January 13th, 2010, 10:29 PM | #81 |
self wrencher
Remove one of the throttle cable (push) and that'll help with binding. One cable is fine.
Posted via Mobile Device Last futzed with by randomwalk101; January 14th, 2010 at 04:24 PM. |
January 14th, 2010, 02:24 PM | #82 |
You are sleeping
Added another needle shim. Now the bike will make it to 8k, but it's a little stuttery. lol
No way around that main jet. Gonna wait until all this carb tuning is done before I try the try the throttle mod again just so I don't have to worry about it for now. I put the stock throttle assembly back together until next time. I will try it again though, it will be good for making sure you have the throttle all the way open for wheelies. I can tell the idle mixture and sync need to be adjusted. (Slight idle hang and lil funny idle) and When I finish the jets have to do it for sure. I finally spent the $30 for the milwuakee offset driver. I don't know how I'll tune idle mixture without it when the shogun sliders are in the way. Yeah I know the gold shims are probably no good to have in there but they're coming out within a week max. |
January 15th, 2010, 06:17 AM | #83 |
You are sleeping
Instead of putting my brake line install pictures here..
I noticed Ninjette.org could use a Brake Bleeding and steel braided hose tutorial so posted my brake upgrade here. http://www.ninjette.org/forums/showthread.php?t=35947 It's half way done with the rear brake line installed and tested. When I get my EBC HH pads in (maybe today) I will finish the tutorial with the front brake line and pads. Once done with the front line and tutorial I will return to my 2010 mod thread here to finish up my bike mods. =) Thanks for stopping in folks. Having fun modifying my lil 250R. |
January 17th, 2010, 09:23 PM | #84 |
You are sleeping
I got lucky and Factory Pro shipped quick!
Had the jets and new needles in place in time to make the GMR ride on the 16th. (yesterday) Didn't get to adjust the float height, idle mixture or carb sync yet because I was running out of time! Really cut it close there like a scene out of one of those bike building shows That was a fun learning experience. Can't wait until I have some free time to tune it! Got my "MOS" in the mail the other day too! Here's some carb porn. Sexy naked bike (yep, adding coolant is on my list.. I see it, I see it! lol) New MOS and my right angle driver. Both excellent on this bike in different ways! That skill brand lithium driver is an exceptional tool as well and extremely strong for it's size. Fits the MOS.. Oh baby! My first self installed jet kit. new 110 jets old jet and carrier New jet reinstalled marked so I don't forget other side You could say I have a short memory Needles and new sexy allen cap heads! Don't forget to grab your ball drivers! Current Shim position = 2 clips and 3 washers No tears in my boots! Dig the new heardware My ball head driver is pointing to the carb sync screw in this pic, highlighted in yellow paint marker by the factory QC man. Will be playing with that soon. Carbs back in place Air filter back on and bike running again! Must have done something right! Made sure to test ride it for a bit at different speeds to check that everything was working right. The bike now pulls awesome to 13K easy, but haven't tried to bounce off my rev limiter yet (I never do that) Then I gave her a bath before the ride on Saturday because she looked all dirty like this.. |
January 24th, 2010, 10:24 AM | #85 |
You are sleeping
OK making a little progress last night and today. Also did a lot of reading on here, the service manual and the factory pro tuning sheet to put two and two together. Thank goodness for directions and this site.
I noticed riding it around yesterday from a weeks sit in the cold that it took forever to warm it up. Also, some hesitation/bog down around 3-5k and also less "umph" around 5-8k. Reminiscent of the stock lean bike. That's OK, we know how to fix that. I could now also feel the transitions between the pilot jets, needles and main jets while accelerating. Pretty cool, but the throttle is not smooth. (akin to hitting v-tech once you get to higher RPM). Since the bike pulls like a bat out of hell above 8k, I'll assume the main jets are good. (still have to read the plugs) I'm going to go to the fourth needle clip position to try and get some of my pull back in the mid range and smooth out the transitions between the mixes. Will report how it feels on the fourth clip, then I'll go back to messing with idle mix and sync. (hopefully, if position four is right) I gotta dig up a couple solid bottles with some rubber caps and some tubing.. (In the carb again)
<Yeah, it's a 250. LMFAO! Weaksauce |
January 24th, 2010, 02:58 PM | #86 |
You are sleeping
4th needle clip position from the top and I no longer notice the transition between power bands. Much less noticeable and much more of a blended feel between 5-8k and 8-13k. Fires right up too and warms up quick.
