Old June 22nd, 2014, 11:17 AM   #1
What do I need to bring to see if this engine works?
The seller doesn't know if the engine runs, so it could be a good deal or a terrible deal:
http://atlanta.craigslist.org/atl/mpo/4509727409.html
It's not very promising that the guy hasn't plugged the intakes.
It's removed from the donor bike but I have enough to throw together a rolling chassis I can bring to try it out. At a minimum I assume that I need:
Carbs/airbox
Battery
Ignition
Ignition coils and plug cables
Handlebar control
Wire harness
Cooling system with coolant
A way to get fuel into the carbs
Anything I'm missing?
Just in case, I'd bring oil and spark plugs.
Old June 22nd, 2014, 11:57 AM   #2
if it has oil, check the oil for glitter.
if it doesn't have oil, put oil in, take out one of the spark plugs and put in a compression tester, then apply power to the starter. (put it on wood straight up and down and watch your hands of the sprocket) does it sound like a normal engine before it starts? or is it not making any compression at all? does it even turn? don't do it more than a couple seconds
if it all sounds peachy keen, check the oil for glitter again. remove the oil filter and oil screen. no glitter? maybe its not terrible
Old June 22nd, 2014, 12:04 PM   #3
Unfortunately, a compression tester is not something that I have around. Is that the kinda thing I can get from a tool loaner program at an auto parts store?
Old June 22nd, 2014, 02:03 PM   #4
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
yes you can get one at autozone etc. Then there s the transmission part of the equation...
My Cafe Racer Build
My intro post
Old June 22nd, 2014, 02:40 PM   #5
transmissions on these bikes are very good and very easy and cheap to fix
Old June 22nd, 2014, 03:24 PM   #6
baxtc1
baxtc1's Avatar
Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50.
$200 for the engine, if you want to start messing around like that, he might tell you to bugger off.
Simply buy and try. Be hard pressed to find an engine that cheap anywhere else.
Originally Posted by jgcable;
I ride a 2006 Custom HD Wideglide..... and I almost have to sign autographs when I park it.
baxtc1 is offline   Reply With Quote
Old June 22nd, 2014, 03:41 PM   #7
Yarhj
Yarhj's Avatar
Motorcycle(s): Ninja 250 (2001)
Well, even if it's not running you should be able to sell the valve cover for like $30, and the rocker arms for $20-$30 each, so just take the valve cover off and make sure everything looks good in the top end and you can't really go wrong.
Yarhj is offline   Reply With Quote
Old June 22nd, 2014, 05:08 PM   #8
Ninjinsky
Ninjinsky's Avatar
Yep, just buy it, it will part out for much more than you paid. Take a socket wrench to turn the engine over on the crank bolt (and a large coin with mole grips to unscrew the plastic end cover. If it turns over you know the valve train is not damaged, that's all I would do in the low price circumstances. But for the Atlantic ocean I would race you to it
Old June 22nd, 2014, 05:43 PM   #9
Yarhj
Yarhj's Avatar
It is only ninjette camaraderie that keeps me from running over and buying it myself!
Well, that and sloth.
Old June 22nd, 2014, 06:10 PM   #10
I've checked my finances and I don't think I can spare $200 any time soon anyway ($1,200+ emergency vet bill, moving into a new apartment, etc).
Based on your avatar, I'd say you probably need it more than me.
Go get it!
Old June 22nd, 2014, 07:14 PM   #11
Yarhj
Yarhj's Avatar
Go get it!
OK, so the third thing keeping me from running over and getting it is $200. Or is that 200 things? =P
[roadracingworld.com] - Restored Ex-Works Vincent Black Shadow Expected To Bring As M Ninjette Newsbot Motorcycling News 0 March 4th, 2013 09:20 PM
[roadracingworld.com] - Restored Ex-Works Vincent Black Shadow Expected To Bring As M Ninjette Newsbot Motorcycling News 0 March 4th, 2013 12:30 PM
[roadracingworld.com] - Restored "Ex-Works" Vincent Black Shadow Expected To Bring As Ninjette Newsbot Motorcycling News 0 March 4th, 2013 10:40 AM
[hell for leather] - How the new R1200GS’s engine works Ninjette Newsbot Motorcycling News 0 February 12th, 2013 09:50 PM
[topix.net] - Hitler's personal plane was powered by this US-designed engine [Engine Ninjette Newsbot Motorcycling News 0 June 14th, 2011 03:10 PM
