fact that they are idiots.
To be honest though, if they have a dual filament type of bulb setup (which a lot of those Hondas do), the aftermarket HIDs do not make the transition as well, so I would tend to agree with you as the reflector assembly/bulb center focus themselves are poor candidates for a HID kit. |
June 27th, 2009, 08:11 PM | #230 |
Got mine installed today Will post pics and impressions tomorrow - it's getting too late now, and I need to go find some cornbread to eat Also installing auxiliary turn signals on the back of my mirrors, relocating the rear turn signals, and putting on extra lights in the rear.... more details to follow
June 27th, 2009, 08:13 PM | #231 |
remember to repoint them, if they are not adjusted correctly.... the headlights, I mean.
June 27th, 2009, 11:15 PM | #232 |
June 30th, 2009, 09:30 PM | #233 |
Join Date: Jun 2009 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 29
I did my hid install today with full fairing removal and lowering in 1 hr. I have installed hids in many cars so it wasn't anything new.
Just one problem I am having which doesn't seem to relate but my left turn signal is not blinking but on constant and almost like a bulb blow out but not, I checked. I was a clumsy idiot after getting everything back together and went to take the bike off the rear stand and poof the bike falls over to the right. No major damage and found out about the signal thing when I started to ride. Any help would be great. Regards Chan |
June 30th, 2009, 10:09 PM | #234 |
Feeling really stupid at the moment. Found out the problem. I forgot to plug the left side back in after taking the fairing off.
June 30th, 2009, 10:16 PM | #235 |
June 30th, 2009, 10:20 PM | #236 |
Simplest things are always the culprits. They are aimed perfectly now since its dark..
June 30th, 2009, 10:27 PM | #237 |
July 1st, 2009, 11:10 AM | #238 |
Around this time a year the sun goes down are 9 and fully sets around 9:30ish. Yeah its nice to have sun longer. Winter time its like 5 sucks...
I aimed my lights and rode and they seem to high and when i check behind a car the cutoff is about an inch below the trunk line. I tried to adjust more turning the adjustment screw counterclockwise and it's tight and won't want to move. Help!! |
July 1st, 2009, 11:26 AM | #239 |
That should be good, as far as aiming.
July 2nd, 2009, 12:32 AM | #240 |
The beam seems too high when i ride and lights up trees and what not but not the road. Only glare beaming off the lights reflecting on to the road. I would like to try to adjust lower to the road.
Did I mention i am lowered in front and rear. Could this be the problem? That my rear is lower than the front hence light pointing up too much? I will take a pic. Kinda annoying that the lights are lighting up half a house up top and not below. Chan |
HID headlight conversion. | agentbad | General Motorcycling Discussion | 6 | May 21st, 2014 07:13 PM |
[webbikeworld.com] - Bikemaster HID Headlight Conversion Kit Review | Ninjette Newsbot | Motorcycling News | 0 | September 16th, 2012 09:10 AM |
HID conversion | b_eastep | 1986 - 2007 Ninja 250R Farkles | 84 | August 4th, 2010 10:10 AM |
Proper HID conversion? | jonthechron | 2008 - 2012 Ninja 250R Tech Talk | 23 | February 9th, 2010 02:09 PM |
