Old August 5th, 2015, 03:53 PM   #1
JayJay
Unhappy Help please!!! Clutch cable
Okay so something happened with my clutch cable, all the tiny wires frayed. My boyfriend removed the old clutch cable and i bought a new one today. I'm trying to get it mostly back together before he gets in from work. If i am sitting on my bike, looking down at the handle bars, does my clutch cable go infront of the forks, and then down the right side of the bike, or does it go under the forks and "across" the top of the engine?
Really hoping I didn't buy the wrong cable! He said it was for a '12 ninja 250. But so far it looks to be about 6 inches too short.
JayJay is offline   Reply With Quote
Old August 5th, 2015, 05:41 PM   #2
C-Bass
C-Bass's Avatar
Motorcycle(s): Currently own: 98 Honda VTR1000, 02 Suzuki's DR200 & DR650, 04 & 08 BUSA's, 05 Ducati SS1000, 12 Ninja 250R SE
The clutch cable goes like this -
C-Bass is offline   Reply With Quote
Old August 5th, 2015, 06:28 PM   #3
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Good pic, C-Bass!
A trick for next time Jessica or boyfriend replaces a clutch cable:
Have the new cable in hand before you remove the old cable.
Unhook both ends of the old cable.
Duct tape the bottom end of the new cable to the top end of the old cable.
Pull out the old cable from the bottom while feeding the new cable in from the top.
Remove the duct tape when the new cable is pulled through: routing for the new cable is now correct and in same place as the old cable.
Old August 5th, 2015, 06:58 PM   #4
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Originally Posted by dcj13 View Post
Good pic, C-Bass!
I did that when I replaced my chain. Not using duct tape of course. Just roll the rear tire and the new chain gets routed to the front sprocket
Riding it like I financed it.
Old August 6th, 2015, 07:35 AM   #5
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Do you have the supplies to lube the new cable? It comes dry so you'll need grease on the pivot point at the lever and lube for the cable itself.
Here's a nice DIY: https://www.ninjette.org/forums/showthread.php?t=16000
<-- Linky
Old August 6th, 2015, 07:54 AM   #6
JayJay
Thanks for the help!!
We got the clutch taken care of, just to run into more issues. :/
Going down the road, my bike is crooked? the rearend isn't crooked, nor does it feel like it is pulling, but my handlebars are crooked.
All i can think of is when we were kids and we had to grab the front tire of our bicycle between our knees and readjust our handlebars
Clutch cable Linkin 2008 - 2012 Ninja 250R Tech Talk 5 January 28th, 2015 03:29 AM
Clutch Cable Scootch 2008 - 2012 Ninja 250R Tech Talk 18 March 8th, 2012 02:02 AM
Clutch Cable atomicrm 2008 - 2012 Ninja 250R Tech Talk 2 December 17th, 2011 12:22 PM
clutch cable slackerman 1986 - 2007 Ninja 250R Tech Talk 2 September 3rd, 2011 05:37 PM
Help on Clutch Cable kashun84 2008 - 2012 Ninja 250R Tech Talk 6 March 31st, 2011 08:55 PM
