Old January 24th, 2016, 08:41 AM   #1
peperino
Motorcycle(s): 250R
Gas tank removal
Hey guys. I'm removing my gas tank (general maintenance, clean carbs, etc).
So when I remove both hoses from the petcock I have a little dripping. Fuel tap is in ON position. I drained the tank by putting it in PRI, but I'd like to fix this issue.
What could be the cause? Bad fuel tap? Should I take it out and clean it?
peperino is offline   Reply With Quote
Old January 24th, 2016, 09:45 AM   #2
Ralgha
Ralgha's Avatar
Dripping constantly, or a few drips when you take off the hose and then it stops?
Old January 24th, 2016, 10:39 AM   #3
peperino
Motorcycle(s): 250R
Constantly.
Never stops albeit it is a small dripping, it prevents me from taking off the tank with fuel in it (had to drain it)
Old January 24th, 2016, 02:08 PM   #4
Sarge1992
Sarge1992's Avatar
Motorcycle(s): 2014 Kawasaki Ninja 650R
What year is the bike? As far as 2007 or older (pregen), in any position there should be no fuel dripping. If there is, then your petcock is leaking and a new one is $50-75. As far as the 2008 and newer, I'm not sure.
Sarge1992 is offline   Reply With Quote
Old January 24th, 2016, 02:20 PM   #5
peperino
Motorcycle(s): 250R
It is a 2012
Old January 24th, 2016, 02:30 PM   #6
Originally Posted by peperino View Post
It is a 2012
No fuel should drip if your petcock is in good working order. You will have to clean it, rebuild it or buy another. :\ No worries though, it's mostly a cheap and easy fix.
Try this first and check your oil for gas contamination.
Old January 24th, 2016, 02:51 PM   #7
peperino
Motorcycle(s): 250R
Oil is fine, seems like the float valves are saving me for now.
Gonna open the petcock and see what I can do.
I've checked bikebandit and they sell the parts individually, so maybe if I find a bad part I could replace than only
http://www.bikebandit.com/oem-parts/...4177#sch731530
Maybe 43049.
It is common for a 3 year bike to have the petcock gone bad?
Thank you
Old January 24th, 2016, 03:18 PM   #8
peperino
Motorcycle(s): 250R
Am I missing any hose on the fuel meter unit? Seems like it has a place for a hose or something
Old January 24th, 2016, 03:24 PM   #9
peperino
Motorcycle(s): 250R
This guy is pretty beaten. Should I try to straighten it to see if that solves the issue? The rubber seals seem to be in good condition
Old January 24th, 2016, 04:12 PM   #10
peperino
Motorcycle(s): 250R
Alright, I've stretched the vacuum spring a bit just like the guy in the video and it is now fixed !!
Thank you!!
Old January 24th, 2016, 05:22 PM   #11
Old January 24th, 2016, 05:53 PM   #12
Sharkride
Sharkride's Avatar
Motorcycle(s): 2010 ninja 250
Is there suppose to be a hose on the sensor?...I'm stuck as well
Never rode a motorcycle but own 2
Sharkride is offline   Reply With Quote
Old January 26th, 2016, 11:38 AM   #13
Foxrider64
Hello Moto
Foxrider64's Avatar
Motorcycle(s): 1975 RD350; 2001 KX125; 2003 Z1000; 2003 KDX50; 2009 ZX6R; 2011 Ninja 250R; 2014 KX250F
No hose on the sensor- no.
I have seen several pregen 250's have the rubber smilely face go bad from contaminated fuel and the fuel switch rubbing until it starts to fall apart.
Sometimes people put an inline shut off valve in place instead of buying a new petcock- what ever floats your boat.
Foxrider64 is offline   Reply With Quote
Old February 10th, 2016, 08:36 AM   #14
peperino
Motorcycle(s): 250R
Guys I took the carbs out and now I'm reassembling. Can you give me a link where it shows where goes every hose from the carb and the emissions system?
Thank you
Old February 12th, 2016, 01:42 PM   #15
peperino
Motorcycle(s): 250R
Anyone? I couldn't find it yet
Old February 12th, 2016, 01:50 PM   #16
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
Best can give you is a link to parts:
http://www.ronniesmailorder.com/oemp...ex250f7f-parts
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old February 12th, 2016, 07:08 PM   #17
hfd1 tuner
Motorcycle(s): many mostly racebikes cbr565 fzr490 ex250ish
Have seen a drain hose on some bikes on the sensor routed to the swingarm area. In my world it is extra weight....
hfd1 tuner is offline   Reply With Quote
Old March 7th, 2016, 07:20 AM   #18
Pic of the carb hose routing:
https://www.ninjette.org/forums/show...97&postcount=5
gas tank removal mikedabike64 2008 - 2012 Ninja 250R Tech Talk 9 November 6th, 2013 08:34 PM
Paintless Dent Removal - Gas Tank Slono General Motorcycling Discussion 6 March 24th, 2013 07:10 PM
08+ Ninja 250 CA model Gas tank port questions (Evap System Removal) abhijitz 2008 - 2012 Ninja 250R Tech Talk 2 April 3rd, 2012 09:59 PM
Gas Tank Removal; Carb Boots aweesner 1986 - 2007 Ninja 250R Tech Talk 1 September 6th, 2011 06:53 AM
Notes for Kkim regarding California model "Gettin Nekkid", gas tank removal, carbs wtfh4xx 2008 - 2012 Ninja 250R Tech Talk 8 June 6th, 2011 07:56 AM
