October 31st, 2010, 04:04 PM | #1 |
Join Date: Sep 2010 Motorcycle(s): 2009 Kawasaki Ninja 250r Posts: 12
HELP!!! New ninja wont stay running; suggestions?
I just bought an '09 Ninja with 1K miles for $2600. No problems but one big one:
Shortly after starting, the engine dies.. OR if it does manage to idle, it dies as soon as the throttle is touched. I've been trying carb cleaner and gum-out to no avail. The bike has barely been ridden, and I was told the bad gas (from sitting in garage for almost a year) was drained and replaced. Any suggestions will be greatly appreciated, I just wanna ride soo bad and I'm so depressed she's not running. Thanks! Camron |
October 31st, 2010, 04:44 PM | #2 |
Has there been any mods done to it? I would check the gas lines to make sure they're not kinked. What about choke? The ninja's are very cold blooded so this time of year, choke is necessary on almost every start. I'm also assuming you've got a charged battery in there. Good luck. I'm sure the more experienced riders here can be of more help.
October 31st, 2010, 05:26 PM | #3 |
I hate driving...
Join Date: Jul 2010 Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12) Posts: A lot.
Also try messing with the idle mine had that problem when I first bought it and it was because the bikes idle was a bit too low but you can't tell that when you are starting it up. Try upping it a bit and if it stays on ride around a bit then get the idle to spec although I have mine idle at 1500
09 ninja 2fiddy SE Driving slow things fast |
October 31st, 2010, 05:42 PM | #4 |
Cycle Start
Join Date: Jun 2009 Motorcycle(s): 2009 Ninja 250r - 2010 Ninja ZX-6R Posts: 32
+1
Did the previous owner mess with it any? Put a fuel filter on or anything? You playing around with full choke, half choke, or leaving it off? Each bike is a little different.
2009 Ninja 250R Red - Area P Full System 12" Carbon - Ceramic coated cap - K&N R0990 Filter - Dynojet needles 106 jets - BikeMonkey Integrated LED Tail Light - Fender Eliminator - Proton Flushmounts |
October 31st, 2010, 06:12 PM | #5 |
Thanks for the replies and suggestions
There are no mods on the bike, just new spark plugs and possibly a new OEM air filter The fuel lines are not kinked, I thought they may be gummed so I used gum-out. I use the choke on start-up and have even tried messing with it. I've messed with the idle adjustment but an idle problem should be compenstable by using a little bit of throttle on start-up. It's feeling like a fuel delivery problem; like its not getting enough fuel after it fires up. Keep the suggestions coming, please. Thanks! Camron |
October 31st, 2010, 06:30 PM | #6 |
When you said it dies when you give it throttle, did you give it enough time to warm up and with full choke on? I know that if it's not fully warmed up, throttle will kill it very very quickly. It could also help if you shimmed the carb needles. Mine needed the shimming otherwise it would die the second I gave it throttle.
Hopefully somebody else can come up with other ideas. |
October 31st, 2010, 06:46 PM | #7 |
I haven't done any work to the bike so far, and I've never tuned a carb, but I've got a shop manual so I'll tear it down tomorrow and basically make sure its all clean and working properly (I.e float, needle and jet adjustments).
Otherwise, I gotta give up and take it to a shop Camron |
October 31st, 2010, 08:47 PM | #8 |
when you clean the carbs, be sure to remove the main and pilot jets and blow them clean with compressed air and the passages they screw into. make sure you can see through the jets clearly.
November 2nd, 2010, 06:55 PM | #9 |
Success!! before and after below..
I finally fixed it today!!
It took me six hours total.. I pried the tank, seat and farings off, removed the battery, slid the airbox back, and removed the carbs. When I opened them up, I found out what 8 months in a shed does to a bike, EVERYTHING was clogged with gunk that my Gum-Out© had no hope of clearing. I disassembled and cleaned everything in a mineral bath with brass brushes, welding tip cleaners (for the jets) and pipe cleaners. When I put it all back together, it fired up first try and sounded beautiful. The local Velocity Powersports quoted me $450 for carb cleaning and tuning. I spent $30 bucks total for using my local garage's bike lift. I'm so happy I had the balls to DIY on my first carb job. Thanks for all the help and suggestion guys! Before and after pics are posted. Camron |
November 2nd, 2010, 07:19 PM | #10 | |
November 2nd, 2010, 07:23 PM | #11 |
self wrencher
now you're a carb cleaning expert
man while you have all that craps open might shim the needles, remove snorkel/airbox etc if you want to... |
November 3rd, 2010, 09:46 AM | #12 |
I was going to say the same thing. Needle shimming at that time would have been most convenient. Congratz. Now if you find that warm up takes too long or it doesnt pull very well at the beginning, you might give the shimming and snorkel thing a try. Fix that in a jiffy. Enjoy.
November 3rd, 2010, 10:29 AM | #13 |
Can you explain the shimming and snorkel thing for me? What does it do and how is it accomplished?
Thanks, Camron
Black '09 ninja 250r |
November 3rd, 2010, 10:50 AM | #14 |
November 3rd, 2010, 11:21 AM | #15 |
Money is a drug.
Join Date: Jun 2010 Motorcycle(s): 2011 ZX-6r, 2010 250r (RIP) Posts: 251
shimming and snorkel removal is amazing (and easy). I highly recommend it. glad to see you bit the bullet and got intimate with your bike!!!
November 4th, 2010, 05:36 AM | #16 |
IC2(SW)
Noticed in your first pic the mixture screw cover still there, hope you removed them.
Glad to hear you got her running |
November 4th, 2010, 12:53 PM | #17 |
Mixture screw cover? Where's that?
November 4th, 2010, 12:59 PM | #18 |
Ninjette CPT
Join Date: May 2009 Motorcycle(s): Black 08 250r Posts: A lot.
welcome to the forum, glad your got it running - ENJOY!
+1 for shimming and snorkel removal |
November 4th, 2010, 01:03 PM | #19 |
IC2(SW)
Guess thats a no. Theres one on each carb, bottom of your picture.
November 4th, 2010, 01:11 PM | #20 |
good eye, Kerry.
Ninja wont stay in 1st when engine off | archaeofreak | 1986 - 2007 Ninja 250R Tech Talk | 6 | December 20th, 2014 04:30 PM |
2010 ninja 250 wont stay on! | daveduno | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 27th, 2014 07:55 PM |
2007 Ninja 250 wont start...any suggestions? | tkessler | 1986 - 2007 Ninja 250R Tech Talk | 11 | February 26th, 2014 10:36 AM |
09 Ninja 250r wont stay idle without choke | TqAmsNy | 2008 - 2012 Ninja 250R Tech Talk | 11 | March 20th, 2013 01:38 PM |
Idle jumps to 9000 rpm on choke then wont stay idle after off | Shawn250 | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 19th, 2012 06:45 AM |
