Old August 5th, 2009, 12:22 PM   #1
tlhamon
tlhamon's Avatar
Motorcycle(s): None Yet
Question Run Both Headlights?
I didn't see a DIY anywhere for this, has anyone done this one yet? I'm going to install some halo rings so I figured I would do this too. Seems to me it's as simple as running both lights off of the lowbeam wires and taping off the highbeam only. If no one has done it yet, let me know and I will post pics and instructions.
It's not worth doing if you aren't completely stressed out about it.
tlhamon is offline   Reply With Quote
Old August 5th, 2009, 12:26 PM   #2
Sounds like a cool mod but I am not sure that the generator can handle the load of both high and low beam at the same time.
Old August 5th, 2009, 12:28 PM   #3
tlhamon
tlhamon's Avatar
It should if both lights operate in high beam mode. They do don't they? I never got off of my bike to look.
Old August 5th, 2009, 12:41 PM   #4
DarkNinja52
DarkNinja52's Avatar
Motorcycle(s): Red 09 Ninja 250r aka Sheila (RIP), Red '10 Ninja 250r aka Sasha (Sold), White '13 Ninja 300 (To be Purchased)
they do.. i've checked
i'd like to see this project
DarkNinja52 is offline   Reply With Quote
Old August 5th, 2009, 12:57 PM   #5
ummm... so what 's wrong with just leaving the highbeam light switch in the on position?
you might want to be able to turn off the highbeam someday.
Old August 5th, 2009, 01:22 PM   #6
Broom
Track Junkie
Broom's Avatar
Motorcycle(s): '08 Ninja 250r Track Bike, DR350 commuter, KDX220 woods bike
you might even run across someone who won't pass your inspection
Las Escobas -- Track Bikes Save Lives
JonBroom.com
Broom is offline   Reply With Quote
Old August 5th, 2009, 01:25 PM   #7
DarkNinja52
hmm sounds like some valid points, any other ways it could be done?
Old August 5th, 2009, 02:14 PM   #8
You could wire then into a seperate switch independent of the high/low switch.
Old August 5th, 2009, 02:21 PM   #9
Broom
Track Junkie
Broom's Avatar
i'm confused, are you trying to change your stock light setup, or add additional lights?
JonBroom.com
Old August 5th, 2009, 06:14 PM   #10
CRXTrek
FORMER MOTORCYCLE RIDER
CRXTrek's Avatar
Motorcycle(s): Rode an 08 250r then rode an 08 ZX-6R until i totaled it on 7/10/10
One light will always be brighter than the other...it's the reflector that is different between the bulbs.
CRXTrek is offline   Reply With Quote
Old August 5th, 2009, 06:23 PM   #11
dimeified
Motorcycle(s): '09 Blue 250R
You go ahead and activate both your lights thinking its a cool idea, then get caught in some fog on the way home from a trip. When your staring at a bright white sheet of fog 5 feet in front of you, you can remember it was me that told you not to mod your bike like this. Having the option of only 1 light on low beam is important, it helps keep the road lit, but also minimizes the amount of reflection of fog blinding your sight.
2 thumbs up
dimeified is offline   Reply With Quote
Old August 5th, 2009, 06:36 PM   #12
P1NDLESK1N
P1NDLESK1N's Avatar
Motorcycle(s): 2015 Ninja 300 (Sold), 2016 Z1000
Last time I rode in fog, running my high beam only helped my vision.
Maybe it wasn't thick enough.
P1NDLESK1N is offline   Reply With Quote
Old August 5th, 2009, 07:24 PM   #13
dimeified
From my own experiences in a car, low beams work better for me in fog. I decided to do a quick google and came up with this...
http://www.mto.gov.on.ca/english/saf...s/badfog.shtml
edit: http://bcrider.com/lowtraffic.html <-- this website is specific to motorcycles and concurs with my point.
2 thumbs up
Old August 5th, 2009, 07:40 PM   #14
P1NDLESK1N
P1NDLESK1N's Avatar
Looks like these people are driving in a cloud.
Old August 5th, 2009, 07:45 PM   #15
DarkNinja52
yea i agree with dimeified. cars also have fog lights for these reasons
Old August 5th, 2009, 09:07 PM   #16
Focus Mike
Motorcycle(s): 2009 Blue Ninja 250R
I wouldn't mess with it personally. Wouldn't it also blind oncoming drivers? I don't think its a wise idea.
Focus Mike is offline   Reply With Quote
Old August 6th, 2009, 12:13 AM   #17
Ken08Ninja
Motorcycle(s): 08 Ninja 250R Candy Plasma Blue
Like kkim said both lights are on when you turn on the highbeams, no mod needed.
Ken08Ninja is offline   Reply With Quote
Old August 6th, 2009, 03:36 AM   #18
maglin
maglin's Avatar
Motorcycle(s): what else?
Correct. The only way it could have the same brightness is to experiment with the lenght of the bulbs.
When I had my low beam with xenon bulb and high with alogen (wich is shorter) the light reached at the same distance.
maglin is offline   Reply With Quote
Old August 6th, 2009, 05:11 AM   #19
HKr1
IC2(SW)
HKr1's Avatar
Post them up.
Old August 6th, 2009, 09:25 AM   #20
demp
Motorcycle(s): 2015 V-Star 950 Tourer (Deep Blue)
? Why would anyone want PERMA-High Beams anyways?, personally I like the option to turn them on or off as it suits me oO
demp is offline   Reply With Quote
Old August 6th, 2009, 09:32 AM   #21
DarkNinja52
Im not even sure what the original question/idea was anymore
Old August 6th, 2009, 01:30 PM   #22
HKr1
IC2(SW)
HKr1's Avatar
Thats why I was hoping for instructions
Old August 6th, 2009, 04:37 PM   #23
tlhamon
tlhamon's Avatar
At some point people stopped understanding my original intent - Modify the lights so that both lights are on at all times, NOT highbeams at all times. The modification looks to be quite simple; just using the low beam wire for both lights. The relay switches the low beam light to high beam and simply shuts off the high beam in low beam mode. So, just tape off the high beam wire. The switch will server the same function, just that both lights will always function.
Old August 6th, 2009, 04:40 PM   #24
HKr1
IC2(SW)
HKr1's Avatar
^ But you have a high beam bulb & a low beam bulb, there not dual filments like an H-4.
Old August 6th, 2009, 06:16 PM   #25
CRXTrek
CRXTrek's Avatar
the bulbs are both 55 watt,it's the reflectors behind the bulbs that make one seem brighter than the other
Old August 6th, 2009, 06:45 PM   #26
DarkNinja52
interesting, i just want to see the halo rings when your done, is there a DIY for this or are you doing that also?
Old August 6th, 2009, 07:20 PM   #27
Ken08Ninja
You can buy HID projectors with angel eyes from F-Sane on Kawiforums. Then you will have two lights on all the time and when you switch to high beam a flap moves to increase the light output.
It is not cheap and it requires slot of modifications to the headlight housing but the light output is amazing.
Posted via Mobile Device
Headlights ChaoSS 2008 - 2012 Ninja 250R Tech Talk 20 June 14th, 2016 08:14 PM
Adjusting headlights? uKER 2013 - 2017 Ninja 300 Tech Talk 2 July 8th, 2013 07:50 PM
LED Headlights TnNinjaGirl 2008 - 2012 Ninja 250R Farkles 39 July 31st, 2012 04:42 AM
HID headlights eddiekay 2008 - 2012 Ninja 250R Farkles 86 October 24th, 2011 04:52 PM
Ninja-Headlights AyMarcus New Members 13 September 21st, 2011 07:24 PM
