May 25th, 2014, 11:04 AM | #1 |
air filter contaminated with gas
Today i removed the air filter from my ~4000 mile ninja 300 so i could do a snorkel delete (i have a yoshi slip on and no other mods.) When i removed the foam air filter, i noticed that the dirty side looked wet and oily and it turned out to be gas.
On the odd occasion when i filled up my tank i would notice later in the day that some gas has overflowed out the overflow tube but only a few drops. Otherwise i have had no issues at all. Any ideas how gas could have gotten there, is this something i should be worried about? Thanks Stephen |
May 25th, 2014, 11:37 AM | #2 | |
Depending on your style of riding, it is normal that the intake valves let some mix go back into the filter box at the beginning of the compression stroke. Wash and re-oil the foam filter....... and keep riding.
May 25th, 2014, 11:55 AM | #3 | |
Thanks for the warm welcome and excellent information. I don't know what style i would be called; I rev match every downshift and ride the revs down with the throttle open slightly so that it pops and backfires (can't get enough of backfires - i drive my cars the same way) and frequently take it to WOT and 11-12k atleast once everytime i ride (which is daily to work.) |
May 25th, 2014, 11:59 AM | #4 | |
That explains it well. The residual fuel on the filter may be from backfires that never ignited.
May 25th, 2014, 12:13 PM | #5 | |
in my experience with cars when you add an exhaust or intake, the ecu would overcompensate for the added air and run a little richer, are these bikes the opposite that they do not compensate for the extra air? |
May 25th, 2014, 12:35 PM | #6 | |
Let's call some more knowledgeable members: @choneofakind, @alex.s, @cuong-nutz, @DaBlue1, @dcj13, @Sirref, @csmith12, @InvisiBill
May 25th, 2014, 12:50 PM | #7 |
just a hi flo air filter in the box isnt changing a whole lot. cars use a feedback loop to correct the fuel ratio. the 300 is a simple lookup table. no "auto corrections". the slipon isnt modifying the flow of the exhaust enough to matter. the headers are what matter.
will it kill your bike? probably not. will it help your bike? probably not without chaning the fuel map. (since they come lean from the factory)
May 25th, 2014, 06:43 PM | #8 | ||
Private Joker
MOTM - Mar '14
I've never gotten gas overflow but I don't fill my tank up to the top, I fill it up to right below the little grate for the gas cap lock. Are you filling it above that? Quote:
May 25th, 2014, 06:58 PM | #9 |
See what Area P had to say about the AFR curve for the 300.
https://www.ninjette.org/forums/show...10&postcount=7 |
May 27th, 2014, 11:30 AM | #10 | |
EX500 full of EX250 parts
I really don't know enough specifics about the 250/300 to add anything useful to this conversation. Based on what the others have said, it won't automatically adjust the fueling, which isn't surprising. If it really is a bit rich (it's safer to be rich than to be lean), then some small flow improvements like the K&N and exhaust might put it closer to ideal by leaning it out a tad. For best results, you'd want to retune it to match your parts, regardless of how much or little you changed (or even if it's 100% stock, according to Area P). That can get tedious and/or expensive adjusting for every little change though. |
K&N air filter to stock air box | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 29 | July 28th, 2012 06:33 AM |
Anyone know an air filter I can replace the OEM filter with? | Monkeytofu | 1986 - 2007 Ninja 250R Tech Talk | 5 | July 22nd, 2012 09:34 AM |
[sportrider - latest stories] - K&N Air Filters Named as Official Air & Oil Filter Su | Ninjette Newsbot | Motorcycling News | 0 | June 11th, 2012 06:00 PM |
HELP - Gas in air filter | dragonboy | 2008 - 2012 Ninja 250R Tech Talk | 15 | June 16th, 2011 10:18 AM |
Gas spills out of my 0990 Air Filter! !@#$% | 00v_Lucky | 2008 - 2012 Ninja 250R Tech Talk | 15 | September 18th, 2010 05:20 PM |
