Old July 18th, 2023, 07:27 PM   #41
From the photos of the adapters, I don't see a way to have a valve at the engine end. That means the volume of the adapter will be added to the combustion chamber volume and lower the readings substantially.
That's not to say that it caused the reading to be 40! It's sounding like something is wrong with the cooling system, allowing the cylinders to overheat, and that ruined the engine.
Old July 18th, 2023, 07:50 PM   #42
haybaler
Motorcycle(s): Ninja 250 and Yamaha Fazer 700
Thanks for the link.
Sorry for your bad luck. If I wasn't 2500 miles away, I would snap that one up, in a heartbeat, love that Kawasaki Green paint scheme.
haybaler is offline   Reply With Quote
Old July 18th, 2023, 07:53 PM   #43
haybaler
I thought my snap-on attachment with valve would screw right into the adapter, wouldn't change the position of the valve by very much, would it?
Old July 19th, 2023, 03:15 AM   #44
Animal78
Motorcycle(s): 08 Ninja 250(sold) 2000 Ninja 250 (sold) 2012 Ninja 250r 2020 Harley Sportster (rarely ridden)
Yeah I still have the Schrader valve it’s a very small amount lost to the end of that adapter and if you turn the engine over enough times it wouldn’t matter.
It’s what it is.
Animal78 is offline   Reply With Quote
Old July 19th, 2023, 09:14 AM   #45
haybaler
"It’s what it is."
It's a pretty nice 250 bike, maybe consider teardown, easy enough to get the top end out of there, then inspect to determine actual damage...there's plenty of used parts around, and fresh gaskets available...just sayin'
Old July 19th, 2023, 10:26 AM   #46
Animal78
Yeah I have thought of that. It’s just not financially worth it. If I am going to sink time and money into something I have higher priority items. This was supposed to be a cheap fun commuter for me and it’s not turning out like that. I have 4 other motorcycles 3 are off-road and 1 is my Harley that I actually loath.
Old July 20th, 2023, 03:05 PM   #47
Animal78
Any differences between the 1987 engine and the one in my 2000? I have the chance to pick up a whole bike for dirt cheap. It’s really rough.
Old July 20th, 2023, 07:56 PM   #48
Different cam-specs, ignitor box. Use your cams on '87 engine so you have more mid-range and don't have to wind it out to redline all the time. Then use ignitor box from older bike.
Compression Numbers NinjaBraap 1986 - 2007 Ninja 250R Tech Talk 22 November 21st, 2018 02:01 PM
Compression test: What size hole? 2weelz 1986 - 2007 Ninja 250R Tech Talk 18 September 9th, 2016 07:37 PM
Average Compression HoneyBadgerRy 1986 - 2007 Ninja 250R Tech Talk 80 March 31st, 2016 08:45 PM
JE High Compression Piston Kit (13.5:1 compression, 356cc displacement) Timpo 2013 - 2017 Ninja 300 Tech Talk 8 October 12th, 2015 07:21 PM
What is compression Racer x 2008 - 2012 Ninja 250R Tech Talk 22 March 15th, 2013 02:44 AM
