Old August 7th, 2013, 02:04 PM   #1
GHill762
GHill762's Avatar
Motorcycle(s): ZX-3R (ok, ex300)
new tires, unstable?
upgraded the IRC's on my 300 to pirelli DR2's in 150/60 and 120/60.. at the same time had the steering bearing replaced. now, I find that at in-town speeds, it's hard to hold a straight line (cruising down a straight road). Is it because these new tires are so much more round (old tires had a squared off center)? or did they mess something up during install (forks out of alignment, overtightened axles, etc)?
did anyone else notice this when going to a DR2 in 120 & 150? driving straight it feels like trying to stand on a bowling ball, or stacking marbles.. like it doesn't want to stay perfectly upright, it shifts back and forth (very slightly, but enough to be annoying).. if it's just the tires, I'm sure I'll have a nice squared off center again in no time, but if they boogered something up I want to make it right..
Thanks,
Garrett
GHill762 is offline   Reply With Quote
Old August 7th, 2013, 02:09 PM   #2
tooblekain
tooblekain's Avatar
Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike)
Thanks,
Garrett
Its your steering bearings...They were tightened it down way too tight. I had the same thing happen trackside and had the exact feelings you described. It was like fighting the bike to just not crash. Tighteing down the steering bearings is tricky. It can't be too loose or too tight. I spent my whole trackday trying to fix this problem. Too loose and under brarking the front end would shake violently back and forth.
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear
tooblekain is offline   Reply With Quote
Old August 7th, 2013, 02:15 PM   #3
GHill762
GHill762's Avatar
I don't get any front end wobble, shaking, etc.. the front end is VERY smooth now with the tapered roller bearings.. it's more of a balance issue during in-town cruising.. like the whole bike wants to lean rather than stay perfectly upright (this is very minor, but annoying).. when I let go of the bars there is no wobble or shake at all (like there was prior to the bearing replacement)..
but you're saying it's the bearings cranked too tight? is it not allowing the bike to cope with changes in the road? what do I do to correct this? do I just loosen the center steering stem nut?
Old August 7th, 2013, 02:22 PM   #4
GHill762
GHill762's Avatar
If I am looking at the manual correctly, it looks like 15 ft-lbs torque on the steering head nut. with tapered roller bearins, will that change? do I just need to play with it until it feels good?
Old August 7th, 2013, 02:24 PM   #5
tooblekain
tooblekain's Avatar
Im not going to completely rule out the possibility of it being too tight. You need to loosen the nut where you need spanner wrench a tad. You might have to remove your top triple to access it.
Maybe check for wheel balance. Might want to check wheel alignment with each other too. Make sure your chain tensioners are equidistant on both sides and that you have proper chain tension.
Old August 7th, 2013, 02:25 PM   #6
tooblekain
tooblekain's Avatar
That torque value may be different now with tapered roller bearings. I know for the steering stem and head bearings, its about getting it not too loose or too tight. That's for all bikes across the board.
Old August 7th, 2013, 02:28 PM   #7
GHill762
GHill762's Avatar
could you elaborate on the section I bolded/underlined?
wheel balance would cause vibration issues right? it's not vibrating, it's super smooth..
my chain is perfect now, they had it too tight from the dealer, but I adjusted it and changed to a 15t front so rear wheel has been completely re-aligned..
I'll have to check wheel alignment (to each other).. not sure on that one..
Old August 7th, 2013, 02:36 PM   #8
tooblekain
tooblekain's Avatar
THis is going off knowledge based on my Ninja 250, so Im not sure if the steering stem nuts are the same for the 300
Wheel balance can cause "speed wobbles"...on the track you may feel a wobble at certain speeds and then goes away if outside of the speed wobble parameters. You can double check your wheel balance by taking them off and using a static balancer to see if it's perfectly balance. A perfect balanced wheel will stay put not matter what orientation the wheel is on.
When you adjusted your chain did you make sure that both chain adjusters on each side of the swingarm are equidistant?
The best way to check for wheel alignment is the string method.
Old August 7th, 2013, 02:51 PM   #9
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Can you currently(not when you were 10 years old) ride a bicycle with no hands smoothly?
Old August 7th, 2013, 02:55 PM   #10
krolinked
Nerd
krolinked's Avatar
Sounds like your just getting used to the new tires. Also they are much rounder since they are new, it feels like riding on a groove right? And your either on one side or the other of the groove but never perfectly on it.
Old August 7th, 2013, 03:04 PM   #11
Sounds like the steering head bearing are too tight to me too.
I've heard similar comments from others that have replaced the ball bearings with tapered bearings, and found they over-tightened them.
It's not the top nut, it's the collar under the top triple that you need to loosen - if that is the problem.
Old August 7th, 2013, 03:08 PM   #12
if you wanna go straight, buy a harley!
Old August 7th, 2013, 04:48 PM   #13
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
I haven't seen a straight Harley rider on years.
Old August 7th, 2013, 05:22 PM   #14
GHill762
GHill762's Avatar
I THINK this is all it is, since it's getting better not worse. And it's very faint anyway. If it continues after another couple hundred miles I'll look into it more.
Old August 7th, 2013, 05:24 PM   #15
GHill762
GHill762's Avatar
Thanks, if it continues after a couple hundred more miles I'll give this a try.
Old August 7th, 2013, 05:26 PM   #16
GHill762
GHill762's Avatar
Lol I don't WANT to go straight but I can't zig zag to work
Thanks everyone for the help. I think it's just new, very round tires.. We'll see.
Thanks,
Garrett
[kropotkin thinks...] - 2012 Le Mans Moto2 Qualifying Practice Result: Unstable Weath Ninjette Newsbot Motorcycling News 0 May 19th, 2012 07:50 AM
Unstable Idle Questions? setasai 2008 - 2012 Ninja 250R Tech Talk 17 June 14th, 2011 09:34 PM
[crash.net - MotoGP] - Hayden still fighting 'unstable' Ducati Ninjette Newsbot Motorcycling News 0 February 7th, 2009 03:00 PM
[crash.net - MotoGP] - Hayden bemoans 'unstable' Ducati Ninjette Newsbot Motorcycling News 0 February 7th, 2009 03:00 PM
[crash.net - WSBK] - 'Unstable' Neukirchner confident for races. Ninjette Newsbot Motorcycling News 0 August 3rd, 2008 07:03 AM
