June 16th, 2012, 10:32 PM | #1 |
Join Date: Jun 2012 Motorcycle(s): 2009 Ninja 250R Special Edition (Green) Posts: 33
Is there a DIY guide for...?
Is there a "Do It Yourself" guide on how to take out the right handle bar of a Ninja 250R? If not, may anyone help me on how to take out the right handle bar? I recently crashed my motorcycle and the right handle is bent. I am not comfortable in riding the motorcycle like that, it feels weird. I am afraid of messing anything up if I don't get proper help before I do it. I plan to straighten the bar once I have everything uninstalled. Then I'll me ready to ride again !
Thank you - A Tomato And it looks like this... |
June 16th, 2012, 10:35 PM | #2 |
Jigglin' your Jiglets
MOTM - Apr '13
Roast the bolt on the end with a torch. Pull everything off. Win.
June 16th, 2012, 11:04 PM | #3 |
torch the bolt on the bar end until it smokes a little.
use either a phillips t handle or two screw drivers unscrew the bolt. then use the screw driver on the rest of the bolts behind the ignition switch. use an 8mm to undo the brake reservoir and lever assembly. use a ratchet with a hex key to loosen the bar. slide everything out and then replace bar. installation is the reverse of removal. use blue loctite on the two brake assembly bolts. |
June 16th, 2012, 11:37 PM | #4 | |
MOTM - Apr '13
June 18th, 2012, 09:55 AM | #5 |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
It's found in the middle of the woodcraft DIY
Here's the post: http://www.ninjette.org/forums/showt...38&postcount=2 |
An Engineer's Guide to Cats 2.0 | Alex | Off-Topic | 4 | January 26th, 2014 01:15 AM |
Buyers Guide | HenBat | 2008 - 2012 Ninja 250R Tech Talk | 3 | May 22nd, 2013 08:31 PM |
A handy reference guide | LuxMundi | Off-Topic | 3 | August 30th, 2010 07:39 PM |
[visordown.com] - How to do just about everything. A guide. | Ninjette Newsbot | Motorcycling News | 0 | May 27th, 2010 12:30 PM |
Chain Guide Wear | backinthesaddleagain | 2008 - 2012 Ninja 250R Tech Talk | 18 | October 1st, 2009 10:40 AM |
