Old March 26th, 2019, 08:11 PM   #1
alexhart
Motorcycle(s): 2007 Ninja 250R
250 Sputters and lags on acceleration at speed?
So I have come across a problem and as a newbie I still don't even know where to begin.
The bike seems to lag or stutter when I go full throttle when I'm cruising. I'll be going along in 2nd gear or 3rd then gun the gas and it like skips a beat until I shift gears again.
This may be relevant but the idling is wonky, it sits really high and when I turn the idle screw a little down it will bog out the engine and maybe die or sit until revved again.
Could it be carb? The gent I just bought it from said that it had been sitting for a minute as he didn't ride it.
Any thoughts on what it might be? Any help would be much appreciated! I've never cleaned a carb before so if there's an easy way to check if it's that before taking the whole thing apart, any tips would be awesome.
alexhart is offline   Reply With Quote
Old March 27th, 2019, 08:00 AM   #2
ducatiman
ducatiman's Avatar
Could it be carb?
huh?
yes, very likely
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old March 27th, 2019, 05:21 PM   #3
Yes, you need to examine carbs closely. Symptoms indicate insufficient fuel delivery, most likely due to clogged carb fuel-circuits. As a test, you can try limiting air-flow to countre-act lack of petrol when going full-throttle. Read this thread and the linked ones within.
https://www.ninjette.org/forums/showthread.php?t=331186
Old March 28th, 2019, 07:10 AM   #4
alexhart
I so took apart the carbs and everything and they were already SPOTLESS! So now I am stumped. I am going to get more carb cleaner today to try and blow out the individual jet holes to see if he just did a poor job cleaning them. I have new spark plugs on the way as well so we will see.
Any other suggestions if it wouldn't be the carb?
Old March 28th, 2019, 07:38 AM   #5
Cafe Racer
Motorcycle(s): Harley Fatboy, Honda CX500, Harley XL1200C Sportster, 305 Honda Dream, Ninja 250
The passage ways in a carburetor are extremely small. Just looking is not a way to ensure your carbs are clean. Even an ultrasonic bath will not always get the crud out. Fine wires, carb cleaner and air will after a good ultrasonic bath. I also use q-tips.
Cafe Racer is offline   Reply With Quote
Old March 28th, 2019, 07:44 AM   #6
ducatiman
ducatiman's Avatar
fuel delivery issue?
*tank vent?
*petcock?
*air restriction (filter, intake snorkel?)
you never clarified the "sitting for a minute" statement.
Visually "spotless" is positive, but does not necessarily indicate clarity of circuits, fully justifying your confirming.
Just who cleaned these carburetors...the previous owner?
Did the bike ever run correctly during your ownership?
Custom Carb Service
Old March 28th, 2019, 05:15 PM   #7
Modern carb cleaners are worthless. You need complete disassembly, mechanical flossing of all jets and fuel-circuits with wire, hours in ultrasonic cleaner along with soda-blasting @ 100000psi.
[motogp.com] - Honda: progress with acceleration and top speed Ninjette Newsbot Motorcycling News 0 March 3rd, 2018 09:10 AM
Sputters When Warmed Up Scattcatt 2008 - 2012 Ninja 250R Tech Talk 17 November 10th, 2017 01:29 PM
HELP! Bike coughs sputters almost shut off but then ran cadymae 2008 - 2012 Ninja 250R Tech Talk 16 August 20th, 2015 09:40 AM
bikes throttle sputters at WOT ninjamatt03 1986 - 2007 Ninja 250R Tech Talk 11 September 16th, 2014 07:37 PM
Tips for fast acceleration from a stop on ninja 250? fr1dayn1ght General Motorcycling Discussion 25 June 23rd, 2013 07:53 PM
