July 2nd, 2009, 12:37 AM | #241 |
you adjusting the correct things? blue adjusts vertical, yellow adjusts horizontal.
The next picture shows the back of the nose piece, which details the headlight lamp housing, after the low beam (left side) bulb was replaced and the rubber housing was modified. The blue and yellow arrows detail the adjusting screws for the light beams. |
July 2nd, 2009, 07:34 AM | #242 |
ok, so I'm pretty much finished with the electrical things I was doing - as we need to wait on another garage door opener after the hubby fried the last one when soldering it... before I get everything buttoned back up ... if the cut offs are in the same location on the garage door, they should be pretty well aimed, correct?
July 2nd, 2009, 09:48 AM | #243 |
Join Date: Jun 2009 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 29
Turning the blue arrow (vertical) counterclockwise and won't go anymore. Very tight.
July 2nd, 2009, 11:06 AM | #244 | |
Kim- that's how I aim mine... on the garage wall marked with a piece of blue masking tape as a reference. You might need to fine tune once you get the bike on the road. |
July 9th, 2009, 01:33 PM | #245 |
Join Date: Jun 2009 Motorcycle(s): Ninja Ex250 09' Posts: 15
I installed my 10000k HID lights on my bike and noticed the headlights get extremely hot, along with the ballasts, is this normal?
July 9th, 2009, 01:41 PM | #246 |
Join Date: Apr 2009 Motorcycle(s): '04 sv650s Posts: 438
HID's burns cooler than halogen..you probably just never noticed how hot stock bulbs were before!
There's 2 types of people in this world, those who complain and those who act. |
July 9th, 2009, 01:52 PM | #247 |
I guess that might be true, but still makes me kinda nervous. I let my bulbs burn for 10 minutes, when I touched the headlight "glass", I had to remove my hand immediately, that's normal?
July 11th, 2009, 11:36 PM | #248 |
Join Date: Jun 2009 Motorcycle(s): 2007 Suzuki GSX-R750 Posts: 378
DAMN, now I need 2 buy HID lights...will I ever stop spending $ on this little bike???????????
July 19th, 2009, 01:18 AM | #249 |
sir posts a lot
Join Date: Jul 2009 Motorcycle(s): '09 Black 250R Posts: 267
Thank God Gary already did this!!!!
A girl walks into a bar and orders a "double entendre" So the bartender gave it to her "once you go black, you never go back." |
July 19th, 2009, 01:26 AM | #250 |
Ramen Rider
Join Date: Jan 2009 Motorcycle(s): 2015 BMW R1200R, 08 Honda VFR800A (sold), 09 Ninja 250R (sold) Posts: A lot.
July 19th, 2009, 10:00 AM | #251 |
Join Date: Dec 2008 Motorcycle(s): 09 250r (*sold*), 2010 Daytona 675 Posts: 301
Hey guys I need your opinion. I'm installing HIDs on my Daytona. I have this nifty gadget installed that turns on both my headlights (both low/high beam) so that both are on at the same time, it just dims the high beam so appear as dim as the low beam. Anyways, I'm wanting to do the HID conversion, but you can't *dim* an HID bulb. So I'm having to put a Halogen bulb in place of the high beam bulb, and put the HID bulb in just the low beam.
I hope all the made sense. So what I'm asking is, is a 55W 4000k Halogen bulb going to match the 35W 6000k HID bulb in color? I wanted to stay away from the blue hue as much as possible. |
July 19th, 2009, 10:35 AM | #252 |
it should. 4000K is the color temp which gives the bulb the characteristic hue. The higher the temp, the bluer the color.
may I suggest a 100w bulb for the highlight if you need a bit more light at night. |
July 19th, 2009, 10:48 AM | #253 |
you want to get a 4300 K HID. The 6000 K will be more blue than your halogen .
July 19th, 2009, 10:52 AM | #254 |
I stand corrected... noche is correct. it won't match. why would you want a 6000K HID?
