Old March 29th, 2014, 12:07 AM   #1
headshrink
headshrink's Avatar
Power Distribution center (make or buy?)
My 250 's wiring looks like a bowl of zip-ties and spaghetti from all the accessories I wired in. I want to install a power distribution center on the new bike, but they aren't cheap. But then again, buying parts at Radio Shack isn't cheap either. Has any one here made one, or have one of the commercially available ones? What's your experience/feedback?
Old March 29th, 2014, 12:17 AM   #2
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
I've done both.
Made one originally from parts at AutoZone. Had no problems at all though originally the connection to the tail light for the relay switch was shorting out and killing the switch. Went several months powering all my gizmos.
Decided after awhile to redo it cleanly as each connection was protected with just a strip of electrical tape. Tore it all apart to add heatshrink to each spade. End result, ****ed that up. LOL
Gave up and bought a Fuzeblock. Opted for that one since it is easy to move from switched to constant power. It was bigger than I thought but still fits between the ECU and battery box. Thinking of moving it up front for easier access and to have the wires not so crimped.
<-- Linky
Old March 29th, 2014, 12:51 AM   #3
headshrink
headshrink's Avatar
Is it cool that the Fuzeblock has no weather protection?
Old March 29th, 2014, 01:55 AM   #4
NevadaWolf
NevadaWolf's Avatar
I haven't run through any rain since I got it and installed the bottom plate as I was intending on velcroing it down, but so far I haven't noticed any issues. I have it under the seat near the battery, so the stock fuse box is only a few inches from it. Figured it was a safe place.
I went with what they said on their site: http://www.fuzeblocks.com/index.php?pid=5#faq35
<-- Linky
Old March 29th, 2014, 04:20 PM   #5
linkinpark9812
Motorcycle(s): Black 2012 Ninja 250R
I bought some very cool waterproof fuse boxes from cycleterminal.com. I've been redoing all of my electrical stuff on my bike to make it cleaner than when I installed it.
http://www.cycleterminal.com/fuse-boxes.html (The first one).
linkinpark9812 is offline   Reply With Quote
Old March 29th, 2014, 05:49 PM   #6
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Jim Davis, owner of Eastern Beaver in Japan makes excellent, high quality,reasonably priced electrical stuff for bikes. Even though he's based in Japan, he delivers the stuff pretty quickly. The BMW bike crowd uses his things.
His fuse block (combines switched and unswitched circuits):
http://www.easternbeaver.com/Main/Wi...PC-8/pc-8.html
I highly recommend his headlight relay kit!
Old March 30th, 2014, 02:42 PM   #7
I've had this on my last two BMW's:
http://www.aerostich.com/aerostich-p...-module-1.html
No fuses involved, completely solid-state. If you have an issue, you fix the problem wherever it is, turn the bike on/off, and you're back up and running.
Old March 30th, 2014, 11:17 PM   #8
headshrink
headshrink's Avatar
Those solid state ones are pretty fancy, but a bit pricy for my tastes. Currently I'm leaning toward the PC-8 &30A Relay Kit from Eastern Beaver. I was going to go with the Denali PowerHub2, but I liked the idea of being able to replace the relay if it went bad.... a little cheaper too (not sure about shipping yet).
Old April 1st, 2014, 07:10 PM   #9
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
One of the best things I've done to the bike. Made adding Fog lights, gauges, chargers easy. Gonna rewire the headlights to it with better wire since stock is pretty thin and the voltage drop is pathetic.
Power Distribution for Peripherals & Pdm 60 antiant General Motorcycling Discussion 16 November 23rd, 2014 09:21 AM
[RoadRUNNER] - Review: PDM-60 Power Distribution Module Ninjette Newsbot Motorcycling News 0 February 25th, 2014 09:30 AM
[roadracingworld.com] - LeoVince USA Opens New Distribution Center In Indianapolis Ninjette Newsbot Motorcycling News 0 April 18th, 2012 11:40 AM
[webbikeworld.com] - Dispatch 1 Power Distribution and Management System Review Ninjette Newsbot Motorcycling News 0 February 6th, 2011 11:51 AM
[roadracingworld.com] - Dunlop Opens New Off-Road Tire Distribution Center In Corona, Ninjette Newsbot Motorcycling News 0 January 26th, 2011 06:40 PM
