August 15th, 2023, 09:43 AM | #1 |
[webbikeworld.com] - Insta360 X3 Action Camera Hands On Review
Click here for full story...
Insta360 X3 Action Camera Review Summary Review Summary The Insta360 X3 action camera is described as the most powerful camera you can carry in your pocket. The X3 has ½ 48 MP sensors and a 2.29 touchscreen capturing 5.7L 360 video with active HDR and the invisible selfie stick effect. You can take 72MP photos or just have the X3 as a standard action camera with single lens mode upgraded to sharp ultra wide 4K. For editing your pictures/videos, the Insta360 app is an AI powerhouse with intuitive reframing tools, you have a lot of technology at your fingertips. Design Build Quality Video Quality Sound Ease of Use Value for Money Pros The X3 is compact in design and really can fit into your pocket Very user friendly, easy to navigate your way around the functions You can turn the record feature on/off whilst riding along wearing motorbike gloves (most of the time) Option of 360 video or single lens mode Using the app on your mobile to edit your shots is user friendly with the option of the app editing the shots for you or you doing your own editing Cons When the selfie stick is mounted to the motorbike and extended this wobbles around due to the length and leverage so I just used an extra tie to keep the stick in place, just in case, although it does have stabilization so this does not affect the picture. Sometimes whilst wearing motorbike gloves, the on/off feature is hard to operate 4.8 Insta360 X3 Action Camera Image Gallery Review Summary
For a complete spec list, visit Insta360 X3. General
The Insta360 X3 has a 2.29 tempered glass touchscreen and can be held easily in one hand. The Insta360 X3 turned on showing the screen, battery level and storage left on memory card, which camera mode you are in and the left and right buttons on the bottom There are two buttons underneath the touchscreen, the right hand button is to start/stop recording, the right hand button switches the lens from inner single lens; outer single lens; 360 mode. On the screen itself, touch the camera icon to change the lens to selfie or outward mode. Touch the film icon and scroll through the menu to see: Video Video active hdr; Timelapse; Timeshift; Bullet time; Loop recording; Starlapse; Burst; Interval; Hdr photo Photo Single lens; Video; Me mode; Loop recording; Photo; Video Right Side On/off button; Q (customize features) Left side Battery and Micro SD card compartment; Charging port 360 Mode In 360 mode you can capture 360 degree footage and then you decide when editing what you want to see, zoom in/out etc. Switching Lens Modes is easy using the bottom right button Although it has a number of features and options it is very easy to use – simply mount the camera to your helmet, bike, motorbike etc. and press record. After recording, you choose the best angle using the reframing tools in the AI powered Insta360 app on your phone or tablet. You can then share this directly from your phone/tablet to any social media platform without losing any image quality. The X3 has dual ½ 48MP sensors which have more pixels for greater clarity and detail even if the light is low. The X3 has the most megapixels in a 360 action camera, you can take 72MP 360 photos with more detail than before. The lens cover which is an optional extra which I would definitely recommend you add to your order, especially useful if you pop the X3 in your pocket when parked up, it protects the screen The camera has 360 HDR mode which gives you stabilized action videos which work even in tough lighting conditions keeping the details in highlights and shadows. Single Lens Mode In single lens mode you can shoot first person view in wide angle just like a single lens action cam with maximum resolution with 4K30fps or an extremely wide 170 degree field of view with 2.7K MaxView. Inner Single Lens mode, easy to switch too using the bottom right button Features The Me Mode fixes the frame to focus only on you. Incredibly the selfie stick does not appear in your footage. The invisible selfie stick disappears in your edit enabling you to capture aerial angles and third person perspectives, which is so clever and also a great feature. This is a screen shot from a video of me riding, the Insta260 X3 is mounted to the rear of my bike with the motorbike claw mount and invisible selfie stick, the selfie stick does not appear in the footage The X3 features very good stabilization which keeps your videos smooth regardless of the camera shake and vibration from the bike. With 360 horizon lock, no matter if you are a motorcycle racer taking the twists and turns of a GP circuit, on a rollercoaster or doing acrobats in your airplane, whatever angle you have the camera or how much you lean the bike, the horizon lock will always keep your video level. With the new larger sensor over the previous X2 model, with the time lapse feature you can speed up time in 8K quality. With 4K 120FPS or 3K180fps Bullet Time you can go into slow mo effect but with even higher resolution and frame rates. The X3 is waterproof down to 33 ft or 10 meters but if you were not impressed at that then grab yourself the Dive Case and you can go down to 164 ft or 50 meters! Thoughts on the Insta360 X3 Wow! That sure is a lot of technology in one piece of equipment that you can fit neatly into your hand. If you are like me, ie. the least techy person there is, a lot of that information has probably gone way over your head. I know at first it did mine. The Insta360 X3 mounted to my bike using the motorbike claw mount and the invisible selfie stick, unextended I have another make of action cam and really dread using this as it is so complicated to use, set up, edit etc. that I am less inclined to use it