May 28th, 2013, 09:46 AM | #1 |
Tip for those who wear glasses
I prefer a sportier riding position (leaned forward, tucked when on the highway, etc.).
Since I wear glasses full-time, this position has literally been a pain in the neck. When tucked my helmet does not block the view ahead, but I find myself looking over the top edge of my glasses. I'm sure those who wear glasses have experienced the same thing. Since I'm pretty much blind without my glasses, this is not a good thing. I have to tuck less, or crane my neck more, to see through the lenses. Recently I came up with a simple solution and confirmed that it works yesterday. I put a Breathe-Right strip over the bridge of my nose, high up (not as designed... I position it so the nose pads on my glasses rest on the strip). It holds the glasses up so that the top of the frames are against the rim of my eye sockets. Problem SOLVED and I can now tuck down all the way and still see ahead. As a side bonus, the strips have plastic pieces in them that form a slight ridge in the surface. These help to keep the glasses from sliding down my nose.
May 28th, 2013, 09:56 AM | #2 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
Are your lenses shatter proof?
(also nice tip) |
May 28th, 2013, 09:57 AM | #3 |
Join Date: Jan 2011 Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r Posts: A lot.
great idea!
May 28th, 2013, 10:03 AM | #4 |
Join Date: Mar 2013 Motorcycle(s): 2010 Ninja 250r Posts: 1
Ingenius
Why didn't I think about this before, or lasik or contact lenses. I prefer to poor mans way
May 28th, 2013, 10:21 AM | #5 |
Yes, but why should that matter? I wear a full-face helmet with a polycarbonate shield and I never ride with the shield up.
I've done contacts before in my life, but I'm now old enough that I actually look better with glasses. Contacts also dry out... I'm not a candidate for corrective surgery. My correction is +6.5 in one eye and +7.0 in the other... BEFORE you add in the bifocals. Those who know their prescription understand how extreme that is.
May 28th, 2013, 10:31 AM | #6 |
bring your helmet into the optometrist and find a second pair of cheap glasses that work well with the helmet. also the newer contact lenses are great. you can wear them for a month without touching them. (which means you can actually wear them for like 3 months... but lets not go there :P) also even if you have crazy bad vision they can do lasik to bring it down to a much more reasonable range. maybe you could get lasik then get a visor that is matched to your vision
May 28th, 2013, 10:43 AM | #7 |
My glasses cost $500. Minimum. Perhaps you don't realize just how radical my prescription is..... there are no "cheap" glasses.
Lasik is not an option, period. I'm not a candidate even if I wanted it. LASIK works well for nearsighted people. I'm extremely farsighted.
May 28th, 2013, 10:45 AM | #8 |
have you thought about eyeball transplants? i hear the newest cybernetics are getting pretty good. plus when you walk into department stores you can get recognized as "Mr. Wong"
May 28th, 2013, 10:51 AM | #9 |
Join Date: Apr 2012 Motorcycle(s): 650r 2009 Vulcan 800 2005 Posts: 557
Great tip. My script is not as severe as yours.... I'm at +2.25 or so. My glasses are shatterproof (@Panda), but they come with non detachable side shields. Sometimes I wonder if that is more dangerous than not having my glasses on! The side shields kill any chance of looking out the side and my head will only rotate so far. Couple that with them fogging up on cold mornings.... Often I ride with my glasses just rolled up in a rag in the saddle bags. I just can't see up close, my distance vision is still great, so driving sans glasses is not a real issue (tell that to the DMV). You gotta wonder just how "cool" ya look when you roll up to a place and have to take your glasses off before peeling out of helmet! snicker.
It's all about the curves. If you ride, you understand. If you have a stick skinny g/f and ride, you're 1/2 way there. |
May 28th, 2013, 10:53 AM | #10 | |
May 28th, 2013, 11:02 AM | #11 |
Join Date: Jun 2012 Motorcycle(s): 1998 Ninja 250 2007 Yamaha R6 2003 Honda RC51... sold :( Posts: 205
Neat solution. Most people that I've know with glasses have a set that have larger lenses than their normal pair just for riding.
I've been using contacts on and off for a while now and prefer them to glasses. I use the daily throw away ones. 10x better than the kind you can wear for months. I get a new lens every day and don't have to worry about cleaning them or carrying solution with me everywhere. I just toss a couple sets in a bag when I'm making a trip, and keep some spares in my desk at work. Years ago, I realized that it really isn't necessary to ride in a tuck on the street at all. I'll lean forward a little on the freeway, but not much. I always get a good chuckle at the guys who go full tuck before they are through the intersection. |
May 28th, 2013, 11:04 AM | #12 |
not an actual panda
Just wondering, I sometimes ride with my glasses on but they're not shatterproof. I ride with my helmet up pretty frequently in the city if I'm going under 25 or so. I always worry about my glasses though.
May 28th, 2013, 11:45 AM | #13 | |
Now, if you're accelerating hard enough on the street to require that, then it's a safe bet you're riding like an a$$hat. But that's a different discussion. To me the aggressive position is mostly about comfort and ergonomics. On my bike sitting up puts too much weight on your hands. Leaning forward allows me to relax my arms and also takes weight off of my butt. I NEVER get a sore butt because I rarely sit on it. Tucking on the freeway also lets me use the windscreen for its designed purpose... less buffeting, less noise, more comfort. On the Ninjette it also made a noticeable difference in acceleration at highway speeds due to the reduction in aero drag. With the GSXR not so much... all that horsepower overcomes it.
