Old November 7th, 2017, 10:50 AM   #1
[motorcycle.com] - First Look: 2018 Husqvarna Vitpilen 701
Husqvarna presented the production version of its Vitpilen 701 at EICMA alongside a concept version of its sibling, the Svartpilen 701. We’ll have more on the flat track-inspired Svartpilen 701 in a separate post, but here’s what we know about the “White Arrow” Vitpilen.
The Vitpilen 701 is powered by a 693cc Single derived from the KTM 690 Duke’s powerplant, claiming 73.8 hp at 8500 rpm and 53.1 lb-ft. at 6750 rpm. The engine is matched with a slipper clutch and six speed transmission. The electronic fuel injection is managed by a ride-by-wire throttle control, with traction control as standard.
The engine is mounted to a chromium molybdenum tubular steel frame. WP Suspension supplies the 43mm upside-down fork and linked rear monoshock, both offering 5.3 inches of travel.
The front wheel is equipped with a single 320mm disc and Brembo four-piston radial-mount caliper while the rear wheel has a 240 mm disc with a single-piston caliper also from Brembo. A switchable Bosch 9M+ ABS comes standard.
Other important details include a 32.7-inch seat height, 3.2 gallon fuel tank and a claimed weight (without fuel) of 346 pounds. We’ll have information on U.S. pricing and availability when they became available.
2018 Husqvarna Vitpilen 701 SpecificationsEngine typeSingle cylinder, 4-strokeDisplacement693 ccBore x Stroke105 mm x 80 mmPower73.8 hp at 8500 rpmTorque53.1 lb-ft. at 6750 rpmCompression Ratio12.8:1Starter/BatteryElectric starter/12V 8.6AhTransmission6 gearsFuel systemKeihin EFI (throttle body 50 mm)Control4 V/OHC with intake cam levers and exhaust rocker armLubricationPressure lubrication with 2 oil pumpsEngine oilBel Ray, SAE 10W-50Primary Drive36:79Final Drive16/40CoolingLiquid coolingClutchAPTCTM slipper clutch, hydraulically operatedEngine Management/IgnitionKeihin EMS, double ignitionFrameChromium-Molybdenum-Steel trellis frame, powder coatedSubframeAluminumHandlebarAluminum clip-onFront SuspensionWP-USD Ø 43 mmRear SuspensionWP-Monoshock with linkageSuspension Travel5.3 inches, front and rearFront BrakeBrembo four piston, radial mounted , brake disc Ø 320 mmRear BrakeBrembo single piston, floating caliper, brake disc Ø 240 mmABSBosch 9M+ Two ChannelWheels Front/RearCast aluminium wheels 3.50 x 17”; 5.00 x 17”Tires Front/RearBridgestone Battlax 120/70 R 17; 160/60 R 17ChainX-Ring 5/8 x 1/4″SilencerStainless steel primary and secondary silencerSteering Head angle65°Triple Clamp Offset1.1 inchesTrail4.3 inchesWheelbase56.5 in. +/- 0.6 in.Ground Clearance5.5 in.Seat Height32.7 in.Tank Capacity (approx.)3.2 gallonsWeight (without Fuel, approx.)346 pounds (claimed)First Look: 2018 Husqvarna Vitpilen 701 appeared first on Motorcycle.com.
Click here for full story...
[visordown.com] - 2018 Husqvarna Vitpilen 701 debuts at Eicma Ninjette Newsbot Motorcycling News 0 November 7th, 2017 07:20 AM
[motorcycle.com] - 2018 Husqvarna Svartpilen 701 and Vitpilen 701 Spied Ninjette Newsbot Motorcycling News 0 May 25th, 2017 03:21 PM
[visordown.com] - Husqvarna Vitpilen 701 Ninjette Newsbot Motorcycling News 0 April 6th, 2017 11:00 AM
[faster and faster] - Husqvarna Vitpilen 401 Aero, Vitpilen 701 concepts shown at EIC Ninjette Newsbot Motorcycling News 0 November 10th, 2016 11:00 PM
[motorcycle.com] - 2015 EICMA: Husqvarna Vitpilen 701 Concept Ninjette Newsbot Motorcycling News 0 November 17th, 2015 02:20 PM
