Old June 26th, 2013, 10:28 PM   #1
quadcrazy
Motorcycle(s): Ninja 300
Slip on exhaust for cali model 300
Hey guys, I am thinking of getting a two brothers slip on exhaust for the 300. Only concern is that it is a cali model, which means it has cats and some other differences I don't know 100% about. Does anyone know if I'd have to do anything special to avoid problems with this slip on? I think someone said it may make the bike run leaner than it already does, can anyone back that up? And if so, would a commander be necessary?
Thanks!
quadcrazy is offline   Reply With Quote
Old June 26th, 2013, 10:33 PM   #2
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
Slip-on exhausts don't really change anything. Don't worry too much about it. A tuner such as power commander would still help the bike run better regardless as the stock bike is tuned for better fuel efficiency and for emission standards, not for power.
Old June 26th, 2013, 10:59 PM   #3
JELY1990
Boring is my middle name.
JELY1990's Avatar
Motorcycle(s): '09 Ninja 250r
JELY1990 is offline   Reply With Quote
Old June 26th, 2013, 11:14 PM   #4
quadcrazy
Thanks for the quick response. By just doing the slip on and not the full exhaust system it still gets a significant noise increase right? Isn't that why people generally get them?
Old June 26th, 2013, 11:17 PM   #5
JELY1990
JELY1990's Avatar
Yes people generally get them for a different sound. Some are louder than others. Like the mgp growler for the 250 is known as one of the loudest and most annoying exhausts you can get.
Old June 26th, 2013, 11:21 PM   #6
quadcrazy
Lol gotcha. How would you rate the two.brothers slip on?
Old June 26th, 2013, 11:27 PM   #7
JELY1990
JELY1990's Avatar
I haven't heard a two brothers on a 250 but on my friend's cbr600 it sounds great.
Since you're interested in aftermarket exhausts you should check out AreaP if want more performance plus better sound. It'll cost you more though.
Old June 26th, 2013, 11:31 PM   #8
quadcrazy
I will check it out, thanks!
Old June 26th, 2013, 11:32 PM   #9
tfkrocks
tfkrocks's Avatar
Slip-ons are purely for sound and looks. The sound level differs based on the one you get and whether or not you have a baffle in.
Old June 26th, 2013, 11:33 PM   #10
JELY1990
JELY1990's Avatar
No problem. How did you end up with a cali model by the way? Cause isn't Lake Worth in Florida?
Old June 26th, 2013, 11:41 PM   #11
quadcrazy
Old June 26th, 2013, 11:44 PM   #12
quadcrazy
What is a baffle? How do I know if a slip on comes with one?
Old June 27th, 2013, 12:45 AM   #13
tfkrocks
tfkrocks's Avatar
It's a removable insert that goes in the exhaust to reduce the sound. They usually tell you whether or not it comes with a baffle or if you need to buy it as a separate part.
Old June 27th, 2013, 06:57 AM   #14
Dark
Simple kind of man
Dark's Avatar
I wouldn't bother with a power commander if you're only installing a slip on, no real point for what it costs.
The only differences with the california model (IIRC) is the charcoal canistor that captures fuel vapors from the tank (and spillage).
Dark is offline   Reply With Quote
Old June 27th, 2013, 07:36 AM   #15
quadcrazy
Thanks for all the responses and help guys! I will be ordering soon! And Jelly you're right, Lake Worth is in Florida. I ended up with a cali model because my uncle's brother in law is the VP of the dealership I bought it from, and the last ninja 300's he was getting for the year were cali models which is what I ended up getting.
Cali model emissions stuff.. inbox526 2008 - 2012 Ninja 250R Tech Talk 26 September 13th, 2014 12:59 PM
How to remove stock exhaust and install aftermarket Slip-On Exhaust System Ninja 300 SON1C 2013 - 2017 Ninja 300 Tech Talk 4 August 14th, 2014 05:45 PM
Slip on exhaust on Fuel injected model loz944 2008 - 2012 Ninja 250R Tech Talk 6 January 24th, 2012 03:36 PM
Cali model in Louisiana?!?! jdoucet93 General Motorcycling Discussion 15 September 2nd, 2011 08:08 PM
Cali Model CrzyFstMnM General Motorcycling Discussion 1 March 18th, 2009 11:18 PM