I seems to have lost a slight amount of top end between 8-13K while improving the mid range and transition. Interesting response! Carb tuning is crazy. I also spent the majority of the day teaching myself how to adjust the mixture screws. It was quite frustrating until I took a lunch break realized two things. 1) Don't let the bike get too hot while your adjusting it cause it'll start doing funny things and you'll falsely adjust the mix screw and 2) Instead of going by blips and by ear right off the bat, try 2.5 turns out on both screws and go from there. I started by just turning the screw in until the throttle died off and then backing it out some but that put me at .75 turns out on the right screw and 1.75 turns out on the left screw. This led me to drop my idle speed, in turn making it further harder to adjust the mixture and the bike was running like crap. I started to get worried and took that lunch break to calm down. What I had to do was set both mixture screws to 2.5 turns out, at which point my idle speed increased slightly, and I dropped it back down with the idle speed knob. Now the whole thing sounds perfectly smooth, does not dip below 1400-1500rpm when blipping throttle, does not hang from 3000 to 1500 for more than 2.5 seconds and just all around runs much smoother! Smoothest since I got it maybe?! I guess everyone is going to have their own trick to that. Now that I have figured out a mixture screw trick that works for me, I can play with it from there. I do notice low end hesitation is less now with better adjusted mixture screws. Even though it sounded perfect after fixing the idle mixture screws, I'll get to work on the vacuum bottle sync tool for further fine tuning. She's running pretty smooth now and if I synchronize the carb now it will only get better!
January 24th, 2010, 06:25 PM | #87 |
You are sleeping
Well today started with an "Oh crap I hope I can figure this out" and seems to be ending with a "That was awesome, I learned myself how to tune my carbs!"
After the idle mixture success above I went about making another gatorade bottle tool for the bike. This time a carb syncer! Man I really hit the nail on the head this time! The bike is running so smooth! I use smooth to explain it because once tuned it really is physically vibrating less and shifting easier! I have it running now much better than the first day I brought it home from the Kawi dealer, for sure! I wouldn't sell it for more than I paid because I'd have to buy a new one and put all this awesome work back into it again. That's awesome! Couldn't have done it without all the info here. Thanks a million guys! Need to drill them slides and adjust the floats next time but it's running tip top shape right now so might leave it! I even have video for you to listen to the bike below. Here's the rundown of what I did next.. Bike had 1800 after the idle mix adjustment.. So I rigged up some gatorade bottles and plugged them to the vacuum lines.. When I fired it up all the oil was running to one side (as I suspected) So I made a holder for the bottles to hang off my shogun sliders while I adjusted the sync. I got my right angle 1/4" ratchet driver with a #2 phillips bit and carefully reached back and adjusted the sync screw a very small amount Until all the bubbles in the tube stopped moving and the idle became extremely smooth! (pic of bubbles in tube not moving) Then I set the gatorade carb syncer next to the gatorade brake bleeder buddy slapped the plastics back on because I could tell it was perfect just from the idle sound of all the changes I made. Purring like a kitten! ..and took her out for a test drive before tomorrows' storm comes in! Man she was running perfect! Video below! Listen to her scream! You can also hear the rock steady idle at the beginning. That first acceleration run was 0-80mph! I feel great knowing how to make my bike run like that! Not only does it get up and go but it cruises smoothly too. this lil 250R is badayuss!
January 25th, 2010, 11:02 AM | #88 |
Join Date: May 2009 Motorcycle(s): 2009 Ninja 250 (sold) Posts: 755
Man thats awesome! I wish I had the cajones to work on my carbs. My bike is running way too lean, I got to slip the clutch excessively just to get the thing moving.
Is that screaming noise I hear coming from the airbox deletion?
