Old December 3rd, 2013, 11:08 AM   #1
mikedabike64
Motorcycle(s): 2008 ninja 250
cam question
hey guys my bike is 14000 miles on it I just got it on a trade not too long ago and so far I redid the fork seals and fork oil. replace the coolant oil filter the chain sprockets, took the carbs off cleaned shimmed the needles which worked great by the way, changed the spark plugs and air filter remove the snorkel, etc.
I have to check the valve clearance and I plan on doing that very soon but I had a question about the cams,
I was thinking since my cans have 14,000 miles on it,
what I be able to replace those cans with newer cams with less miles on it because that probably took quite a beating over time. but for argument sake if they did not fall within the service limit
is that something I would be able to do or are the cams machine for a specific motor much like the head is machined.
I'm just asking if I would be able to buy a newer cams off of say a wrecked bike that might have less where on it and then do the valve clearance adjustment based on the new used cams,
I apologize if it is a stupid question but I think I am more curious than anything else
mikedabike64 is offline   Reply With Quote
Old December 3rd, 2013, 11:17 AM   #2
If it was maintained properly there shouldn't be any reason to replace the cams at that point.
Take a look at the surface of the cams for damage (galling) from lack of oil or the wrong (auto) oil, but chances are they should be fine.
Old December 3rd, 2013, 11:32 AM   #3
don't bother unless there is something wrong with it.
Old December 3rd, 2013, 11:54 AM   #4
mikedabike64
ok thanks guys
I get these stupid ideas in my head and it's nice to have sensible people to kick it around with
Old December 3rd, 2013, 05:51 PM   #5
Originally Posted by mikedabike64 View Post
.......are the cams machine for a specific motor much like the head is machined.
I'm just asking if I would be able to buy a newer cams off of say a wrecked bike that might have less where on it and then do the valve clearance adjustment based on the new used cams.........
No, cams are not machined to match any other part in the engine, you can just replace both camshafts or one, ..... and your question is not stupid either.
That mileage is nothing for one of these engines, if properly used and serviced.
Old December 4th, 2013, 11:26 PM   #6
mikedabike64
ok thanks moto
i thank you for the response
Old December 5th, 2013, 02:35 AM   #7
SteveL
old git
SteveL's Avatar
Motorcycle(s): BMW K1300S
If it works don't fix it.
Steve
Some mistakes are too much fun to make only once.
SteveL is offline   Reply With Quote
cam chain tensioner question bob706 2008 - 2012 Ninja 250R Tech Talk 16 June 21st, 2016 12:09 PM
replacing exhaust cam with intake cam subxero 2008 - 2012 Ninja 250R Tech Talk 2 June 1st, 2014 12:19 PM
So I have a mini HD cam... Stingray1000 Motorcycle Gear 12 June 19th, 2012 07:49 PM
cam timing verandaman 2008 - 2012 Ninja 250R Tech Talk 0 October 12th, 2011 01:27 PM
English 10 Language Question (Very simple question) nickjpass Off-Topic 24 September 16th, 2011 08:28 AM
