September 11th, 2009, 06:44 AM | #1 |
Join Date: Jul 2009 Motorcycle(s): 2004 ninja 250 Posts: 13
Small surge a cruising speeds.
So I have a 2004 Ninja 250,It has a K&N filter and the dynojet kit using the .98 main jet.Up until recently this bike had a full Muzzy exhaust,but I have put back stock exhaust,and actually it runs much better and I enjoy it more.Anyway I notice a slight surge when going a constant cruising speed maybe between 5000 and 7000 RPM's.It idles perfectly runs smooth to redline when you get on it,warms up easy.So my question is do you think it is a little rich or a little lean? I have recently cleaned the carbs.Logically it should be a bit rich because i switched the exhaust,without changing anything else,but doesn't have other symtoms of being rich.
September 11th, 2009, 07:09 AM | #2 |
Join Date: Aug 2009 Motorcycle(s): 90 Suzuki gsx600f Katana, 03 Buell XB9R Posts: 868
Normally surging is from a lean condition, check the needles and maybe try one clip lower to move the needles out to see if that helps.
September 11th, 2009, 08:12 AM | #3 |
Ok I'll give that a try,going to try it without pulling out the carbs this time.So your saying to go from say 4 notches to five right?
September 11th, 2009, 08:57 AM | #4 |
It's worth a try, if it gets worse then you know which way to go next time. If it get worse on 3 than there is something more complex going wrong and it's time to pull the carbs and see what is happening.
Also check spark plugs and wires, I've had odd things happen with a loose plug letting compression change, also note that some plugs will start to leak around the ceramic which can cause odd things too. |
September 11th, 2009, 09:07 AM | #5 | |
September 11th, 2009, 09:29 AM | #6 |
usually surging at a constant cruising speed indicates a lean spot in the idle circuit. I fixed mine by adjusting the mixture screws. you can try going one notch richer on the needle first, as suggested, but I think that if the midrange is fine now, going one more notch will make the midrange go flat from being too rich.
if it already has a jet kit, perhaps the mixture screw plugs have been removed? if so, it's easy to tune the mixture screws w/o having to remove the carbs. |
September 11th, 2009, 09:34 AM | #7 | |
September 11th, 2009, 09:37 AM | #8 |
try backing out the mixture screws till you get a rich indication, then go back in until it goes back to normal.
make sure the bike is fully warmed up when setting the the mixture screws. ride it like 10-15 minutes before to insure it's fully warmed. also, have you synced the carbs? |
September 11th, 2009, 11:03 AM | #9 |
I synced the carbs when I cleaned them,but that was before the exhaust swap.I'll try what you said with the mixture screws.
September 11th, 2009, 12:25 PM | #10 |
cool... let me know how it turns out. it sounds like you have a handle on how to work on the bike and that's good as fine tuning your jetting takes a lot of trial and error, plus a big heaping of patience.
September 11th, 2009, 12:50 PM | #11 |
Live Life
Join Date: Nov 2008 Motorcycle(s): 2009 Green SE Ninja 250 Posts: A lot.
Can you buy that at Sam's or do you have to go to the motorcycle shop?
- ATGATT - Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots |
September 11th, 2009, 01:00 PM | #12 |
you can get it at either... it's located right next to the elbow grease.
September 11th, 2009, 06:57 PM | #13 |
well I've been divorced twice,and am a single parent of a 15 year old girl,that I have raised alone since she was 3...so one thing I do have learned is patience.Thanks for your help.
September 11th, 2009, 07:06 PM | #14 |
Live Life
Gordon let me know if you ever take a ride to the north.
September 12th, 2009, 01:09 AM | #15 |
Join Date: Jun 2009 Motorcycle(s): 2007 EX250 Posts: 178
This may be out of left field, but if it's really windy where you're at....it could just be the wind. No, really.
Just a thought, before you go tearing into the carbs.... |
September 12th, 2009, 06:37 PM | #16 |
Again, just thinking
September 13th, 2009, 01:32 PM | #17 |
That's a good thread Jerry,thanks.I'm going to keep all that in mind and ride it around some more and try to determine if it is something else.I need to make better notes when it happens like what rpm,wind even type of pavement,thanks again.
[motorcyclenews.com - news] - Small bikes for a small budget | Ninjette Newsbot | Motorcycling News | 0 | August 30th, 2013 09:40 AM |
[motorcyclenews.com - news] - Small bikes for a small budget | Ninjette Newsbot | Motorcycling News | 0 | August 30th, 2013 02:40 AM |
Dies at higher speeds/slowing down from higher speeds | TheFranchise216 | 1986 - 2007 Ninja 250R Tech Talk | 67 | April 20th, 2012 01:13 PM |
HJC FS-15 Surge Helmet - size small | phr3ek | Gear-related | 3 | July 13th, 2011 04:12 PM |
[nytimes.com] - For Motorbike Dealer, There Are No Small Parts, Only Small Plans | Ninjette Newsbot | Motorcycling News | 0 | November 12th, 2008 11:58 PM |
