September 26th, 2012, 03:09 PM | #1 |
YMCMBillionaire
Join Date: Jul 2012 Motorcycle(s): 2008 Ninja 250R(Wrecked&Gone), 2004 Honda CBR1000RR (Trading back to dealer for 600cc) Posts: 81
Headlight Upgrade etc..
Ok I was wondering I was wanting to upgrade my headlights on the 250 to HID kit. Where could I get a SET for cheap online but good quality and My Ninja 'Elektra' is blue and I want blue ones but not completely blue more like 6k to 8k whiteish blue what size should I get to fit is it H4? H7? Etc? Also nooby question what wattage and amp etc should I get? Any help will be appreciated Cheers!
September 27th, 2012, 09:21 AM | #2 |
cuz
Join Date: Jul 2011 Motorcycle(s): 09 ninja 250r Posts: A lot.
H7
55W I never messed w/the kits, I just bought the bulbs. 100% these will work but hopefully there's somewhere else that's cheaper. http://www.ebay.com/itm/PHILIPS-4000...58c1ce&vxp=mtr http://www.mea.philips.com/c/motorbi...2972bvubw/prd/
THE GOOD LIFE |
September 27th, 2012, 10:20 AM | #4 |
September 27th, 2012, 10:32 AM | #5 |
a projector is a lens with a cutoff that makes it so you don't blind the **** out of the people in front of you when you use hids.
September 27th, 2012, 10:33 AM | #6 |
Join Date: Oct 2009 Motorcycle(s): 09 Ninja 250 Posts: 56
Best option so far for getting a projector installed, instructions are pretty clear and straight forward.
http://bkmoto.com/index.php?route=pr...&product_id=55 Please don't throw in HID bulbs without projectors...wut others have said Last futzed with by nealt; September 27th, 2012 at 12:43 PM. |
September 27th, 2012, 10:46 AM | #7 |
September 27th, 2012, 10:53 AM | #8 |
HID bulbs are not designed for standard reflectors. they make lots of scattered light that goes in all directions. projectors are designed for hid bulbs. do a google search
September 27th, 2012, 11:12 AM | #9 |
Projectors make a clean cut-off line and fill in everything underneath that line with light. You can then control the cut-off thingy with your high beam switch to give you "high" beams.
Basically, you can then control the output of the HID bulb so it doesn't accidentally blind people. |
September 27th, 2012, 09:51 PM | #10 |
cuz
ohh & G Unit!!!
that's all.
THE GOOD LIFE |
To upgrade or not to upgrade... | neldy | General Motorcycling Discussion | 19 | August 29th, 2011 10:21 PM |
Mounting stock headlight and gauges using headlight clamps? | SV_Hadder | 1986 - 2007 Ninja 250R Farkles | 0 | January 17th, 2011 09:15 PM |
Looking to upgrade... | P1NDLESK1N | General Motorcycling Discussion | 12 | June 24th, 2009 11:12 AM |
