November 25th, 2008, 05:55 PM | #1 | |
JIS Screws
I saw this on another forum, and went to do a bit more exploring. It seems that the reason so many of us are having difficulty with our carb screws is because they aren't Phillips at all!
November 25th, 2008, 06:36 PM | #2 |
Great info!
November 25th, 2008, 07:32 PM | #3 |
yes, I agree... great info.
as a common practice, I always push the screwdriver down into the screw head as hard as I can before I apply sideways torque to loosen any screw. If the screwdriver head fits relatively tight in the screw head, the chances of stripping it out is slim. That and make sure the faces of the splines of your Phillips screwdriver is not chewed up. Cheap tools deform easier due to their softer temper of the steel that is used, which is why I use Craftsman hand tools with their lifetime warranty... When the wear out, take them back to the store for a brand new one. |
November 26th, 2008, 11:23 AM | #4 |
Kelly, Second the need for good tools. Mine are Craftsman, Snap-On, and Park Tools (for the bicycles). I use torque wrenches a lot primarily because a lot of bicycle components are carbon fiber and aluminum. It looks like motorcycles are going in the same direction. Besides, I always feel better when I have a torque spec on a bolt.
November 26th, 2008, 11:33 AM | #5 | |
Car wheel lugs and oil drain plugs are 2 that always see my torque wrench when it comes time to put them back on. |
November 30th, 2008, 02:17 PM | #6 |
Get your JIS screwdrivers .... here!
http://www.centralhobbies.com/Tools/jis.html
and you get a nice catalog with specialty tools included! $17.99 + S&H |
November 30th, 2008, 05:08 PM | #7 | |
December 14th, 2008, 05:29 PM | #8 | ||
IC2(SW)
January 5th, 2009, 02:23 PM | #9 |
JIS Screws Revisited
All those phillips screws on the 250R are NOT Phillips screws. Here are bits (JIS) which can be used in the MOS tool, which works great for those hard to reach screws.
January 7th, 2009, 07:36 PM | #10 |
lolwut
Join Date: Dec 2008 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 196
those crazy japanese....
that said, I shoudl get some of those
08 Blue Ninja 250R |
January 7th, 2009, 08:28 PM | #11 |
Guys, I haven't thought this in a long time, but twenty years ago this why I always used the screw driver supplied in the tool kit to break the screws loose.
January 7th, 2009, 08:34 PM | #12 |
I just hope the tools are made of a stronger steel than the butter screws they use, but good point about the stock tool kit having appropriate tools for the screws used on the bike... maybe.
Do we know if all screws on the bike are JIS or only these on the carbs and other places? |
January 7th, 2009, 08:47 PM | #13 |
Not sure about some of the smaller screws, but I'd think the kit should have the right type.
Many years back, the case screws were "phillips" and the only way to get them out was with the supplied tools. We used to replace them with allens most of the time though. I do remember drilling the heads out on a few, pulling the cases, using vise grips on the studs and then installing allen bolts. It's probably been twenty years since they used phillips on the case bolts. But it might pay off to check the tool kit. I do agreed, if you are going to do much work on bikes, buy the right tools. |
January 7th, 2009, 08:55 PM | #14 | |
lol... I had completely forgotten about replacing the case screws with allens... I used to do that with all the dirt bikes I had back then. |
January 8th, 2009, 04:29 AM | #15 |
If you read about the design of JIS screws and the US phillips screwdriver, they both interact to MAKE the screwdriver NOT grip the screws correctly.
The screwdrivers supplied with the bike are a P.O.S. in my opinion, but I might be inserting them in the handle wrong. I think they are more trouble than they are worth. The JIS set, with integral handles, have worked on every screw on my bike with no damage. I was even able to do the carbs with them; however, as I stated previously, I did use a phillips bit with the MOS for the 2 screws under the frame. I put lots of pressure, so the bit didn't rotate out. |
January 22nd, 2009, 12:15 PM | #16 |
Don't Be Evil!
On any stubborn Phillips screw I always put the bit in a 1/4 in socket on a 1/4in ratchet. It makes it easy to push down hard and put torque on the screw.
January 22nd, 2009, 03:21 PM | #17 |
Just for clarification, the JIS screws are not stubborn Phillips screws. Matter of fact, they are very easy to remove with a JIS screwdriver. If you research how a JIS screw is designed versus a Phillips screwdriver, it's kind of like trying to remove a one-way screw with a regular flathead screwdriver. The flathead screwdriver just walks right out without gripping the screw! The JIS screwdrivers I use haven't damaged any of the screws on my bike. There are only 2 screws with any visible damage (had to use a Phillips bit in the MOS, as mentioned above) to get them out of the carbs, in order to remove the needles. They are still very usable.