May 28th, 2013, 12:19 PM | #14 |
Have you tried putting something like stomp grip or tech spec pads on the tank? That takes a lot of weight off your hands too. Sounds funny, but by squeezing the tank with your legs, you're able to hold your upper body upright without putting any weight on your hands. It uses your core muscles more than your arms.
Another trick is to only squeeze the grips with your outer two fingers, and not the index and middle. Leave those two on the levers. When I am twisting the throttle, I'm pinching it between my fingers, and not wrapping my hand around it. Pretend you are holding onto a taco shell. Riders with smaller hands will have a harder time with this. |
May 28th, 2013, 12:50 PM | #15 |
The breathe right strip is a great idea. I'll have to try it. @adouglas, you and I are almost in the same boat. I run into the same issue of looking over my glasses some times when I ride. I have slightly thick lenses in my glasses and I've worn contacts (Toric) lenses too. Just barely a candidate for lasik, and a prime candidate for bi-focals, but I've been wearing glasses since I was a kid, so I feel naked without them sometimes.
What I've found is that a larger, rounder eyeglass frame increases the area in which I see thru, so I'm not looking over the top of them. So I have a cheap pair (i.e. frames) for riding, yard work, sports etc, and a pair for everything else. The pair for riding is minus some of the perks. (cool factor & shatter proof lenses) They do have anti-glare and transition lenses. I feel you, I do understand how expensive glasses are, and $500 a pop is nothing to sneeze at. I'm so glad I get mine at a greatly discounted price. |
May 28th, 2013, 01:00 PM | #16 | |
I've posted extensively about ergonomics on the forum so I won't repeat myself here. Aside from the other benefits already mentioned above, leaning forward allows me to rest some weight on the tank. That's huge for comfort over the long term.
May 28th, 2013, 01:07 PM | #17 |
CVMA #74 WSMC #750
Join Date: Oct 2009 Motorcycle(s): All of them Posts: A lot.
Here's my tip: Lasik!!!
Best thing you could ever do for yourself! No side effects or anything. Trust me...I've worn glasses all my life and was always afraid of the surgery but I'm telling you it's worth every penny!
May 28th, 2013, 01:43 PM | #18 | |
I would have recommended Oakleys, but they're not able to make wrap around lenses beyond +/- 4.0 total. I can go flat to the tank & still see through the Splinter's lenses, the FOV is just like wearing contacts. |
May 28th, 2013, 02:30 PM | #19 | |
CVMA #74 WSMC #750
May 28th, 2013, 03:06 PM | #20 | |
I thought my -4.25 and -3.75 was bad for a 20 year old... daaaaaaaaaaaaaaaaaaammn alex.s, I wish I could have continued wearing the fancy long-use ones, but I'm stuck with dailies. My eyes react really badly to the proteins that build up on lenses, and I get ridges/bumps (basically mini-hives) on the inside of my eyelids after about 2 days. Hurts like the dickens and makes wearing lenses impossible, as every time I blinked, the ridges would snag the lens and pull it out of my eye, don't forget the watering/eye goop 24/7. Fresh lenses every morning solved the issue. Doc tells me I'm a good candidate for Lasik, so once I get to 25 or so, I'll look into that. I've heard some great things about how non-invasive it is since they're all laser now, no knife involved anymore. |
May 28th, 2013, 03:11 PM | #21 |
Certified looney toon
MOTM Jul '13, Jul '14
Great tip, thanks! I have narrow lenses just because I like the look but yeah, the whole kink in my neck from trying to tuck while not looking over the frame has been annoying.
I'm annoyingly nearsighted so riding without my glasses is a serious no. I have contacts but for some reason they get stuck in my eyes and I've had problems with them before so it's just easier to put the glasses on than fuss with it. I'll give anything a shot to improve being able to see while riding.
May 28th, 2013, 03:35 PM | #22 | |
May 28th, 2013, 04:05 PM | #23 |
Certified Troublemaker
Join Date: Oct 2012 Motorcycle(s): 2006 Ninja 250r "Pikachu", 2017 Ninja 650 "Epona" Posts: A lot.
I just switched to contacts myself. I use the acuvue oasys daily lenses without to much drying out.
you could always keep a pair of non-prescription glasses to put on when you get off the bike to look good. |
May 28th, 2013, 05:23 PM | #24 |
Join Date: May 2012 Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike) Posts: 748
Another alternative recommended by an older guy I met is to actually get prescription billiard glasses.
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear |
May 28th, 2013, 05:54 PM | #25 |
May 28th, 2013, 06:03 PM | #26 | |
PRK seems to have a longer recovery time but seems to be a safer procedure.
glasses camera?? | ai4px | Videos | 19 | May 12th, 2014 06:02 PM |
Glasses | Apex | Off-Topic | 8 | May 13th, 2012 10:17 PM |
Anyone wear glasses? | Falcor | General Motorcycling Discussion | 51 | April 30th, 2012 10:06 AM |
Watches, boots, sun glasses, etc. | g21-30 | Miscellaneous | 2 | December 30th, 2009 05:43 PM |
Glasses and motorcycling | Elfling | General Motorcycling Discussion | 11 | May 17th, 2009 09:10 PM |
