Old September 24th, 2010, 04:35 PM   #1
SV_Hadder
Motorcycle(s): 2001 Ninja 250
Question 1988 Ninja 500 fork springs?
There is a guy in my area with a wrecked 88 Ninja 500. One of the forks is slightly bent, but the spring should be ok, yes?
Also, will the older springs work in a 2001 Ninja 250? The guy selling them told me that the older springs are stiffer than the ones from the updated 1994 model, is this true or is he just BS'ing me?
I only weigh 145 w/o gear, anybody else have suspension suggestions? I was thinking EX500 fork springs and an EX500 rear shock. Thanks guys!
SV_Hadder is offline   Reply With Quote
Old September 24th, 2010, 04:46 PM   #2
http://faq.ninja250.org/wiki/Front_suspension_upgrades
Old September 24th, 2010, 05:41 PM   #3
SV_Hadder
Yeah.... I've read that, too. Didn't find anything much in the way of pre-94' ex500 springs, that's why I asked you guys. Thanks!
Old October 2nd, 2010, 12:00 AM   #4
ReDnEcK
ReDnEcK's Avatar
Motorcycle(s): 2005 Kawasaki Ninja 250R
I just upgraded my '03 ninja 250 rear shock to a '08 ninja 250 rear shock and I love it! See my thread titled "newgen shock installed" in the '86 - '07 Tech Talk section.
As for the EX500 springs, I think the '94 and newer springs are the only ones that will fit.
Posted via Mobile Device
ReDnEcK is offline   Reply With Quote
Old October 2nd, 2010, 07:55 AM   #5
SV_Hadder
Yeah I have been following that thread of yours, and I'm thinking about going with the new-gen 250 shock. How much do you weigh? I'm only about 145 without gear, so maybe 155 with gear, I would think that the new-gen rear shock and some 94' and up Ninja 500 fork springs would suit me just perfect. I wanted to get a ninja 500 rear shock, but they are either too old, or too expensive... There are 07 ex500 shocks on ebay for like $100 which is ridiculous for what you are getting. Then there are mid 90's ex500 shocks for around 30 to 70, and those are likely to be worn out/leaking oil, which would be a waste of money.
Old October 3rd, 2010, 03:27 PM   #6
ReDnEcK
ReDnEcK's Avatar
You could always make some longer spacers for the fork springs and see how you like it before spending money for nothing. Its very easy to do, almost as easy as replacing the rear shock.
Old October 6th, 2010, 12:49 PM   #7
bob138
Motorcycle(s): 1991 EX500 , 2009 250r
Pre Gen ex250 had 36mm fork tubes.
1st Gen ex500 had 36mm fork tubes.
So those are replaceable and could provide a firmer front.
New Gen ex250 has 37mm fork tubes.
2nd Gen ex500 has 37mm fork tubes.
You'd have to compare stock spring rates to be sure. I'll see if I can dig them up.
Bob
bob138 is offline   Reply With Quote
Old October 8th, 2010, 09:31 AM   #8
Guppy1026
Motorcycle(s): 07 Harley Ultra, 04 883 Sportster, 07 Ninja 250
Bob
Any word on the spring rates on the New Gen 250's?
Guppy1026 is offline   Reply With Quote
Old October 8th, 2010, 12:15 PM   #9
http://www.ninjette.org/forums/showp...15&postcount=9
from this thread...
http://www.ninjette.org/forums/showt...ht=spring+rate
Old November 19th, 2010, 02:35 AM   #10
SV_Hadder
Bob
So if the 1st gen EX500 (94 and older) is 36mm, and the pregen 250 is 36mm...... why does the suspension FAQ say to get 94' and newer EX500 (2nd gen with 37mm tubes) springs?
Also, according to a wiki on the EX500, during the minor revamp of the 500, the fork springs were stiffened up, thus answering my original question, but which springs fit a pregen EX250?
Thanks!
FS: Pregen : Fork Springs, Fork Clamp, Factory Pro Jet kit FvnnyL3tt3r1ng Motorcycle-related 20 February 24th, 2016 08:24 AM
Can fork springs be changed without removing the fork tubes? AlanDog 1986 - 2007 Ninja 250R Tech Talk 26 April 23rd, 2014 05:19 AM
$500 for a 1988 Ninja 600R IF13 General Motorcycling Discussion 9 October 14th, 2013 07:50 AM
WHat are these and why are they so cheap? (fork springs) psych0hans Ninjettes At Speed 6 October 7th, 2012 10:21 AM
WTB: 1995-2007 Ninja 500 fork springs SV_Hadder Items Wanted 0 November 16th, 2010 10:32 PM
