March 26th, 2010, 02:21 PM | #1 |
Lowering the front - dangerous?
Seeing the 250R beside super sports, I noticed how considerably higher are handlebars are. So I am contemplating lowering the front of the bike. What kind of issues/dangers am I putting myself into by doing that... aside from possibly having the wheel cover hit the front cowling, and reduced ground clearance?
March 26th, 2010, 02:39 PM | #2 |
Two things come to mind for me, there's certainly more.
1) You'll need to bag some clipons if you want to go more than just a tiny bit down; the handlebar mounts will stop the forks from coming up much further than they are stock. 2) The handling of the bike will change. I seem to remember it'll fall into turns even faster, but be a bit twitchier in straight lines.
March 26th, 2010, 02:58 PM | #3 |
I'm lovin' it.
Join Date: Feb 2009 Motorcycle(s): '09 Black 250R Posts: A lot.
PM Zartan or Kkim, they both lowered their front. Zartan for height issues, Kkim for handling purposes.
Heres the link, Zartan's DIY: Lowering the front
Son: When I grow up I want to ride a motorbike. Father: You can't do both son. |
March 26th, 2010, 03:44 PM | #4 | |
2) Because supersports have lower handlebars, do they fall into turns faster than our bikes? |
March 26th, 2010, 04:12 PM | #5 |
The net result of lowering only the front end will be quicker feeling steering. I lowered mine 1" over what it was stock and have no interference problems with the fender hitting the under nose cowling.
You should be doing this mod for a quicker turning bike, not for how it looks next to a SS bike. The bike will steer quicker in turns... almost effortlessly. I expected more straight line instability or twitchyness, but never encountered it after lowering the front. |
March 26th, 2010, 04:16 PM | #6 |
March 26th, 2010, 04:44 PM | #7 | |
the suspension geometry and ergonomics for the 250R were designed for a "standard" riding position... very upright with handlebars high and footpegs forward for a comfortable, easy to ride position. The SS bikes usually have a steeper head angle for quicker turning and the seat/bar/peg relation is much more designed to put the rider forward, over the front wheel and raising the pegs, for maximum cornering ground clearance. By lowering the forks you are quickening the steering. By adding the clipons, you move the rider forward... closer to the front of the bike. So yeah, I guess it makes it closer to a SS designed bike. |
DIY: Lowering the front end. Raising the Forks | zartan | 2008 - 2012 Ninja 250R Tech Talk | 102 | September 10th, 2021 05:55 PM |
Clipons for lowering front forks instead of risers | gptoyz | 2013 - 2017 Ninja 300 Tech Talk | 19 | August 7th, 2014 05:44 PM |
Lowering Front-end question | Justanothermp5 | 2008 - 2012 Ninja 250R Tech Talk | 4 | September 27th, 2010 02:59 PM |
Front end lowering kit for sale?? | stealth250 | 2008 - 2012 Ninja 250R Tech Talk | 6 | June 21st, 2009 07:44 PM |
lowering set for front and rear | ninjablk08 | Items Wanted | 0 | March 4th, 2009 08:27 PM |
