Old September 17th, 2014, 05:52 PM   #1
Cereal
Motorcycle(s): 2009 ninja 250r
Oil in my airbox
I have oil leaking from the air box on my 2009 ninja 250. Could the cause of this be because I over filled the oil?
Cereal is offline   Reply With Quote
Old September 17th, 2014, 06:00 PM   #2
cuong-nutz
cuong-nutz's Avatar
Welcome to the forum! Spend some time and create an introduction thread and tell us about yourself and bike!
Cause for oil in the airbox:
1. overfilling the crankcase.
2. you lowsided your bike or tipped it over.
3. you overoiled your stock air filter.
The airbox drain is located on the left side just above the front sprocket. It's there for a reason since the bike is leaned over on the kickstand side and oil settles to that side.
HalfFast Racing Team
Old September 17th, 2014, 06:03 PM   #3
Cereal
Thank you, I will do that. But can this be harmful to my bike?
Old September 17th, 2014, 06:08 PM   #4
cuong-nutz
cuong-nutz's Avatar
Overfilling the crankcase is overtime. Just drain some out and you'll be good. Also, drain the airbox too and wring out the the excess oil on the air filter. Make sure you are checking the oil height with the bike standing upright and not on it's kickstand. Bike has to be perpendicular to the ground to get an accurate reading on the sight glass. If you started the bike and just turned it off, wait a few minutes for the oil to setting back down into the crankcase and measure. Otherwise you will just end up overfilling again.
Old September 17th, 2014, 06:30 PM   #5
xorbe
xorbe's Avatar
There's a tube hooked up to the airbox drain right? The tube is manually plugged at the end, is that normal? (Used bike.)
Old September 17th, 2014, 06:38 PM   #6
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
yep
Old September 18th, 2014, 07:54 AM   #7
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
you can get some oil there if you are doing wheelies as well
'08+ Airbox Countersteer Motorcycle-related 0 June 10th, 2012 12:50 PM
Oil leaking out of airbox bike wont run properly peeweecollins General Motorcycling Discussion 18 July 9th, 2011 10:05 PM
Oil rapidly filling airbox, won't run without choke. 44chart 1986 - 2007 Ninja 250R Tech Talk 21 March 28th, 2011 09:13 PM
1993 250 gas/oil mix sprayed into airbox? th3cavalry 1986 - 2007 Ninja 250R Tech Talk 11 October 28th, 2010 05:34 PM
[webbikeworld.com] - Substitute Ducati Oil Filters - Changing the Multistrada Oil and Ninjette Newsbot Motorcycling News 0 October 26th, 2008 05:10 PM
