July 4th, 2015, 03:17 PM | #1 |
Join Date: Jun 2015 Motorcycle(s): 2008 Ninja 250R Posts: 102
Right handlebar
Bike was put down on the right at a track day, helping a friend fix it up. He remembers that this is some sort of eBay clipon deal. It measures 7/8 in diameter and just over 12" long. We do not believe it is stock.
Anyone know where we can get a replacement? I heated/rebent it back pretty straight but neither of us are sure of how we feel about that being safe. |
July 6th, 2015, 08:58 AM | #2 |
Join Date: Sep 2013 Motorcycle(s): 2015 Yamaha FZ07, Ninja 250r 2012 Limited Edition (Sold) Posts: 529
Looks fine to me. I had a bent bar that a friend straightened good as new. I rode that bike thousands of miles without a problem before I sold it.
"Take it easy driving. The life you might save might be mine." |
July 8th, 2015, 07:02 PM | #3 |
Took it apart again today, to install new passenger side throttle, kill switch, start. It's still anything but straight.
Any ideas on where we can get another or will used OEM work? It has plastics at both ends like OEM but unlike most aftermarkets. Any suggestions on aftermarket grips while I'm at it? |
July 8th, 2015, 07:28 PM | #4 |
No clue on the bar, OEM's are one piece so will not work for you. And Dury makes nice grips that are not pricey at all.
July 8th, 2015, 07:47 PM | #5 |
July 8th, 2015, 08:56 PM | #6 |
Gear crash test dummy
Join Date: May 2011 Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r Posts: A lot.
Why has nobody told him that any 7/8th replacement bar will fit? Just buy a woodcraft replacement bar.
CVMA #531 |
July 8th, 2015, 09:15 PM | #7 | |
Private Joker
MOTM - Mar '14
link: http://www.revzilla.com/motorcycle/w...t-clip-on-bars
I see you over there seeing me, do you see the me I think you see? |
July 8th, 2015, 09:43 PM | #8 | |
http://www.ourygrips.com/road-grips/
July 8th, 2015, 10:26 PM | #9 |
Also - to be clear a straightened bar is just fine. The only thing you have to be concerned about is the throttle cables blinding. If you can twist the throttle, let go, and it snaps back then you are good.
If it doesn't snap back first make sure the rubber grip itself is not touching the bar and causing a slow return.
CVMA #531 |
July 14th, 2015, 12:04 AM | #10 |
ordered the woodcraft 7/8 handle in silver today and the replacement stock grip/right side control is already here so rolling with that for now. thanks guys
Handlebar risers | Brian250R | 2008 - 2012 Ninja 250R Tech Talk | 29 | January 11th, 2016 02:31 PM |
Need a Handlebar | Finesse | Items Wanted | 7 | May 16th, 2014 02:33 PM |
Right newgen handlebar | ninja250 | Motorcycle-related | 4 | August 13th, 2011 06:56 PM |
08+ Right handlebar | TeamGreen | Items Wanted | 6 | October 6th, 2010 09:46 PM |
Got handlebar vibrations? | sofo | General Motorcycling Discussion | 15 | August 18th, 2010 09:14 PM |
