November 9th, 2011, 04:05 PM | #1 |
Please Help - Bike not running well
I have an 06 ninja 250 I was riding down the road about 50mph and the bike started running really bad, I have cleaned the carbs the gas is good and I think it is getting plenty of fuel. It is getting air. I think the problem may be in the spark but I don't know what to do now. I put new plugs in it. It's almost like the rpms are going up really slow and it is missing and backfiring. Like it is getting random spark could this be an ic igniter problem I just don't know what I should start trying to fix. The wires on the coils are still connected very good.
Thanks for the help. |
November 9th, 2011, 05:04 PM | #2 |
vampire
Join Date: Feb 2011 Motorcycle(s): 2 many 2 list Posts: A lot.
Are the carbs synchronized?
November 9th, 2011, 05:12 PM | #3 |
November 9th, 2011, 11:19 PM | #4 |
Check the easy things first.
After you sync'd the carbs, did you connect the vacuum hoses correctly? Have you checked that the petcock works properly? |
November 10th, 2011, 01:18 AM | #5 |
I cleaned the carbs after it did this I didn't think it was a carb problem but I cleaned them anyway. I have taken them apart many times they are put back together correctly. It is running just like it did before I cleaned the carbs. The petcock is working correctly. I was just driving about 50 but I was hard on the throttle and then it just acted like it shut down and then it started missing and sputtering really bad all of a sudden which makes me think it is electrical or the motor lost compression. I don't really know where to go from here. Thanks for the replies.
November 10th, 2011, 06:20 AM | #6 |
vampire
How does it start up?
Does it idle at all? Does it idle without choke when it's cold? Is idle smooth once warmed up? |
November 10th, 2011, 06:59 AM | #7 |
With it running, wiggle the connectors where the two wires connect to each coil. If the bike changes the way it runs, then you have a broken wire inside the rubber connector shield. BTDT. I'd be riding along, suddenly it would take full throttle to maintain 55mph, then after a while it'd take off like a rocket. Very intermittent, very unpredictable. Took forever to track that problem down.
November 10th, 2011, 10:21 AM | #8 |
I will try that thanks. It idles without my help when it's warmed up but I don't know if I would say smoothly
November 10th, 2011, 10:04 PM | #9 |
When you cleaned the carbs, did you get a chance to look at the diaphragms?
November 10th, 2011, 10:50 PM | #10 |
November 15th, 2011, 05:38 AM | #11 |
I have heard of people saying that alcohol in the gas can cause lacquer in the bowls to dislodge and clog the carbs in motion. When you cleaned them, are you certain you got ALL of the little passageways clear? There are several of them in each carb.
When you are idling, the fuel takes a different route through the carbs so its possible to have it idle fine and run awful or run fine and idle awful.
November 15th, 2011, 08:19 AM | #12 |
Yes I am sure about the carbs I cleaned it good all the jets are super clean and then I seperated the carbs and pulled everything out of them and soaked them in berryman's b12 overnight
November 15th, 2011, 09:00 AM | #13 |
Smoker
All things being equal, and assuming the carbs are truly clean, when you get an "all of a sudden" issue, most of the time it's the gas. Most likely that you got some fuel with water in it. Water doesn't burn like gas (obviously) and will make the bike act exactly as you described. Of course, it could be any number of other things too, but start by drianing the float bowls and checking the gas that comes out for water / contamination. You could also let the bike sit for a while and then draw off a bunch of gas fron the tank via the petcock (set to reserve) and check that as well. Any water or other contamination should be readily visible after letting the siphoned off gas settle for a minute or two.
November 15th, 2011, 12:45 PM | #14 | |
I don't think its a wiring problem or bad gas or else it would act up when idling. Sometimes plugs can work fine at low speed, but act up at high speed or when hot. You can watch your tach and see if its vibrating when its acting up. That could indicate an ECU or ECU sensor issue. But I've never actually heard of anyone having a bad ECU. The ECU generates the pulses for the coils to make the spark. Let us know what you find.
November 15th, 2011, 12:51 PM | #15 | |
What would cause a good running bike... | corksil | 2008 - 2012 Ninja 250R Tech Talk | 22 | February 3rd, 2014 12:02 PM |
Need ideas for a non-running bike | aharnak | 1986 - 2007 Ninja 250R Tech Talk | 5 | August 11th, 2013 07:21 AM |
Bike not running, too much oil? | lstat | 1986 - 2007 Ninja 250R Tech Talk | 16 | May 14th, 2012 01:15 PM |
help - bike stopped running | Raiders fan | General Motorcycling Discussion | 7 | June 2nd, 2011 04:51 PM |
Bike is running WAY too rich. | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 5 | April 5th, 2010 12:32 PM |
