Old April 3rd, 2019, 03:41 AM   #1
PR2Jay
Motorcycle(s): 250 gpx
250 gpx starts but then stalls
Been having this issue for a few weeks, my bike will turn on and be rideable for about a minute but then the revs start dropping lower and lower until the bike fully turns off, and then it gets harder and harder to start, have a new battery, any ideas?
PR2Jay is offline   Reply With Quote
Old April 3rd, 2019, 04:32 PM   #2
One possibility of many is that your tank vent is blocked. Another is that the little filter screen inside the fuel hose where it enters the carb is blocked. Another is that your petcock isn't flowing properly. I'd bet it's some sort of fuel restriction.
Welcome to the board Jaiden!
Old April 3rd, 2019, 09:13 PM   #3
PR2Jay
I was thinking it may be a fuel restriction aswell but I have next to no clue where any of the parts are on the bike. Would it be a hose coming from the fuel tank?
Old April 4th, 2019, 07:39 AM   #4
The tank vent is in the cap, and is pretty complicated, so work on a table with a towel on the surface it you take it apart. If that's the problem, when is tries to stall and your open the cap, it will run properly again. Use appropriate caution if you open the cap while riding.
The little screen in the fuel line is in the line from the petcock to the left carb, right where it goes over the barb at the carb. If it's clogged it could cause your symptoms.
The petcock is the thing with the ON-OFF valve on the bottom left of the tank. It's operated by vacuum that is created when the engine is running or cranked by the starter. If something is wrong and it's not opening fully, it could cause your symptoms.
The easiest one to check is the filter screen in the fuel line, so it would probably be wise to start there.
Spark problems normally show up as on or off, not "the revs start dropping lower and lower until the bike fully turns off".
Old April 5th, 2019, 02:36 AM   #5
PR2Jay
I checked the filter screen and that was all good in both the normal hose and the reserve, I’m now running into a new issue though, bike started making a clicking noise ose when I tried turning it on like it did with my old battery, then it made a more annoying buzzing noise and now it makes no noise at all
Old April 5th, 2019, 06:34 AM   #6
As I posted, the filter screen in question is in the rubber fuel line, right where it attaches to the left carb. The screens in the tank are also important, but generally don't clog by themselves.
Your battery is discharged. If you recently replaced it, you probably have something wrong with the charging system.
Have you seen this page? https://faq.ninja250.org/wiki/Ninja250_Howto
Old April 5th, 2019, 06:37 AM   #7
PR2Jay
I jump started my bike a few months ago with a car that was turned on while my battery wasn’t working, just read a post that said my starter could be bad now, I’m pretty sure I broke my starter lmao. Any clue where I would find it?
Old April 5th, 2019, 06:59 AM   #8
Jump starting the motorcycle from a running car won't hurt the bike's starter motor, but it can blow the voltage regulator. That would prevent the battery from being charged. Regulators are cheaper and easier to replace than starter motors.
You didn't answer my question about the web page I posted the link to.
Old April 5th, 2019, 07:01 AM   #9
PR2Jay
Is the regulator on the side of the bike near the battery? I think I replaced it with the one on my other gpx but the battery still died after running it for a while
02ninja 250 stalls when coming to a stop or when reving in neutral Catchandrun 1986 - 2007 Ninja 250R Tech Talk 17 May 2nd, 2016 12:42 PM
Ninja 250 stalls when giving throttle ji0315tafeng 2008 - 2012 Ninja 250R Tech Talk 4 August 24th, 2015 10:43 AM
Gpx 250 clutch issue (i think) bowerbird100 1986 - 2007 Ninja 250R Tech Talk 3 June 22nd, 2014 03:14 PM
2011 Ninja 250 stalls when given too much gas GregoryC4 2008 - 2012 Ninja 250R Tech Talk 15 April 1st, 2014 09:45 AM
