Old September 13th, 2012, 03:01 AM   #1
tac12345
Motorcycle(s): Ninja 250r 09 SE
aftermarket front master cylinder??
is there a direct replacement for the front master cylinder?
i'm looking for a better one than the stock one.
tac12345 is offline   Reply With Quote
Old September 13th, 2012, 05:00 AM   #2
dubojr1
dubojr1's Avatar
What's wrong with the stock one? The lil ninjette has more braking capability than it needs already.
Old November 19th, 2012, 06:45 PM   #3
Galaxieman
Galaxieman's Avatar
Motorcycle(s): 2008 Ninja 250, 2009 Concours 14
While the Ninjette has brakes that are quite capable, I wouldn't go so far as to say it has more than it needs. Will it lock up the front tire? Yes. Is the feel and modulation capability of the stock MC somewhat 'meh'? Also a yes. Of course if you're still learning to ride, I'd stick with the stocker... you have to be really ham-fisted to over-squeeze it, which generally helps a newb rider not bin it during a panic stop. However, for someone who's used to significantly better brakes, the stock brakes do leave something to be desired.
I've seen a couple of threads around about upgrades, I was able to get a 2002 Honda Superhawk MC to fit without significant heartburn. Pretty much any MC from a bike with dual-disc front brakes will be a huge upgrade in stopping power since it will have been designed to push enough fluid to activate 2 calipers, usually larger than the one on the Ninjette. Since brake fluid is incompressible, this equates to much higher pressure in the system with much less lever pull. You just need one that will clear the right-hand grip group (throttle housing, killswitch, etc) and has the same banjo bolt thread size / location as the stocker and you're in business.
Igitur qui desiderat pacem, praeparat bellum...
Galaxieman is offline   Reply With Quote
Old November 19th, 2012, 08:50 PM   #4
r6boater
Motorcycle(s): '04 R1 and '08 Ninja 250
try putting on Stainless Braided lines and some Vesrah pads. That set up will not disappoint you.
Check out this Ninja 250 roadracing youth---> TheDraik77 <--- My son
r6boater is offline   Reply With Quote
Old November 25th, 2012, 01:03 PM   #5
Dmj_88
Motorcycle(s): Many
My buddies has an r6 master made by brembo 16x18 works pretty well. The stocker on my Husqvarna 510 sm is wicked for a single disk but also very expensive oem replacement.
Dmj_88 is offline   Reply With Quote
Aftermarket Master Cylinder krolinked Ninjettes At Speed 11 October 15th, 2014 07:12 AM
Front brake master cylinder ninjagaiden09 2008 - 2012 Ninja 250R Tech Talk 7 April 22nd, 2014 08:51 AM
Front Master Cylinder Size FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 3 August 14th, 2013 02:38 PM
front brake issues. master cylinder? Solunatic 1986 - 2007 Ninja 250R Tech Talk 13 June 25th, 2012 11:34 AM
front master cylinder wanted 03slime250 Items Wanted 4 July 14th, 2011 09:56 AM
