Old March 28th, 2009, 04:57 PM   #1
motorcycle_munge
motorcycle_munge's Avatar
Motorcycle(s): Ninja 250R
squeaking front tire
Any one else out there having problems with a squeaking front tire? I have a 09 250R with only 500 miles on it. My tire just started squeaking about 50 miles ago. When I took it in for the oil change I had them take a look at it and they either didn't ride it long enough to hear it squeak or they didn't find a problem. They are going to take another look at it next week when I get the frame sliders installed. Also, I've ordered a new pink helmet to go with my pink riding jacket. It should be here next week too.
motorcycle_munge is offline   Reply With Quote
Old March 28th, 2009, 05:00 PM   #2
http://www.ninjette.org/forums/showthread.php?t=11686
Old March 28th, 2009, 05:00 PM   #3
Hi Amanda -
Check out this thread, which has some other links within it as well. Likely culprits are either the speedo gear down on the left side of your front wheel (just squirt some WD-40 on it), or less likely, your axle may be overtightened and it could have affected the wheel bearings. Good luck!
- Alex
Old March 28th, 2009, 05:01 PM   #4
sm0kediver
one disaster at a time
sm0kediver's Avatar
Motorcycle(s): EX250J9
WD40 fixed that problem on mine. Just squirt a little in on the side where the speedo connects. No more embarassing squeak.
sm0kediver is offline   Reply With Quote
Old March 28th, 2009, 05:02 PM   #5
you need to tune your bot up, Alex... too slow. Oh wait, that wasn't a bot, that was you... sorry, couldn't tell the difference.
Old March 28th, 2009, 05:07 PM   #6
I could speed the bot up, or I could just forward-date your posts a few hours retroactively. Seems either option would work fine!
I will add this up in the "Common Tech Topics" thread in the tech section; it's not there yet...
Old March 28th, 2009, 05:08 PM   #7
sm0kediver
sm0kediver's Avatar
Seems pretty common on the new ones at 400 - 500 miles.
Old November 19th, 2009, 08:25 PM   #8
villamia
KawiNewbie
villamia's Avatar
I tried the WD-40 as suggested and it worked. Squeaking has stopped....for now.
villamia is offline   Reply With Quote
Old November 20th, 2009, 09:19 AM   #9
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
for a brief period around 1000 miles i had the problem. squirt of wd40 was good for 100 or so miles, then at a 2000 or so i never heard it again. quiet at 9500 miles.
Old November 20th, 2009, 09:54 AM   #10
rockNroll
rockNroll's Avatar
Motorcycle(s): black
WD 40 didn't affect mine, nor did taking everything apart, cleaning and then lubing everything. I just cuss at it now when it starts.
Old November 20th, 2009, 11:12 AM   #11
Maybe it will just wear in, kind of like mine did. Someone suggested removing the cable and using a graphite type lube on it, but I think it really comes from inside that speedo drive on the wheel more than the cable.
Old March 17th, 2010, 06:14 PM   #12
kobachi
kobachi's Avatar
Motorcycle(s): Blue 2008 Ninja 250R
Could you (or someone else) take a picture of this and indicate where the WD-40 should go?
kobachi is offline   Reply With Quote
Old March 17th, 2010, 06:30 PM   #13
ojameyo
MMMJami
ojameyo's Avatar
I got this same problem!! It is very annoying
ojameyo is offline   Reply With Quote
Old March 18th, 2010, 04:39 AM   #14
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
the noise is coming from the speedo drive. The seal gets folded under when they put the front wheel on .Just remove the speedo drive and put some grease in the seal then reinstall without folding the seal under .
Old March 18th, 2010, 06:13 AM   #15
Mine went away on its own for a few thousand miles and now its back at 10,600. Guess I'll pull the wheel grease the axle, pull the speedo cable and put some grease.
Quick fix for the "chirping" or "squeaking" front wheel 80MPHdownhill 2008 - 2012 Ninja 250R Tech Talk 2 November 18th, 2012 09:25 PM
Front brake squeaking? lostdaemon 2008 - 2012 Ninja 250R Tech Talk 6 July 3rd, 2012 08:34 AM
Front Wheel Squeaking? Jiggles 2008 - 2012 Ninja 250R Tech Talk 8 June 30th, 2011 04:20 PM
Help - squeaking noise coming from front wheel / fork? muffinman 2008 - 2012 Ninja 250R Tech Talk 5 March 17th, 2009 05:11 PM
Squeaking coming from the front. minizoom 2008 - 2012 Ninja 250R Tech Talk 10 January 12th, 2009 07:53 AM