and in fact I have not used it since the X3 arrived! The X3 has a built-in microphone that works really well but for vlogging and commentating while riding. There is a very simple plug in microphone adapter that just has a 3.5mm jack socket, you can plug a microphone into that which you can then have in your helmet. The microphone plugs into the adapter The Insta360 X3 however, is a whole new ball game for me. I absolutely love the fact that I can fit the camera onto my motorbike, press record and ride. That is it. All I need to know about the X3 is that it takes amazing videos and photos and then the editing software in the app does what it needs to do to make my videos and me look fabulous. The battery compartment and recharging port. The 360 image allows endless editing opportunities making it appear if the camera is rotating. It also gives so many options for different mounting places on the bike and you can, for example, take tracking shots of another bike so easily. When it comes to the editing, that is made so much easier by the Insta360 App that I have downloaded onto my phone. Creating Content So you now have footage that you need to do something with. The Intsa360 App which is AI powered is available to download from the app store. Simply download the Insta360 app, register and you are ready to go. Simple. I like simple. The home page on the Insta360 App To edit your footage, simply click on the camera icon on the bottom of the screen, pair your phone with your X3. That is it, you are now ready to edit your footage. Your footage uploaded and ready to be edited, just click on the one you wish to edit As you would expect, there are numerous editing options available to you. You can choose the length of footage that you wish to use with the Trim feature and can easily cut out the bits you dont want and paste them together with the Jump Cut feature. Then using your fingers on your touchscreen phone, you change the angle of the shot you wish to see, as if swiveling the camera around and zoom in and out. You can add a small screen in the corner of your video showing you a selfie or have it as a split screen. Image of footage ready to be edited, you can now start to choose how you wish to edit it and which parts you wish to have in your video You can speed up or slow down the footage, add sound to your video from a selection of free to use music, text etc. Honestly, the options are numerous but I am sure you get the gist of what I am saying. Once you are happy with your footage, you can then share it directly from the app to your social media or just save it to your photos on your phone. Simply use your fingers to turn the image around to show what footage you want in your video That is it. So simple and as you know I like simple. For even more simple, if you do not wish to edit the footage yourself, the app will do all this for you. It will put together a piece of footage from your content and prepare a video for you. You decide how long you want your video to be and it does the rest. You really cannot get easier than that. Insta360 X3 Video Samples Other Accessories You May Need With The Insta 360 X3
The external mic adaptor is easy to connect to the X3 simply take off the side cover (do remember to keep this safe) and plug the mic in. Attach the microphone using the crocodile clip inside your helmet. There is no wiring into the bike needed. You must remember that if an external mic is connected, then the X3 is not waterproof as you have taken off one of the side covers so if it starts to rain you will need to bear this in mind. What I Like About The Insta360 X3 Even though the X3 has an amazing amount of technology at your fingertips in a device that will fit in the palm of your hands, it is incredibly user friendly so for those of us that are technologically challenged, the X3 will create some amazing content that makes you look clever (I need all the help I can get there!) Side view of the X3 showing the battery compartment and the recharging port The X3 is light and small enough to put into a pocket when you are off the bike (or whatever it is you are on/in) and has an incredible amount of modes available to you. The basic price of the X3 is $594 so probably at the higher end of the Helmet & Motorcycle Action Cameras market but I, personally, think it is a great piece of kit that takes some incredible footage and will even edit it for me. You really can create some amazing content with the X3. What Id Change About The Insta360 X3 When wearing motorcycle gloves, I did sometimes have difficulty in operating the start/stop button which was frustrating at times when riding along. It is not always convenient to stop when riding and when I could not get the X3 to start recording, I missed some scenery that I would have liked to have captured. I would like to see the lens cover come as standard with the X3 itself. You literally just get the device, everything else is extra. Pros
Specs
Important Links / Where to Buy Product Page: Insta360 X3 The post Insta360 X3 Action Camera Hands On Review appeared first on webBikeWorld.
[webbikeworld.com] - NNOVV H5 Helmet Camera Hands-On Review | Ninjette Newsbot | Motorcycling News | 0 | March 13th, 2023 06:01 PM |
[motorcyclistonline] - Insta360 X3 Action Camera First Look Preview | Ninjette Newsbot | Motorcycling News | 0 | September 10th, 2022 03:11 AM |
[webbikeworld.com] - [REVIEW] Insta360 One X2 Camera Review | Ninjette Newsbot | Motorcycling News | 0 | January 16th, 2022 04:53 PM |
[roadracingworld.com] - American Flat Track: Insta360 Named Official Action Camera | Ninjette Newsbot | Motorcycling News | 0 | September 3rd, 2021 11:21 AM |
[webbikeworld.com] - INNOVV K3 Action Camera: Hands-On Review | Ninjette Newsbot | Motorcycling News | 0 | June 20th, 2021 10:13 AM |
