Old June 30th, 2014, 06:47 PM   #1
reroka
Biker Noob
reroka's Avatar
Motorcycle(s): 2004 Honda Shadow 750 Aero
tire alignment
How can you tell if the wheels are aligned with each other? Would the bike wobble?
Riding as I stole it.
reroka is offline   Reply With Quote
Old June 30th, 2014, 06:48 PM   #2
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
why would they be out of alignment? you can straighten the rear by looking at the alignment markings on the swing arm.
TEAM ALFALFA
www.apexassassins.com
Old June 30th, 2014, 06:51 PM   #3
reroka
Biker Noob
reroka's Avatar
Because I adjusted the chain tonight. So is the marks are on the same line the wheels are aligned.
Old June 30th, 2014, 06:52 PM   #4
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
you need to make sure each side is on the same mark.
TEAM ALFALFA
Old June 30th, 2014, 06:54 PM   #5
reroka
Biker Noob
reroka's Avatar
Ok. That answered my question. I did it correctly then. Thanks.
Old June 30th, 2014, 07:08 PM   #6
Linkin
Down Under
Linkin's Avatar
Motorcycle(s): Kawasaki ZXR250C Ninja
If the rear wheel is not aligned you will get vibration, varying from left to right, at low speed.
You will also get uneven noise from the chain.
Also remember the chain should be adjusted from the tightest point, the wheel should spin freely once adjusted
Linkin is offline   Reply With Quote
Old June 30th, 2014, 07:47 PM   #7
Not with much accuracy. The marks on the ninjette are iffy and variable (just loosen the axle and you can see how they can each be moved forward and back several mm without the axle actually moving). More info in the main DIY thread covering this:
https://www.ninjette.org/forums/showthread.php?t=13833
Old July 2nd, 2014, 05:02 PM   #8
That's right, Alex.
That's why I always use my fingernail and count the threads exposed on the adjuster.
Alignment off? APEmike 2013 - 2017 Ninja 300 Tech Talk 1 October 14th, 2014 07:32 PM
Fork alignment headshrink 2008 - 2012 Ninja 250R Tech Talk 2 September 16th, 2014 08:31 PM
Rear Tire Alignment Q indr 2008 - 2012 Ninja 250R Tech Talk 11 December 17th, 2010 09:10 AM
Headlight alignment kobachi 2008 - 2012 Ninja 250R Tech Talk 2 July 29th, 2010 11:19 AM
Blew my tire..alignment is messed up now? hybridxx Off-Topic 10 April 27th, 2010 07:03 AM