The Ninjette is not a disposable bike. You are not ever supposed to get rid of it. It is like a [friendly] herpes virus.... once you got it, you get keep it forever. Originally posted by-Headshrink |
January 25th, 2010, 05:27 PM | #89 |
You are sleeping
I'm not sure.. what noise do you mean. Give me a time in the video at which the noise occurs and I'll do my best to figure out what it is.
She's running pretty good right now but I'd sure like to get an air fuel reading on a dyno so I could know how well it's tuned. Something makes me thing the needle might be able to be shimmed more?! Sounds crazy to me though. I dunno. lol Other than that zero complaints. Just seems like the mid range could kick it up another slight notch to me. Top end is screaming! Got some videos from today I'll put in the ride report section later.
January 25th, 2010, 06:05 PM | #90 |
Im talking when the tone changes as you get up in the higher rpm. Mine makes an audible difference in tone at around 7-11k rpm, but its not as drastic as yours sounds in the video.
January 25th, 2010, 06:30 PM | #91 |
You are sleeping
Ah yes,
That's the combination of the K&N R-0990 filter and the new Factory Pro 110 main jets. I think (from what I Read?) only things in effect at wide open throttle past 7-8k are the main jet, intake and exhaust. Wait till I get another wheelie video. You'll see what I mean. hehe It's really not that hard to dingle with your carbs. Just take your time and study where everything goes and use proper assembly/adjustment techniques. If you gotta force something, you're probably doing it wrong. Take a break and try later.
<Yeah, it's a 250. LMFAO! Weaksauce Last futzed with by ninja250; January 25th, 2010 at 07:44 PM. |
February 5th, 2010, 12:18 AM | #92 |
Join Date: Aug 2009 Motorcycle(s): 2009 Ninja 250R Posts: 26
How much would you charge to come up to the Bay Area and give me a a week's worth of tune-up lessons? ****. I just wish I had that kind of time these days, and money for that matter, and balls. Excellent work.
February 5th, 2010, 05:52 AM | #93 |
You are sleeping
All just a matter of time reading the info here on this site and applying what I learned on my bike. Little bit of mechanical common sense helps too.
I've owned and messed with a few motorcycles myself before anyways along with tons of other electro-mechanical devices so this kind of thing is my niche. I love the bay area. Lived there for a few years in Alameda on the island overlooking-looking out to San Francisco. I could almost be convinced for a visit for the gas money and a place to sleep alone, as long as I get to ride Redwood Road and the Oakland/Moraga hills at least once an afternoon Just kidding. I used to work in the Berkeley hills at the lab and had to drive up Fish Ranch Road every morning to go to work. You don't know what you have until it's gone! I have actually been trying to get a hold of an old buddy up there to let me crash on his couch for a weekend so I can come visit and ride some of my favorite roads on the lil 250R. Kinda depressing going back up there now though that I have nowhere to go when I get there and have to turn around and come home again after driving some of my favorite roads. Would make for a hell of a ride report though. Anyways, still tons more work being done to my bike. It's in pieces as I type this for a bunch more mods. lol Will be trying to get to some of those tonight. Can't wait for summer. I'm gonna take this bike all over California. I know this whole state inside and out.
February 5th, 2010, 09:48 AM | #94 |
Join Date: May 2009 Motorcycle(s): '09 Kawasaki N-250 + '09 Vulcan 900 Classic Lt Posts: A lot.
Reading your post and all the upgrades... video post was great at the end to hear the final results of your work. Excellent if I do say so myself! Great Job Would you come out here and do mine?
February 5th, 2010, 01:43 PM | #95 |
You are sleeping
Sounds like I might have to open my garage for business and go get my bike mechanics certification really quick.
You guys just gotta get the cajones to tinker with your bikes. It's not that bad. Most of it anyways.. If you break something you can always just replace it or take it to a mechanic and have him fix what you broke. Just be sure you don't ignore any broken, "bodged" or incorrectly assembled stuff cause it could cost you your life! I worked on remote control helicopters for a long time and if one tiny thing goes wrong on them it could cost you thousands of dollars in a half second. I'm pretty secure in my mechanical abilities after messing around with that type of stuff. I'd trust my mechanical skills with my life. Make sure you can say that about yourself before you go tearing into important things on your bike. If it means marking hoses and wires with tape so you don't forget them and setting all your screws in bins so they don't roll away and get lost, so be it. Do not hurry/rush through working on your bike either. Take your time and make sure every bolt has been done up properly, by the book.