July 19th, 2009, 11:26 AM | #255 |
Thanks Noche. I was told that the 6000k would match the 4000k just fine, but I didn't feel comfortable with that answer so thats why I asked y'all.
July 19th, 2009, 02:16 PM | #256 |
4300k, 6000k, and 8000k are supposed to be "standarized color"...6000k should always be 6000k no matter what wattage you get.
July 20th, 2009, 09:45 AM | #257 |
Since your trying to match HID to wannabe HID halogen bulbs (only a blue coating over the bulb), just get 6k halogen brand like nokya's. I done this on my IS350F 6k hid headlight and 6k halogen fog bulbs and they match pretty well.
July 20th, 2009, 09:54 AM | #258 | |
(e-mailed ddmtuning and asked for their advice as well, still waiting for a response) I am crash coursing all this electrical stuff too. That's why I was confused all the hue differences and the bulbs. I'm still trying to learn all this crap. I'm just a wrench monkey after all.. |
July 20th, 2009, 09:55 AM | #259 |
sir posts a lot
Wait off topic do you have an is350 or isf??? Or do live somewhere there is an is350f?? Also yea my wife has been pestering me nonstop to put in matching bulbs coz stock lights/fog lights are ugly as sin
Posted via Mobile Device |
July 20th, 2009, 11:38 PM | #260 |
It is a 350 with all "F" parts besides engine. Turbo'ing it soon so it will be faster than a stock factory ISF. Just waiting on paying off CC from Evo build. I agree with your wife, change those uggs out stat.
July 21st, 2009, 09:49 AM | #261 |
Thanks for the write-up! It definitely made things go smoothly, and I can now see clearly at night.
Only thing that held me up was that I didn't know how to take off the bottom part of the clear plastic case around the bulbs (first time installing HID on any vehicle). After about an hour of trying to "gently" remove them I just cut them with a large pair of shears. |
July 23rd, 2009, 07:09 PM | #262 |
Low beam is 35W 6000k HID, High beam is 100w 7000k Noyka Artic White Halogen.
What do you guys think of the setup? Thanks for all the input so far! |
July 23rd, 2009, 08:07 PM | #263 |
sir posts a lot
Soo I bought Garys bike and since have had 2 fuses pop. Now Gary said he never needed the new fuse, and I really have no clue what I have done, other than drain the battery, soo what should I do??? I was thinking about going and buying the biiger fuse, but negative sideeffects could/will this have??? thanks
July 23rd, 2009, 08:34 PM | #264 |
what size are the fuses that are popping? I assume it's the low and high light fuses?
July 23rd, 2009, 08:44 PM | #265 |
sir posts a lot
I thought there was just 1 fuse for the headlights it is 10 amps
July 23rd, 2009, 08:48 PM | #266 | |
have you done/added anything else to the bike since buying it? when you jumped the bike, you did have the car turned off, correct? |
July 23rd, 2009, 08:55 PM | #267 |
sir posts a lot
Yes the car was off and there hasnot been any other probe other than the headlights
July 23rd, 2009, 08:57 PM | #268 |
do the headlights work fine right up to the time the fuse pops?
July 23rd, 2009, 09:00 PM | #269 |
sir posts a lot
Yes they worked fine when I pUt the fuse in lastnight but doesn't work today
July 23rd, 2009, 09:21 PM | #270 |
you can try putting one size larger fuse than the 10A... which is a 12.5A or 15A.
some HID kits give you a 20A with their kits. you want the smallest one in there that won't pop. are you using both the hi and low lights and the fuse pops or does it pop even just using the low light? |
July 23rd, 2009, 09:28 PM | #271 |
sir posts a lot
Yea I will try a 15 today.. Is it possible I damaged the Ballest with the jump??? Also I had to ride in the rain the other day ( had to ride back I should say). Uuugggg if I have to replace that stuff I'm gunna be mad
July 23rd, 2009, 09:33 PM | #272 |
do you start the bike w/ both the hi and low lights on? any particular time you notice that the fuse blows?
