Old May 21st, 2011, 10:18 PM   #1
crazymater91
crazymater91's Avatar
Motorcycle(s): 1994 kawasaki ninja 250
what is this hole for?????
Its on the left side as your sitting on the bike I seam to have a bit of oil coming out of it
crazymater91 is offline   Reply With Quote
Old May 22nd, 2011, 08:02 AM   #2
Snake
Snake's Avatar
I could not find it in the Service Manual but it looks like it could be a freeze plug which seems odd that oil would be coming out. Check the radiator to see if oil is getting into the cooling fluid.
Old May 22nd, 2011, 08:13 AM   #3
greg737
Motorcycle(s): -
Just at a glance I think it's one of two drain holes (one on either side of the head) for the spark plugs. Remember that the spark plug holes are very deep in the engine's head.
Old May 23rd, 2011, 07:25 AM   #4
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
It's the spark plug recess drain. There's only one, on that (the down-hill side when parked on the side stand) side of the motor, there's a hole connecting the two plug recesses together. If you've got oil leaking from there it means one of your valve cover gaskets is out of place or damaged.
Old May 23rd, 2011, 02:47 PM   #5
Snake
Snake's Avatar
Thanks Frugal, I did not know that. I guessed wrong.
Old May 25th, 2011, 10:35 PM   #6
crazymater91
Thanks guys makes sense it got a little worse after I did a valve job
Old May 30th, 2011, 12:22 PM   #7
Archerzz
Motorcycle(s): 2007 Ninja 250r
Sorry to hijak this thread a bit, but since it has been resolved it seems like a good time to ask a related question. When I was washing my bike today I noticed that there was basically dirt crammed in that hole I cleaned it out and it looks clear, so should everything be fine or is this an issue?
Archerzz is offline   Reply With Quote
Old May 30th, 2011, 12:33 PM   #8
headshrink
headshrink's Avatar
I have a new-gen, which doesn't have this hole, but I assume you are better now that it is clear, than you were when it was clogged with dirt. You basically unclogged the drain.... that's a good thing.
Old May 30th, 2011, 12:58 PM   #9
Archerzz
Yea thats what I figured just bought the bike used a few weeks ago and noticed today that I have accumulated a whole lot of bugs on the front facing parts of my bike =P during the waxing I noticed that the hole was just brown like mud had gotten in so I sprayed and scraped it out, came out relatively easy.
Old May 30th, 2011, 06:28 PM   #10
greg737
Motorcycle(s): -
Every so often you'll see a post here on this forum (and the other ninja 250 site) where somebody has a bike that dies every time he rides in the rain. Sometimes the cause is water pooling in the spark plug recess, messing up the ignition system. That drain hole definitely serves a purpose.
Old May 31st, 2011, 03:44 PM   #11
johnjohn
Motorcycle(s): Honda, Buell, Kawasaki, Suzuki, Yamaha
Probably plugged by a mud wasp.
johnjohn is offline   Reply With Quote
[visordown.com] - Hole in one Ninjette Newsbot Motorcycling News 0 April 4th, 2014 05:00 AM
I'm an a**hole... BlueHairSar Pictures 24 February 11th, 2014 07:38 AM
what's this hole for? 05Ninjette89 1986 - 2007 Ninja 250R Tech Talk 4 April 5th, 2013 09:43 AM
What is this hole..?? davenay67 1986 - 2007 Ninja 250R Tech Talk 14 May 3rd, 2012 06:47 AM
Anyone know this hole size? EddieNewYork 2008 - 2012 Ninja 250R Farkles 2 February 7th, 2011 04:02 PM