February 5th, 2010, 02:35 PM | #96 |
You are sleeping
Slides drilled
February 5th, 2010, 04:36 PM | #97 |
You are sleeping
Here is what my done and to do list looks like..
__________________________________________ Gear mods/updates: helmet fixed dianese pants dainese back protector bike mods done: removed ca emissions equip installed PCV valve and fuel filter on tank removed kleen air system plugged clean air holes carb sync ports added half chopped fender plate reflectors added disk lock added onboard soft coated cable lock stowable in backpack battery tender garage side wiring and bike side wiring iPhone RAM mount Video/still camera head for RAM mount Shogun frame sliders air box removal breather filter for crank case hole rear right blinker light connector bodged with zipties K&N R-0990 filter and support throttle twist reduction (need to retry, currently removed) factory pro jet kit 3.0 110 main jets, needle clips pos. 4, 3 shims idle mixture adjusted, check again at 3000mi or when new mods done. maybe try 2.75 turns carbs synchronized after latest drilled slides mod.. check again at 3000mi coolant added.. check at 3000mi (goes down quick from doing wheelies, have to check often) oil changed w/ filter at 1600mi, check at 2000mi, change at 2500-3000mi Chain lubed at 2200mi, Lube again at 3000mi.. Chain slack adjusted to 24mm at 2200mi and new cotter pin. check again at 3000mi. Wheel aligned. EBC pads on front installed at 2200 mi. drilled slides #70 .028" and resynced carbs In progress Leaning gauge and gear indicator installation and programming (install shifter switches and finish programming, 80% completed) Hel lines To do: water temp gauge fender elimination In contact with Hel about brake lines.. installation/testing to be done. test/modify red ebay pegs? (I've dragged knee with these but still don't trust them, might do rearsets but dont want to) Float height adjustment light connectors (broke one, ziptied currently) steering stem nut adjust tool Steering Damper Yoshi, carbon, full Pazzo, red Wood craft or ktc clip ons Puig double bubble, red Proton Tires Jacket (must zip to pants)
<Yeah, it's a 250. LMFAO! Weaksauce Last futzed with by ninja250; February 5th, 2010 at 05:43 PM. |
February 5th, 2010, 11:04 PM | #98 | |
http://www.ninjette.org/forums/showthread.php?t=34996
February 8th, 2010, 10:47 AM | #99 |
You are sleeping
This be the one. It's a tricky one to reach.
I believe it's the right rear blinker connector, female side. I broke the prong that holds the male side in. Taught me real quick to go easy on the connector prongs. Will probably order some new ones, once I get to the fender eliminator. Thanks for the offer dude. Will probably do your proton DIY eventually too. Working on saving for that jacket and exhaust right now.
February 8th, 2010, 06:04 PM | #100 |
You are sleeping
Found a few cool pictures on my iphone.
Here is the moment I first laid hands on my bike, rolling it off the dealer lot. I was stoked! It didn't have a single scratch on it yet. Only had 1 mile from the dude who checked it out and made sure it was working right before he helped me load it in the truck. Here was a hat I hit on my way to LA one day. It stuck on the bike wrapped around the rear wheel for like 10 miles and I didn't even know it. When it hit me damn thing nailed my foot pretty good for a hat too! Always happy to be riding with Sidi boots. That one was crazy! I did a little hat dance while pulling the hat out of my back axle.
February 8th, 2010, 09:33 PM | #101 |
Wow, I would've laid a brick when I realized there was a hat wrapped 'round my rear axle. Good story though and definitely another reason to wear real moto boots!
Are you planning to grab a tank pad/grip sometime soon? All that red tank looks kinda nekkid
February 8th, 2010, 10:29 PM | #102 |
You are sleeping
Yeah thanks for the reminder. I've already dulled the shine off the tank!