if you have damaged the ballasts, you can go back to the stock bulbs and the lights should still work fine. Did you get the original bulbs with the bike sale? If not, perhaps Gary still has them. My thought is that if the ballasts are damaged, it's due to the lower and lower voltages they received as the battery drained down. Those ballasts don't like that. |
July 23rd, 2009, 09:40 PM | #273 |
Ramen Rider
yeah, i gave him the original bulbs as well. if you do end up taking off the HIDs, i had to cut the rubber boots a bit as shown in this diy. not sure how water tight they will be with the stock bulbs. may have to buy stock replacement boots. maybe not. idk.
try the higher amp fuse first. if those still blow, try the stock bulbs like kelly said. if the stock ones work fine and you want to keep the HID, then yeah, i would imagine you may have to replace the ballasts. |
July 23rd, 2009, 09:46 PM | #274 |
Ramen Rider
here are the replacement ballasts for the kit i have. they run $63.75 each. you would need two. http://f-sane.com/store/index.php?ma...products_id=26
which actually is kind of dumb because the whole HID kit costs $145 which would also include the two bulbs. anyways, hopefully it isn't the ballasts that were damaged. |
July 23rd, 2009, 09:49 PM | #275 |
lol... you can get entire HID kits (2 bulbs and ballasts) for less than the cost of that one ballast now days.
July 23rd, 2009, 10:34 PM | #276 |
Join Date: Apr 2009 Motorcycle(s): 2009 Black Ninja 250R, 2004 Yellow Ninja 250R Posts: 111
it will blow the fuse if you try to start the bike with the high beam ON. done it twice so i make sure the high beam is OFF before even turning the ignition key. let the low beam warm up a little until current draw is stable. for me, i just wait 5 minutes before turning the high beam ON after start up
it has something to do with initial current draw with HIDs. if you notice, whenever you flip the high beam ON, the hi - HID will flash bright for less than a fraction of a second but eventually dims. by then, it will warm up to its full brightness. that sudden rush of current will blow your 10A fuse during start up with both HIDs in ON position |
July 23rd, 2009, 10:42 PM | #277 |
sir posts a lot
ok soo I got a 15 amp fuse in her and turn on the lights and voahla.....they worked. I then flicked the brights repeatedly a bunch, then (as I told my wife ) I HAD to ride her around to make sure they didnt go out. I went for a short 15 min ride across base with the brights on (just trying to see the threshhold) and they still work like a charm. I even turned the bike on and off 5x in a row (prob not good for the starter). My guess is the fact that no two HID light kits are made the same, sooo it is quite possible that my kit uses a bit more power than say another kit uses??? mabye?? Well I will def keep everyone updated...but for now it seems that the "bandaid on the bullethole" is working.
July 23rd, 2009, 10:48 PM | #278 |
Ramen Rider
that is good to hear michael. i still don't know why i ran fine with the 10 amps all this time and you blew it twice within a week of having it. lol. oh well, i guess it doesn't matter. ride safe.
July 23rd, 2009, 11:39 PM | #279 |
answer the question... do you start the bike w/ both the high and low lights on at the same time?
July 25th, 2009, 01:55 AM | #280 |
sir posts a lot
I don't think so but now I run a mental checklist and manually put my thumb on the low beam portion of the switch before starting and I don't mess with high beams
HID headlight conversion. | agentbad | General Motorcycling Discussion | 6 | May 21st, 2014 07:13 PM |
[webbikeworld.com] - Bikemaster HID Headlight Conversion Kit Review | Ninjette Newsbot | Motorcycling News | 0 | September 16th, 2012 09:10 AM |
HID conversion | b_eastep | 1986 - 2007 Ninja 250R Farkles | 84 | August 4th, 2010 10:10 AM |
Proper HID conversion? | jonthechron | 2008 - 2012 Ninja 250R Tech Talk | 23 | February 9th, 2010 02:09 PM |
