Old September 18th, 2012, 03:53 PM   #1
Confuzshuz
Motorcycle(s): 2011 ninja 250r
too much oil...oil removal
If I put a little too much oil in the bike, what's the best way to take some out w/o removing the drain plug?
Confuzshuz is offline   Reply With Quote
Old September 18th, 2012, 03:55 PM   #2
how much is a little too much? less than .2l just leave it there
Old September 18th, 2012, 04:12 PM   #3
Reyno2ac
Reyno2ac's Avatar
Motorcycle(s): Red 2009 Ninja 650r
Take a spray bottle nozzle and stick it into the oil fill hole. Squirt the excess oil into a water bottle.
Reyno2ac is offline   Reply With Quote
Old September 18th, 2012, 04:14 PM   #4
bdavison
Wartown, USA
bdavison's Avatar
just pick up bike and pour it out....
Just kidding....
Use a syringe or siphon it out of the filler opening.....DONT drop anything down in there though.
Old September 18th, 2012, 04:20 PM   #5
Confuzshuz
I think I put in about of 2 quarts total.
Old September 18th, 2012, 04:32 PM   #6
Monkeytofu
I told you bro
Monkeytofu's Avatar
Huh, never thought of this. Great idea
Old September 19th, 2012, 05:09 AM   #7
Bob2010
Bob2010's Avatar
Actually it works really well. That's how I have to change my s/c oil in my car every season.
And to the OP. my one bike took 2qts the other 1.75
2010 Red Ninja 250
2009 Black Ninja 250
Old September 19th, 2012, 12:07 PM   #8
GeneJunkie
GeneJunkie's Avatar
I put in almost 2qt and it was overfull and that caused a leak in the stater cover since the pressure causes the liquid seal to fail. Anyways, the guys that helped me I think used a turkey baster to pull out the excess oil or maybe it was a squirt bottle.
GeneJunkie is offline   Reply With Quote
Old September 19th, 2012, 01:19 PM   #9
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Suck it
with a straw
AFM #676
Supersports are for n00bs
Old September 19th, 2012, 10:42 PM   #10
Confuzshuz
I attempted to remove some oil today. It was a lot more work than I thought.
First, I bought a $3 siphon at the auto parts store......it was horrible. I ended up sucking on the end of the siphon to get oil moving (happy @Jiggles ?). Since the oil wasn't too appetizing, I opted to get different siphon/pump mechanism. Back to the autoparts store and spent big money....$13. Got home and it didn't work. The best result was sucking on the $3 siphon, which yielded over a 1/2 cup of oil.
I think I'll leave it alone at this point.
Old September 20th, 2012, 08:12 AM   #11
stealth250
Gearhead
stealth250's Avatar
Seems like you could've just pulled the drain plug for a second and it wouldn't have cost you anything...
stealth250 is offline   Reply With Quote
Old September 20th, 2012, 08:32 AM   #12
Confuzshuz
I know that now. Actually loosening the filter cap was my original plan.
You know the old saying....The shortest distance from one point to another is a straight line.
No more short cuts for me.
Old September 22nd, 2012, 03:26 PM   #13
BearZ
BearZ's Avatar
Motorcycle(s): 2012 Kawasaki Ninja 250R
rather than sucking on the oil, fill the pipe with some leftover oil, assuming you have any left; that will work. You should not be ingesting Motor oil, or getting it anywhere near your face for that matter.
BearZ is offline   Reply With Quote
Old September 22nd, 2012, 04:39 PM   #14
GREY NINJA
Motorcycle(s): 2002 ninja 250
Originally Posted by Jiggles View Post
Suck it
with a straw
LOL
GREY NINJA is offline   Reply With Quote
Is it normal for oil to increase a bit in the crankcase after an oil change? cadd 2008 - 2012 Ninja 250R Tech Talk 10 May 15th, 2014 08:38 PM
5qt. G-Oil Synthetic Motor Oil (5w-30) Free After $26 Rebate setasai Miscellaneous 3 May 25th, 2011 01:59 PM
Could someone create a DIY for oil pan removal? jink 2008 - 2012 Ninja 250R Tech Talk 6 July 2nd, 2009 05:38 PM
[webbikeworld.com] - Substitute Ducati Oil Filters - Changing the Multistrada Oil and Ninjette Newsbot Motorcycling News 0 October 26th, 2008 05:10 PM
