Old October 28th, 2016, 04:52 PM   #1
[motorcycle.com] - MO Wrenching: Brake Caliper Rebuild
The photo above points out how important properly functioning brakes are to getting the most performance possible out of them. Brakes, however, are instrumental in more than riding quickly. They are necessary for your safety.
Remember, way back in February (in this brake pad replacement article), when I told you to look for uneven wear on brake pads as a sign of sticky caliper pistons? Well, even if no pistons in the calipers are sticking, you should consider rebuilding a caliper if you can’t remove the brake dust deposits from a piston with solvent and a brush during your pad swap. Proper functioning of the brake system depends on pistons that move easily within their bores.
Calipers, no matter how many pistons they have, are broken into two categories: single-action and dual-action. Single-action calipers have pistons that only press from one side of the disc. Dual-action calipers squeeze the disc with pistons from both sides. Rebuilding these two kinds of binders follows exactly the same steps – you just do more on dual-action units.
When using air pressure to push out the pistons, take it easy. A little pressure can provide a lot of piston movement. Keep your fingers clear and use a rag to contain the pistons.
The rebuild starts with pressing the pistons out of the calipers. My preferred method is to drain the system, press the pistons into the bottom of their bores (to force out the brake fluid), and carefully blow the pistons out with compressed air. If you don’t have compressed air, you can use the hydraulic fluid and lever to achieve the same result. Unfortunately, this technique is terribly messy. Be sure to place a container to catch the fluid under the caliper. Follow the same procedures for restraining the pistons described below. And don’t forget latex gloves to protect your skin from the hydraulic fluid.
A piece of wood can keep the pistons from popping completely out of dual-action calipers. Again, apply the pressure slowly to keep the pistons from banging against the board. Note the dust build-up near the top of the pistons. This is where you’re likely to find corrosion.
Begin the rebuild by draining the system and removing the caliper. If you’re leaving the rest of the system on the bike, you’ll want to wrap the line’s fitting with a rag and tape it in place to avoid a mess. Remove the pads, springs, clips, piston insulators, and any other hardware around the caliper’s pistons. It’s easiest to remove pistons from single-action calipers. For a one-piston, single-action caliper, place a rag between the piston and the bracket for the second brake pad. Carefully blow compressed air into the hole for the banjo fitting. Keep the air pressure low and your fingers clear of the piston! If the caliper has more than one piston, you will want to place a piece of wood, as well as the rag, into the caliper. This will keep one piston from popping out and leaving the other deeply recessed in its bore.
Similarly, one-piece, dual-action calipers should have their pistons blown out with a piece of wood in between the sets of pistons. The goal here is that the wood is thin enough to allow the pistons to fully extend, but not pop free. Two-piece, dual-action calipers can sometimes be unbolted, giving you better access to one set of pistons at a time. (Check your service manual before attempting this, as some manufacturers recommend against it.) Since you’d have to fashion a means of controlling the pistons as you blow them out of their bores, I’d recommend treating the calipers like one-piece units until you have the pistons extended.
If a piston is stuck, try removing it with soft jaws and a set of locking pliers. Also, try rotating it in the bore as your attempt to pull it out.
If you’re lucky, you’ll be able to pull the pistons free of their bores with your fingers. If not, use a set of “soft jaws” on a pair of pliers. These plastic covers will keep the metal of the pliers from touching the piston and scratching its surface while still giving you a remarkably strong grip on it.
After the pistons are removed, use a pick to gently pry out the dust covers and inner seals. Be careful not to scratch the piston bores – although this is less vital than with the pistons. (Remember that, in calipers, the sealing rings are mounted in the bores and slide over the smooth surface of the piston.) Thoroughly clean the interior and exterior of the calipers and pistons with brake cleaner or other solvent. If the parts are particularly dirty, soak them for a few hours in parts cleaner. Remove any traces of the solvent and blow the parts dry, making sure that all fluid passages are clear.
Inspect the pistons. If you find any rust or pitting, polish the surface with Scotchbrite until it is perfectly smooth. If the corrosion is too great, replace the piston. Similarly, buff away any pitting in the piston bores, and replace the caliper if you can’t make the interior look like new. Spray the parts with brake cleaner and blow them dry again.
Be careful not to damage the piston bore as you remove the seals.
Although you don’t need to replace the O-ring piston seals unless they’re damaged, why would you go through all this trouble and not replace them? Install fresh seals and the dust seals by applying a coating of fresh brake fluid and slipping them into place. (Note: The dust seal is closest to the bore’s opening.) To avoid damaging the seals, don’t use any tools to install them – just your fingers. Apply a coat of brake fluid to the pistons and slide them all the way into their chambers. If you disassembled the caliper halves, install new O-rings and torque them together to factory specs.
Remove any corrosion with Scotchbrite. If you can’t restore the piston to a polished surface, replace it.
Install any anti-rattle springs, clips, and other parts you removed from the caliper. On single-action calipers, apply a coating of high-temperature, water-resistant grease to the caliper holder shafts and the holder holes. If the boot and dust cover for the shaft is cracked, you should replace it. Now is also a good time to wrap the caliper bleed-valve threads with teflon tape to make bleeding the system easier.
Install fresh pads and bolt the caliper into place. Torque the banjo fitting and its fresh crush washers to factory spec. Bleed the lines, break in the new pads, and you’re done.
[This article was adapted from Evans Brasfield’s book*101 Sportbike Performance Projects. Learn more about it*here. Read the MO review*here.]
MO Wrenching: Brake Caliper Rebuild appeared first on Motorcycle.com.
Click here for full story...
[motorcycle.com] - MO Wrenching: How To Replace Brake Pads Ninjette Newsbot Motorcycling News 0 February 1st, 2016 07:22 AM
Brake Caliper Rebuild Kit Trailerboy531 2008 - 2012 Ninja 250R Tech Talk 31 September 6th, 2015 06:38 PM
Rear Brake Caliper Rebuild aurbz 2008 - 2012 Ninja 250R Tech Talk 6 April 5th, 2015 10:57 AM
Brake caliper rebuild help agentbad 1986 - 2007 Ninja 250R Tech Talk 3 April 6th, 2014 10:24 AM
Caliper rebuild inquiry Momaru 2008 - 2012 Ninja 250R Tech Talk 12 January 13th, 2013 08:31 AM
