Old June 16th, 2012, 07:33 AM   #1
Will raising my suspension with shorter dogbones change my chain length requirement?
I need to order a chain and sprockets for a pregen with newgen suspension (swingarm, wheel, shock, etc).
So no one thinks I'm doing this specifically for the chain: I'm not. I already planned to raise the tail. In fact, I plan to remove the blue paint from a proper 106-link chain and use that if possible, but the green one I want is only available up to 104 links. Because I really want that green chain, I will be extra sensitive to changes that might require a longer chain and extra appreciative of any change that might require a shorter one (smaller sprocket). Which category might this change fall under, if any?
I know that the chain tightens up when the suspension compresses, which is why you want slack and you don't want to ride with a tight chain. It seems to me that raising the rear would be the geometrical equivalent of unloading the suspension, which may contribute to the slack I need to get away with a shorter chain.
Any input?
Old June 16th, 2012, 08:49 AM   #2
Your max length plus some little slack for the centrifugal force on the chain is needed for the travel point of the rear suspension at which the front shaft, swingarm's pivot and rear axle are aligned.
That is what the specified measured slack in the extended position guaranties.
Will your new steup reach the alignment position?
If yes, then you still need adjusting your length and the new measurable slack by that condition.
Old June 16th, 2012, 09:49 AM   #3
I understand. I guess I really won't know if it has enough slack and adjustment with 104 links until I try it. I may have to buy a smaller rear sprocket but I am willing to do that.
Old June 16th, 2012, 10:07 AM   #4
leed
leed's Avatar
Motorcycle(s): Time will tell
Yes, technically you would need to shorten the chain, but I don't think you have anything to worry about. Worse comes to worst, you have to punch out a set of links, but I honestly don't think you have much to worry about.
Old June 16th, 2012, 11:29 AM   #5
the amount that you end up raising the tail will effect the chain only slightly. well within the adjusters limits
Old June 16th, 2012, 02:30 PM   #6
That's just it. I need to use an already shortened chain and I'm hoping it's long enough.
Old June 16th, 2012, 02:33 PM   #7
hmm... might just be me being ghetto fab but... combine old and new chain? you only need one link right?
Old June 16th, 2012, 02:53 PM   #8
The bike currently has no chain. That's how I bought it. I already have a spare 106 link blue chain that I could throw on there, but I'd have to strip the paint and I'd rather buy the 104 link green chain. The 104 link green one fits my color theme perfectly but isn't available in longer link counts.
Bad idea? Smaller sprockets for shorter chain CZroe 1986 - 2007 Ninja 250R Tech Talk 11 July 5th, 2014 02:59 PM
Dogbones length and design broken neck 2008 - 2012 Ninja 250R Tech Talk 55 March 6th, 2014 07:35 PM
15/43 sprocket combo chain length? gantt 2008 - 2012 Ninja 250R Tech Talk 13 September 8th, 2013 10:21 AM
Sprocket and chain length question. MKlein3004 Ninjettes At Speed 2 August 14th, 2013 06:40 PM
Raising the seat/tail on a pregen (dogbones?) CZroe 1986 - 2007 Ninja 250R Tech Talk 21 July 3rd, 2012 12:31 PM
