October 3rd, 2009, 07:31 PM | #1 |
Join Date: Jan 2009 Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock Posts: A lot.
Speedo Came Off!
Speedo CABLE that is
went for a short evening ride and had actually traveled about a mile thru residential area until i noticed...no speedo reading..odometer and trip meter no werkie... got to gas station and noted the speedo cable from forks to front wheel hub was hang'in kinda low...upon further review, i realized it wasnt connected at the top! thought it was broken at first but saw the threaded connector and understood that it had worked itself loose over time as i have done no maintenance anywhere near that stuff. (speedo cable is circled #3 in diagram) (..and my bike didnt have that 'clamp' at headlight) Speedo Cable.jpg made sure it was secure for the ride home, and once in the garage, before looking anything up i saw where it went to and tried to reconnect. isnt quite reachable from the bottom up, so had to work between instrument cluster, handle bars and forks from the top-down...and still couldn't connect it. THEN i looked at the manual and saw the positioning of that bend in the metal piece fitted at the top end of cable. routing the cable and aligning that metal section from the bottom was easiest, then tightened connector up top. reconnected! ops check good! thinking about it later, i did have some clue the cable was working itself loose. the last time i refueled and reset the trip meter it didn't work for the first mile or two...speedo was fine but for some reason trip meter didnt turn. just an afterthought... wanted to fyi my adventure... friday nights just are NOT what they used to be aloha
Remember when sex was safe and motorcycles were dangerous? |
October 3rd, 2009, 11:32 PM | #2 |
ATGATT Squid Killer
Join Date: May 2009 Motorcycle(s): '06 CBR600 Posts: 189
This is actually a fairly common problem with with both the EX250s and the EX500s. If you didn't do it this time, I HIGHLY recommend Locktite on the threads when you put the cable back on. The same thing happened to me one night, so I googled it and found that others have had the same problem.
October 3rd, 2009, 11:35 PM | #3 |
thanx chad... didn't have any at the time but definately worth the doing...
and dang...did other's have theirs fail at night too??
October 4th, 2009, 08:16 AM | #4 |
North Alabama Mtn. ryder
Aloha Steve, Your not alone I've had mine back off from both ends, you don't need lock tite just use some slip joint pliers, get it hand tight and give it a little extra tourqe. hav't had it happen again
QTRltrPWR |
October 4th, 2009, 09:29 AM | #5 |
dirty old man
Join Date: Nov 2008 Motorcycle(s): Blue '08 Ninja 250 Posts: A lot.
Whew, for a minute there, that was a visual I didn't really want to see.
nb
Death tugs at my ear and says, "Live, I am coming." -Oliver Wendell Holmes, Sr., poet, novelist, essayist, and physician (1809-1894) www.friendsofsanonofre.org |
October 4th, 2009, 09:35 AM | #6 |
Join Date: May 2009 Motorcycle(s): '09 Kawasaki N-250 + '09 Vulcan 900 Classic Lt Posts: A lot.
Same thing happened to my 2007 N-250. Just vibrates itself off. Screwed it back on up under the dash tightly and it behaved itself from then on. But its hell to get the angle when you are in a hurry. (doesn't it seem some things just end up seeming pornographic when you work on a bike)
October 4th, 2009, 12:45 PM | #7 |
Join Date: Apr 2009 Motorcycle(s): 2000 Honda CBR600F4 (sold) 1999 Ninja 250 (sold) Posts: 586
Happened to me too a few months ago... got home, put it back on.. all good.. but apparently it is common!
2000 Honda CBR600F4 Silver and Red 1999 Kawi Racing Green Ninja 250 sold |
May 29th, 2011, 03:34 AM | #8 |
Join Date: Apr 2011 Motorcycle(s): 2002 Kaw Ninja 250/05 yama RSTD/03yama 1100 Classic Posts: 5
yupyup Happened to my wife yesterday. A pain to get to as well but I got it and a pair of needle nose latter had it back on and TIGHT this time I hope. Can always do the Loc-tite later if it happens again.
May 29th, 2011, 01:55 PM | #9 |
Speedo Drd, Speedometer and Odometer Accuracy-Speedo Healer/drd | Klondike1020 | General Motorcycling Discussion | 8 | August 17th, 2014 12:23 AM |
My speedo is way out! | Damo990 | 2013 - 2017 Ninja 300 Tech Talk | 14 | March 5th, 2014 06:54 AM |
Aftermarket speedo | lowandslowcabby | 1986 - 2007 Ninja 250R Farkles | 5 | May 25th, 2013 08:03 AM |
Speedo Problem | Ninja28 | 2008 - 2012 Ninja 250R Tech Talk | 8 | October 9th, 2011 05:16 PM |
My speedo is off??? | Kitdog | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 28th, 2010 03:24 PM |
