Old April 5th, 2018, 02:35 PM   #1
Cafe Racer
Motorcycle(s): Harley Fatboy, Honda CX500, Harley XL1200C Sportster, 305 Honda Dream, Ninja 250
Help with oil filter plate
I dropped the oil filter assembly and noticed it is missing the oil filter plate, part number 13169-1313. It looks like a half cylinder that slides over the oil filter.
I am not sure if it is necessary, but it only cost a few bucks.
What to the experts think?
Thanks
Cafe Racer is offline   Reply With Quote
Old April 7th, 2018, 06:12 AM   #2
greg737
Motorcycle(s): -
That piece acts to reduce turbulent flow and insure proper pooling of oil at the pickup piont in the oil sump, helps to prevent bubbles or foaming that might cause cavitation at the oil pump.
Old April 7th, 2018, 03:47 PM   #3
Cafe Racer
Thanks Greg your are the man. I knew it had to do something. For now I put a washer the same size as used between the spring and the filter body. When I get the part I will drop the oil and add it to the top of the filter.
Thanks again.
Old April 8th, 2018, 12:41 AM   #4
Ram Jet
Ram Jet's Avatar
Yeah what he said. Also, those penny pinching Kawasaki cost accounts who worship the Unit Manufacturing God wouldn't allow it to be there if the engineers didn't think it was necessary.
Bill
Old April 10th, 2018, 02:45 PM   #5
austinninjabill
Motorcycle(s): 1992 250R Ninja
That thing called the filter "fence" goes on top of the filter and not the bottom, right?
austinninjabill is offline   Reply With Quote
Old April 10th, 2018, 04:26 PM   #6
Cafe Racer
Yep it goes on top of the filter thereby covering a portion of the top half of the filter.
By the way I used a KN-401. It comes with two large o-rings, neither of which fit. One is way to big and the other is a little to small. So I used the old o-ring which was still just right. Going to have to buy a few oem o-rings I guess. I hate Fram filters, they are cheap but crap. KN better made, but that filter is crossed to many different bikes, atv's, and lawn mowers.
Oil filter crosses over with Honda filter smokinsingle 2008 - 2012 Ninja 250R Tech Talk 4 April 19th, 2014 08:47 AM
Oil/Filter help? Eagle981 1986 - 2007 Ninja 250R Tech Talk 2 January 13th, 2013 07:23 PM
Loss of oil and Air filter soaked in Oil 08ninja250 2008 - 2012 Ninja 250R Tech Talk 19 August 9th, 2010 05:35 PM
change oil filter, without draining oil? peter330 2008 - 2012 Ninja 250R Tech Talk 5 May 30th, 2010 01:08 PM
