March 25th, 2014, 08:10 AM | #1 |
[visordown.com] - Yamaha Tricity trike launched
LAST year Yamaha showed its 125cc Tricity leaning three-wheeler as a concept bike. Now the production version has appeared and it looks all but identical to the preview version. The firm’s design is intended to be lighter than rivals like Piaggio’s MP3, and with a wet weight of just 152kg it appears to have achieved it – undercutting the Piaggio by around 50kg. Where the MP3 has leading link front suspension, the Tricity uses telescopic forks – there are two for each wheel, giving a total of four fork legs, although all are mounted between the wheels. The for tops are mounted on a pair of swinging beams mounted across the bike’s headstock area, allowing the whole thing to tilt. Power comes from the usual 125cc, single-cylinder engine mounted as one with the twist-and-go transmission on the bike’s swingarm. It makes a claimed 11bhp. Initial sales will be in Thailand, where the bike is built, but the firm is promising that it will be available in Europe and Japan before the end of the year. Overall length/width/height 1,905 mm × 735 mm × 1,215 mm Seat height 780 mm Weight (dry) 146 kg Weight (with oil and a full fuel tank) 152 kg Engine type Liquid-cooled, 4-stroke, SOHC, 2-valve Cylinders Single cylinder Displacement 124.8 cm3 Bore x stroke 52.4 × 57.9 mm Max. output 8.1 kW (11PS) / 9,000r/min Max. torque 10.4 N·m (1.1kgf·m) / 5,500r/min Fuel tank capacity 6.6 L Fuel supply system Fuel injection Transmission type V-belt automatic Tire size (front/rear) 90/80-14 / 110/90-12 (both tubeless) Brakes (front/rear) Hydraulic disc / Hydraulic disc Suspensions (front/rear) Telescopic / Unit swing Related Content Two-strokes will be axed from GPs in 2012 First of the Moto3s revealed Taylor Mackenzie signs two-year Moto3 deal Rieju releases RS3 125 NKD Andrea Iannone tops 125cc timesheets at Estoril Click here for full story...
[visordown.com] - Yamaha files patents for leaning electric trike | Ninjette Newsbot | Motorcycling News | 0 | September 1st, 2014 02:20 AM |
[visordown.com] - First ride Yamaha Tricity review | Ninjette Newsbot | Motorcycling News | 0 | July 21st, 2014 04:40 PM |
[visordown.com] - Yamaha Tricity threewheeled scooter to debut | Ninjette Newsbot | Motorcycling News | 0 | March 17th, 2014 04:50 PM |
[faster and faster] - 2014 Yamaha Tricity tilting trike unveiled at the EICMA | Ninjette Newsbot | Motorcycling News | 0 | November 7th, 2013 08:40 PM |
[visordown.com] - Yamaha’s Tricity, the leaning trike | Ninjette Newsbot | Motorcycling News | 0 | November 5th, 2013 04:20 PM |
