Old May 18th, 2013, 09:47 AM   #1
quadcrazy
Motorcycle(s): Ninja 300
How do I remove the Cat from my California model?
Hey guys, so I have a California model Ninja 300. From what I understand this comes stock with a cat and some other components that I don't know much about. I read somewhere that removing the cat may slightly increase power and seeing as how I live in Florida I don't need it. Does anyone know how I could go about doing this?
Thanks
quadcrazy is offline   Reply With Quote
Old May 18th, 2013, 10:04 AM   #2
Joshorilla
Bass Master General
Joshorilla's Avatar
You don't "need" it by law, but there is a strong moral argument to leaving it in, they measurably reduce emissions, and manufacturers but them in for a good reason.
If you did cut the cat out, you would also need to change the fuel ratio by using a piggyback device or re-flashing the computer or you'll run lean.
If the 300 has a snorkel, you could remove this for more power.
Old May 18th, 2013, 11:47 AM   #3
old3
Towards the end of the thread.
http://www.ninjette.org/forums/showthread.php?t=120376
I'd ride it without a tuner for a bit, but definitely get one at some point. The Area-P is excellent.
old3 is offline   Reply With Quote
Old May 18th, 2013, 01:57 PM   #4
quadcrazy
I can definitely respect the moral argument of leaving it on, I'm just curious as to how to do it. I appreciate the responses but what do you guys mean by it running lean? And what is a tuner?
Thanks again.
Old May 18th, 2013, 05:16 PM   #5
old3
The fueling is a bit lean to begin with on the 300, less fuel than air to better pass smog testing. When you remove air restrictions in the path of that charge, either intake or exhaust, it gets leaner still.
A tuner is a piggy back computer that adds or subtracts fuel for the best ratio that the engine works at regardless of what a government document says it should be. The engineers who built the bike would have the fuel set this way if they were free to do so. An Area P tuner can adds gobs of torque and power to a bone stock bike.
Honestly, if you aren't sure what these things do yet, take some more time to get your feet wet. Do your homework and figure what you want and what you need.
Old May 19th, 2013, 12:57 PM   #6
quadcrazy
Appreciate the responses, I'll look more into everything.
Old May 19th, 2013, 01:17 PM   #7
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Offer it a saucer of warm milk.
Old May 19th, 2013, 02:08 PM   #8
Bthibodeaux
Motorcycle(s): Ninja 300, Ducati 916
Jim,
I am planning to remove my cat next weekend, and install the Area P tuner with Akrapovic S/O. So I guess I am a copy cat....
Anyway, can you tell me how much of the header you cut off to get to the cat internals?
Thanks,
Brian
Bthibodeaux is offline   Reply With Quote
Old May 19th, 2013, 02:29 PM   #9
old3
Originally Posted by Bthibodeaux View Post
Jim,
Thanks,
Brian
Brian, if you look at post #20 in the thread I linked above you can see where I cut mine. That should get you close enough, it chipped out pretty easily. One slice, remove and weld it back together. If you have a welder at home it is a one hour job start to finish, tops.
Old May 19th, 2013, 02:45 PM   #10
Joshorilla
Bass Master General
Joshorilla's Avatar
If you invest in a bazzaz unit, you will have the ability to add a self tuner unit, and will have access to all the maps other users upload to their DB.
It's a little more expensive than the area p, but the software seems better and the access to maps from their DB also seems better.
http://www.bazzaz.net/index.php/maps-research-database
Old May 19th, 2013, 02:53 PM   #11
Bthibodeaux
Got it. Thank you! Yep, have a little Miller 135 MIG.
Old May 19th, 2013, 03:27 PM   #12
old3
IIRC you can stick a wire in there to get a fix on the cat so you avoid chopping thru it.
Old May 19th, 2013, 08:14 PM   #13
quadcrazy
Hey old3,
So basically you cut the exhaust and pulled out the cat? Then had it welded back together? Before installing the tuner I mean.
Old May 19th, 2013, 08:18 PM   #14
old3
Yep. Off road use only, of course.
Old May 20th, 2013, 04:25 AM   #15
quadcrazy
What do you mean? Sorry for my noobness.
Old May 20th, 2013, 01:01 PM   #16
old3
That is the tag all the exhaust companies put on their systems and cans.
Ninja 300 California model? quadcrazy 2013 - 2017 Ninja 300 General Discussion 10 April 24th, 2013 11:29 AM
To remove or not to remove?? extremez31 General Motorcycling Discussion 13 April 18th, 2012 07:54 AM
Hey California Riders! Yes, I'm from California! tommyher New Members 18 February 5th, 2012 04:49 PM
[roadracingworld.com] - New Moto Guzzi California 90 Marks End Of California Model L Ninjette Newsbot Motorcycling News 0 October 8th, 2011 07:50 AM
Notes for Kkim regarding California model "Gettin Nekkid", gas tank removal, carbs wtfh4xx 2008 - 2012 Ninja 250R Tech Talk 8 June 6th, 2011 07:56 AM
