September 27th, 2009, 05:44 PM | #1 |
Join Date: Sep 2009 Motorcycle(s): 2000 Ninja EX250 Posts: 6
Dude are you freakin serious? Rear brake problem.
Hey guys, Ok, kinda ticked off here I just purchased my 2000 ninja from a guy 3 weeks ago rear brakes were quit worn but had no problems, great pressure and everything. The putz offered to replace my pads I said ok, sure no problem so pads come in the guy replaces them and now for some reason, no freaking brake pressure! After almost an hr of bleeding and still no luck please help!
September 28th, 2009, 08:39 AM | #2 |
Join Date: Apr 2009 Motorcycle(s): 2000 Honda CBR600F4 (sold) 1999 Ninja 250 (sold) Posts: 586
Did the piston come out of the bore? You shouldnt have to bleed doing a pad swap.. My knowledge is cars more than bikes.. can you bleeed at the rear master and then the caliper?
2000 Honda CBR600F4 Silver and Red 1999 Kawi Racing Green Ninja 250 sold |
September 28th, 2009, 02:57 PM | #3 |
Join Date: Aug 2009 Motorcycle(s): 90 Suzuki gsx600f Katana, 03 Buell XB9R Posts: 868
I have a feeling that you will need to tear the caliper down and replace the seals before it will work properly. Are you leaking fluid onto the rotor yet? That's a sure sign of a damaged seal. Other wise you may want to bleed the brake yourself to make sure all the air is out.
September 28th, 2009, 08:24 PM | #4 |
Problem solved guys thanks, turns out that the brake pads were not seated correctly therefore not making contact with the rotor all is well now Thanks!
September 28th, 2009, 08:43 PM | #5 |
Note to self... If you want it done right, do it yourself.
September 30th, 2009, 10:54 AM | #6 |
Join Date: Jul 2009 Motorcycle(s): 2002 Ninja 250 Posts: 159
I don't understand how you have time to complain when you could be helping him fix this..he really has no obligation to fix your bike after he has sold it to you no matter what he has said.
Bay Area Event Coming Up: June 2, 2012 Mike's Newb Group Ride |
Just installed new gen rear wheel, brake problem? | Zombarian | 1986 - 2007 Ninja 250R Tech Talk | 6 | August 2nd, 2014 09:26 PM |
Rear Brake Problem | RandomPhantom | 2008 - 2012 Ninja 250R Tech Talk | 11 | July 11th, 2014 05:10 AM |
Dude, use the rear brake! | adouglas | General Motorcycling Discussion | 43 | June 28th, 2010 02:02 PM |
rear brake problem after 600 miles maintenance | tac12345 | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 25th, 2010 02:45 PM |
[kropotkin thinks...] - Le Mans MotoGP Debrief: Pedrosa Reveals Rear Brake Problem | Ninjette Newsbot | Motorcycling News | 0 | May 28th, 2010 10:30 AM |
