Old November 8th, 2016, 02:22 AM   #1
[motorcycle.com] - 2017 Honda X-ADV Preview
A year ago at EICMA, Honda debuted its intriguing City Adventure concept, combining an adventure-bike design with a scooter platform. Today, Honda officially presented the final production version in the 2017 X-ADV. At the moment, the X-ADV has only been announced for Europe and it’s not likely to be brought over to the U.S.
The X-ADV is powered by a 745cc parallel-Twin with a dual-clutch transmission inherited from the NC700/750 series. Honda claims a peak output of 54.0 hp at 6250 rpm, while maximum torque of 50.2 lb-ft. is reached at 4750 rpm.
Rather than using the same frame as the NC series, Honda developed a new tubular-steel chassis to create room for 5.5 gallons of underseat storage space. The 41mm upside-down fork offers spring preload and rebound damping adjustment along with 6.0 inches of travel, while the preload-adjustable Pro-Link rear shock offers 5.9 inches of travel.
Up front, the X-ADV runs on a 17-inch wheel while a 15-inch wheel spins at the back. Both use stainless steel rust-resistant spokes and come wrapped in chunky-looking block-pattern tires. Radial-mount four-piston calipers stop the dual 310mm front rotors, while ABS comes standard as per Euro 4 requirements.
Other features include a five-position adjustable windscreen, all-LED lighting, a CRF450 Rally-style instrument cluster, Africa Twin-style hand guards, and a shot-peened aluminum bash plate.
The 2017 Honda X-ADV will be offered in four color options. Digital Silver Metallic and Matt Bullet Silver are the standard colors, but Honda will also offer a Pearl Glare White with the Africa Twin’s tricolor scheme and a CRF-inspired Victory Red.
2017 Honda X-AdvEngine TypeLiquid-cooled, L2, SOHCDisplacement745ccNo. of Valves4 per cylinderBore x Stroke (mm)77 x 80Compression Ratio10.7:1Max. Power Output54.0 hp at 6,250rpmMax. Torque50.2 lb-ft at 4,750rpmOil Capacity1.1 gallonsCarburationPGM-FIFuel Tank Capacity3.4 gallonsFuel Consumption64.7 mpgStarterElectricBattery Capacity12V-11.2AHACG Output420W @ 5,000rpmClutch TypeWet multiplate Hydraulic Dual clutch (DCT)Transmission Type6-speedFinal DriveChainTypeSteel DiamondDimensions (LxWxH)88.4 in. x 35.8 in. x 54.1 in.Wheelbase62.6 in.Caster Angle27°Trail4.1 in.Seat Height32.2 in.Ground Clearance6.4 in.Kerb Weight524.7 poundsTurning radius9.2 ftFront Suspension41mm upside-down fork with spring preload and rebound damping adjustmentRear SuspensionProlink with rear shock preload adjustmentFront wheel17 inchRear wheel15 inchFront Tire120/70 R17Rear Tire160/60 R15Front BrakesDual four-piston calipers with 310mm discsABS System Type2 ChannelInstrumentsDigitalHeadlightLEDTaillightLED2017 Honda X-ADV Preview appeared first on Motorcycle.com.
Click here for full story...
[motorcycle.com] - 2017 Honda CRF250L Rally Preview Ninjette Newsbot Motorcycling News 0 November 7th, 2016 02:40 PM
[RideApart] - Budget ADV Bike 2017 Honda CRF250L Rally Ninjette Newsbot Motorcycling News 0 November 7th, 2016 01:50 PM
[motorcycle.com] - 2017 Honda CB1100 RS and CB1100 EX Preview Ninjette Newsbot Motorcycling News 0 October 7th, 2016 07:10 AM
[motorcycle.com] - 2017 Honda X-ADV Confirmed for EICMA Ninjette Newsbot Motorcycling News 0 September 15th, 2016 02:10 PM
[motorcycle.com] - Honda Teases X-ADV Scooter Ninjette Newsbot Motorcycling News 0 July 25th, 2016 03:00 PM
