January 4th, 2014, 12:31 PM | #1 |
Motorcycle Nurse?
Join Date: Sep 2013 Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100 Posts: 606
Should I adjust my valves or are they good enough?
Exhaust 1,2,3,4-.009",.009",.008",.007"
Intake 1,2,3,4-.008",.007",.007",.007" My feeler gauges went from .007-.008-.009", should I check them with more precise gauges? All of my Intake valves are within spec and close to the middle but my exhaust valves are questionable. This is also my first valve job so the valves may not be measured 100% correctly I'm thinking that they are good enough for now but a second opinion would be nice. |
January 4th, 2014, 12:40 PM | #2 |
here's a good explanation for what the clearance can affect
http://faq.ninja250.org/wiki/What_ar...ance_ranges%3F
January 4th, 2014, 12:47 PM | #3 |
i can't think of what the conversion for inch to mm is right now, but if they are all in spec and it's only the first valve adjust, i would just leave them and button it back up. since they're not all equal just remember to do the next valve check a little early and be prepared to adjust them then. maybe then they will still be the same, maybe they wont. who knows.
January 4th, 2014, 12:52 PM | #4 | |
.008" = 0.2032 mm .009" = 0.2286 mm
January 4th, 2014, 12:59 PM | #5 |
spec: Exhaust: 0.22 mm to 0.29 mm Intake: 0.15 mm to 0.24 mm
Exhaust 1,2,3,4-0.2286 mm, .0.2286 mm, 0.2032 mm, 0.1778 mm Intake 1,2,3,4- 0.2032 mm, 0.1778 mm, 0.1778 mm, 0.1778 mm i would adjust those exhaust. probably prudent to set the .20mm intake down to .17 to match the rest.
January 4th, 2014, 01:24 PM | #6 |
Motorcycle Nurse?
Do you guys know where I can order shims?>
January 4th, 2014, 01:33 PM | #7 |
Motorcycle Nurse?
Also the gasket for the spark plug that goes underneath the cover fell off, how should I get it to stick back on? the other one is stuck to the cover
January 4th, 2014, 01:53 PM | #8 |
I usually order the the sizes in packs you need. Hot cams sells a kit but you won't be using most of the other sizes included. You can find them on amazon or eBay. Cam size are 7.48mm.
January 4th, 2014, 01:56 PM | #9 |
get the hotcams *REFILL* kit, not the entire kit. only order the sizes you want. its only like $20 for the small kit.
you can use moly grease to hold the gasket in. i think i usually keep them on the head instead of the cover but it should be fine either way. just make sure its placed in correctly cause if you tighten it down and the little metal thing isn't seated correctly, you'll bend the metal part and have to order a new one.
January 4th, 2014, 02:50 PM | #10 |
Motorcycle Nurse?
I removed my camshaft chain tensioner and timed the engine but there was slack in the chain that caused the cams to rotate in a weird way. Now the white marks dont match up. Is it ok for me to start disassembling the cams?
I'm at 2T But this is where my cams are, they were lined up before |
January 4th, 2014, 03:49 PM | #11 |
don't turn the engine with the chain and cams in but tensioner out.
if you stick your finger in the hole where the tensioner goes, you can push on the chain guide and put tension on the chain. the cams will rotate back to the correct position. but yes, you can take the cam cage off and remove the cams
January 4th, 2014, 04:03 PM | #12 |
Motorcycle Nurse?
Dang kawiforums
Step 1: remove CCT Step 2: Time engine |
January 4th, 2014, 06:33 PM | #13 |
Why going that far?
We have all you need here: http://www.ninjette.org/forums/showthread.php?t=9924 http://www.ninjette.org/forums/showthread.php?t=9787 http://www.ninjette.org/forums/showthread.php?t=83284 http://www.ninjette.org/forums/showthread.php?t=73240 http://www.theyeagergroup.com/2008_n..._clearance.htm http://faq.ninja250.org/torque/ex250j/ And don't forget replacing your plugs and synchronizing your carbs: http://faq.ninja250.org/wiki/Changin...d#Installation http://www.ninjette.org/forums/showthread.php?t=9754
January 4th, 2014, 09:03 PM | #14 |
Motorcycle Nurse?
Okay, I purchased a "General" brand micrometer and it only goes to 2.XXmm and I am trying to be consistent with the light pressure I apply. Should I be squeezing the hell out of it to pinch the shim though?
My current readings seem good, however two shims ,EX 3&4, read 2.87 and 2.82 consistently. Are these the hard as hell to find .025mm interval shims? Or should I round them down? If they are then I only need to purchase a replacement shim for EX 4 and swap IN 5 with EX 3. @cuong-nutz Do you have a 2.775mm shim by chance? I can only find these in Europe websites. The downtime on my bike is going to be ridiculous |
January 4th, 2014, 09:21 PM | #15 |
Good micrometers should have a ratcheted knob with which to put light and consistent pressure on the part to be measured.
January 4th, 2014, 09:24 PM | #16 |
Motorcycle Nurse?
January 4th, 2014, 09:27 PM | #17 |
Sorry, cannot see the pic.
In any event, don't put too much pressure. If you cannot slide the shim out easily, the pressure is enough. If what you have is one of these, that is a caliper and has no knob, but the same applies about the pressure.
January 7th, 2014, 05:55 AM | #18 |
Board Member
I set the intake on the tight side and the exhaust on the loose side and attempt to match all the numbers as close as possible. This helps with intake lift and exhaust valve cooling.
How to know you need your valves adjusted? | Hero Danny | 2008 - 2012 Ninja 250R Tech Talk | 42 | July 26th, 2014 06:39 PM |
just adjusted Valves. ... | Fakker | 1986 - 2007 Ninja 250R Tech Talk | 7 | July 2nd, 2014 10:28 AM |
Watch first hand in person how to adjust your valves | rojoracing53 | General Motorcycling Discussion | 17 | July 6th, 2013 08:26 PM |
When to clean carbs and Adjust Valves | RandomPhantom | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 10th, 2013 03:58 PM |
valves keep going out of spec. Causes? | Monkeytofu | 1986 - 2007 Ninja 250R Tech Talk | 7 | September 5th, 2012 07:16 PM |