I'll do that now.
February 9th, 2010, 01:59 AM | #103 |
Haha Might do a wash/wax/polish, see if that helps restore some lustre. Just got finished doing that to all the blue bits of my bike and it looks much better.
February 16th, 2010, 06:07 PM | #104 |
Join Date: Mar 2009 Motorcycle(s): '09 Ninja 250 Black Posts: A lot.
I really love the shogun diy pics. Was wondering what part that we had to cut to make the bar fit. Thanks!
I'm not small, I'm fun sized |
February 20th, 2010, 10:37 PM | #105 |
Black Ninjas
Join Date: Feb 2010 Motorcycle(s): Kawasaki Ninja zx150RR, 250R Posts: 10
congrat. KC, nicely done!!
with open pipe the rpm will pull thru' to 14k. mind telling me what is proton? BB
It is much easier to stop smoking than to recover from stroke. |
February 21st, 2010, 05:19 AM | #106 | ||
You are sleeping
I'll get a better picture soon to show this better. Here is Pauls.. he actually did a nicer cut than I. I'd recommend trying to go about it his way for the cleanest install. I just hacked mine up real quick like a hurried excited little boy. lol http://www.ninjette.org/forums/showp...6&postcount=20 Sorry I missed your post a few days back! Been running around with "my head cut off" lately. lol Quote:
I'm hoping the pipe will bring back a tiny bit of the low end from removing the air box, but who knows. It's running pretty good right now and I just bought a new jacket so the pipe will have to wait a couple more weeks again. I just took it out, dropped the plastic and tune it again yesterday (mixtures and synch) before taking it for a ride and it sounds even better than it did before Starting to get the hang of this lil bike.. tuning wise. Will love it when I put the exhaust on! Here's a great link to the Protons and an excellently assembled DIY how to install them for you! They look sweet huh? http://www.ninjette.org/forums/showthread.php?t=36477
February 21st, 2010, 07:51 AM | #107 |
Black Ninjas
thanks KC,
over here we still have lots of smaller capacity two stroker, we can easily get them from yamaha RXZ, a simple direct swap. BB
March 6th, 2010, 02:54 AM | #108 |
You are sleeping
Well,
Along with upgrading my jacket and helmet yesterday, finally got around to switching to Synthetic. Hopefully this is the right stuff so my clutch doesn't slip all over the place. lol I'll find out today! Wonder if I'll be able to feel the difference. The bike is now rockin' almost 3,500mi. Most (all besides new gloves) of my gear upgrades are done. Time for my exhaust and damper now. Definitely want any type of damper addition I can get on this bike. She gets a lil wobbly when draggin' knees on me. Tires would probably help too. Mine are pretty well worn down after 3500mi of mostly twisties. I figure they'll be replaced at about 5,000mi. Also saw a nice red tank bag and saddle bags I might purchase for longer trips in the future.
March 9th, 2010, 05:15 AM | #109 |
You are sleeping
PRetty sure I could actually feel the Mobile 1 making a smoother difference in how my bike runs.
Now for the new white shogun sliders and new ebay pegs since I dropped it a couple weekends ago.
March 11th, 2010, 03:17 AM | #110 |
no joy
Join Date: Nov 2009 Motorcycle(s): Ninja 2006 636 Posts: 408
Very badass NIN...
Sorry bout that hat- it cracks me up tho- dang tourists! |
Darks 300 mod thread. | Dark | 2013 - 2017 Ninja 300 Farkles | 8 | August 26th, 2013 07:51 AM |
To mod or not to mod, that is the question... | RiderOnTheStorm | General Motorcycling Discussion | 19 | October 29th, 2012 08:21 PM |
I'm going to mod....! | RiderOnTheStorm | 2008 - 2012 Ninja 250R Tech Talk | 6 | October 6th, 2012 03:34 PM |
My Mod thread | gadgetguy1288 | Pictures | 24 | February 9th, 2012 03:21 PM |
First mod. | HMB-ninja | 2008 - 2012 Ninja 250R Farkles | 10 | September 28th, 2009 09:54 AM |
