#1 |
Join Date: May 2011 Motorcycle(s): 2007 Ninja 250 Posts: 11
Sounds like metal scraping at high RPM?
Whenever I am at around 10k RPM or higher my bike makes a noise that sounds like metal scrapping or dragging against something. Anyone know what this could be?
#2 |
KThanksBye
Join Date: Mar 2011 Motorcycle(s): 2006 zx636r Posts: A lot.
Brakes?
----> My Youtube! <---- Unregistered, watch my youtube page! ![]() |
#3 |
Join Date: Jan 2011 Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r Posts: A lot.
check oil level?
#4 |
clutch lever vibrating?
#5 |
vampire
Join Date: Feb 2011 Motorcycle(s): 2 many 2 list Posts: A lot.
#6 |
happens when im out riding, only above 10k
going to re lube the chain tomorrow if the rain stops and then take it out again |
#7 |
vampire
You can try and diagnose the problem while the engine is running, bike parked on the centerstand.. even while it's raining
#8 |
yea but i honestly dont feel like standing out in the rain to do that when i can do it once the rain stops
#9 |
I think he meant running
#10 |
Join Date: May 2011 Motorcycle(s): 2007 Ninja 250R Posts: 18
Push down on the clutch lever when it starts making the noise... it's probably that vibrating. Give a search, it's a common issue.
#11 |
Join Date: Mar 2011 Motorcycle(s): 2009 Kawasaki Ninja 250r Posts: 51
Thats when my bike has a jingling metal sound.. now I'm thinking it could be the clutch level like the other guys were saying?
#12 |
Join Date: Mar 2011 Motorcycle(s): 2007 ninja 250r Posts: 374
My clutch lever rattles around 8k all you do is hold the clutch lever and see if it still makes that noise
#13 |
Join Date: Jun 2011 Motorcycle(s): 2008 ninja 250 Posts: 17
i think i had the same problem ...
i took it to the shop and ended up replacing the chain and cogwheel. |
#14 |
Ice cream
Join Date: Jun 2011 Motorcycle(s): 2007 ex 250, 2005 xlc 883 Posts: 34
#15 |
Any words of wisdom on this one ?
i think i'm experiencing the same problem now - buzzing sound at 10RPM ... |
#16 |
I had a bad master link on a chain that would sometimes scrape the sprocket cover as it passed around the front sprocket.
#17 |
Join Date: May 2011 Motorcycle(s): 2011 Ninja 250R SE GREEN! Posts: 562
Mine makes a jingling noise too around 9k rpm. I think it's the timing chain
#18 |
Jigglin' your Jiglets
MOTM - Apr '13
Same here! Let me know if you figure out what it is. It's not a steady rattle its sort of a sporadic jingle.
If the Ninja 250 doesn't have enough power for you, then you don't know how to ride it. AFM #676 ![]() Supersports are for n00bs |
#19 |
the noise stops when squeezing the clutch if it helps ...
#20 |
Eternal Noob
Join Date: Feb 2011 Motorcycle(s): "Blanka" 07' Ninja 250 Posts: 247
Mine ALSO makes this same noise at almost exactly 9k :/
#21 |
KThanksBye
#22 |
Fighterer in Training
Join Date: Jul 2011 Motorcycle(s): 2001 Ninja 250R Posts: 316
Now that we're on the subject of clutch levers, how much play should there be in the clutch lever? On my 01, there seems to be about half an inch or so of movement of the lever before I see some movement on the transmission. Should there be that much? I'm assuming that its slack in the clutch cable. I haven't ridden the bike yet, just trying to go over any possible problems before I take it on the road.
Posted via Mobile Device |
#23 | |
KThanksBye
![]() Ps: Mine has about that much play too and I dont hear anything
Just cleaned carbs - now stuttering at low RPM, fine at high RPM | Ohio | 2008 - 2012 Ninja 250R Tech Talk | 20 | August 5th, 2014 10:30 PM |
High handle bar vibration, hard to get into high RPM, is this normal? | jackliu239 | 1986 - 2007 Ninja 250R Tech Talk | 24 | September 19th, 2013 09:04 PM |
Rpm too high? | mms1361 | 2008 - 2012 Ninja 250R Tech Talk | 2 | April 3rd, 2011 07:20 PM |
High Idle RPM... | wayanlam | 2008 - 2012 Ninja 250R Tech Talk | 4 | July 20th, 2010 09:59 PM |
