August 19th, 2011, 11:43 AM | #1 |
Join Date: Dec 2010 Motorcycle(s): 2005 ninja 250 street fighter, 2008 street fighter ninja 500, 2001 nsr 125 Posts: 812
one click, no start
I just dropped a new battery into my bike. Horn blows, lights are on, hit the starter and get one click. Who knows? And yes it's in neutral, kickstand up, clutch in and red button down. Please!
August 19th, 2011, 11:55 AM | #2 |
one click - bike not starting
got my 05 250 all set for sale and decided to put in a new battery myself for conscience sake. lights come on and horn blows but when i hit the starter button i get one click. yes the stand is up, clutch in, neutral, red button down et al. so what happened?
August 19th, 2011, 11:55 AM | #3 |
Is the gas line turned to be on??
Have you tried to clean the kickstand safety switch? |
August 19th, 2011, 12:54 PM | #5 |
/moved to pre-gen tech area
/duplicate threads merged
August 19th, 2011, 01:33 PM | #6 |
Did you charge the new battery first? Most new motorcycle batteries dont come charged until you purchase them and ask them to charge it for you.
August 19th, 2011, 03:36 PM | #7 |
Join Date: May 2011 Motorcycle(s): 2011 Ninja 250R SE GREEN! Posts: 562
2nd on starter motor or dead battery
August 24th, 2011, 09:06 AM | #8 |
Join Date: Jun 2011 Motorcycle(s): 2005 Ninja 250 Posts: 37
If the starter is clicking then it is most likely functional. Hook a battery charger to it; $20 says the battery is dead. Also, I noticed the battery doesn't charge very much (if any at all) when the bike is standing still. Get it running, ride it around the block so it isn't dead when you show the bike to someone.
September 6th, 2011, 04:28 PM | #9 | |
1. Check battery:
a. Voltage just sitting there should be no less than 12.7 volts. b. Voltage while starter button is pushed should not drop below 10.0 volts. 2. Check starter solenoid: a. Voltage on starter motor terminal should be present when starter button pushed. 3. If battery is good and voltage present on starter motor terminal, but it still doesn't work, remove and repair starter motor. Here is a guy that rebuilds them if you don't know how to do it yourself. I am not recommending him, I'm just posting his information: Quote:
A remote possibility is that your engine is locked up. Try push starting it in 6th gear to see if anything happens.
September 7th, 2011, 04:45 PM | #10 |
thanks all, know the family that lierally makes the batteries, so i'm going with starter motor or plug. thanks for the angles of looking. Happy trails.
September 12th, 2011, 12:46 PM | #11 |
starter motor, thanks again!
September 12th, 2011, 01:48 PM | #12 |
Join Date: May 2011 Motorcycle(s): 06 Buell Uly, 05 VStar 1100 Posts: 577
Mine done the same thing, I had to take the starter motor out and clean the brushes. Fixed it up. Is that what was wrong with yours?
September 12th, 2011, 04:43 PM | #13 |
We've been having a lot of rain down here recently (I live fairly close to coondog). Maybe it got wet or something.
Honestly, I've never heard of a bad starter on a Ninja until this thread. But I suppose anything is possible.
No start, click from fuse box, batt is good | WAGESLAVEesc | 1986 - 2007 Ninja 250R Tech Talk | 17 | June 7th, 2014 04:09 PM |
First gear click | Bentley813 | 2013 - 2017 Ninja 300 Tech Talk | 24 | July 2nd, 2013 06:27 AM |
[motorcyclistonline] - Adjusting Motorcycle Suspension | Click, Click | Street Savvy | Ninjette Newsbot | Motorcycling News | 0 | July 10th, 2012 10:20 PM |
Amazon.com 1-Click Ordering | Jiggles | Miscellaneous | 1 | December 15th, 2011 12:59 AM |
Weird Click | JBar215 | 1986 - 2007 Ninja 250R Tech Talk | 13 | June 7th, 2010 12:17 PM |