January 23rd, 2009, 09:34 AM | #19 |
Got 'em. Put 'em in the tool chest. Haven't had an opportunity to use 'em yet.
January 25th, 2009, 07:55 AM | #20 |
It is really amazing that Sears-Craftsman has not heard of JIS Screws. I am going to check out NAPA, Mac Tools, Makita, and Snap-On. I would like to get a set that will work with my impact driver. It is strange that the official Kawasaki Shop Manual makes no mention of JIS screws. A bit set that can also be used with a racheting screw driver or 1/4" socket ratchet would offer the most versatility.
January 25th, 2009, 08:14 AM | #21 | |
Did you miss post # 9 above? Just what you're looking for! |
January 25th, 2009, 05:26 PM | #22 |
I think that I will probably put in an order with them. Have you seen the screwdrivers called "Posidrive"? They claim to be the same as JIS. Snap-On , Mac Tools, SK Tools, Milwaukee, and Makita make them. I will check them out further and try to find a whole set ranging from 0 to #4 in both the long and short bit.
January 25th, 2009, 05:47 PM | #23 |
Join Date: Jan 2009 Motorcycle(s): '13 Ninja 300 '09 Boulevard C50. '08 250r(TOTALED BY DEER) Posts: 467
This thread brings back memories...
First, Hi Torque/One way screws in the aerospace industry(similar to pic) ...those things are a beast to remove/install. Second, Who remembers King Of Queens where Arthur wanted to invent the "A" head screw, to make a million dolars?
CHEERS!!! Last futzed with by Tigerpaw; January 25th, 2009 at 07:02 PM. |
January 25th, 2009, 06:37 PM | #24 |
This whole thing blows me away. We finally got away from Whitworth, were promised to be all Metric, and are ultimately stuck with SAE, Metric, and now JIS. Sure would be nice if there was some standard. We went through the 4 Channel Stereo era with three incompatible systems, then we went through the Beta vs VHS war, Now DVD vs Blue Ray. It`s really a pain in the a$$.
October 30th, 2009, 07:25 PM | #25 |
October 31st, 2009, 02:47 AM | #26 |
Back in GA, my friend assured me that he could remove the screws from the front brake reservoir using a certain screw driver (can't recall if it were one of mine or one from the bike's tool kit). I told him that I didn't do it myself because I could tell that it was going to slip and I was looking for the right screwdriver. This prompted him to try it himself to prove it to me. The screw immediately chewed up and the driver spun in place despite all the weight he was putting into it. Now I have a nice shiny bit of silver staring at me wherever I go! Idiot. I colored it black again with a Sharpie but that didn't last long.
October 31st, 2009, 08:09 AM | #27 |
Buy the JIS set I linked to in a previous post. One of the drivers will remove that screw for you.
See attached. |
October 31st, 2009, 03:39 PM | #28 |
November 1st, 2009, 01:25 PM | #29 |
More Info - FYI
November 1st, 2009, 01:33 PM | #30 |
so, the drywall bits won't work?
November 1st, 2009, 01:36 PM | #31 |
November 1st, 2009, 04:01 PM | #32 |
IC2(SW)
I had two tamper proof bit sets. Just so happen's they have some philip type bits that fit the bike perfect
November 5th, 2009, 08:18 PM | #33 | |
Join Date: Jun 2009 Motorcycle(s): 2009 Ninja 250 (Blue) Posts: 167
November 6th, 2009, 06:06 PM | #34 |
Join Date: Aug 2009 Motorcycle(s): 08 Ninja 250R(red) 09 Ninja 650R(red) 08 PGO Buddy 150(Pamplona) Posts: 41
i just bought the 3 pieace bit set and also a long #2 screwdriver, and i also picked up some #4 brass washers last nite i have some questions about what happens next but there seems to be a ton of simming threads which one should i post to?
[webbikeworld.com] - Vessel Motorcycle JIS Screwdriver Kit Review | Ninjette Newsbot | Motorcycling News | 0 | August 11th, 2013 02:30 PM |
Is a JIS screwdriver a necessity? | slickt0mmy | 1986 - 2007 Ninja 250R Tech Talk | 7 | June 26th, 2013 05:14 AM |
JIS screwdrivers - Why do we damage some of the hardware? | Motofool | General Motorcycling Discussion | 6 | July 14th, 2012 11:53 AM |
Where to get new screws? | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 5 | December 14th, 2011 02:10 PM |
[webbikeworld.com] - JIS Screwdriver Review | Ninjette Newsbot | Motorcycling News | 0 | October 17th, 2011 07:40 AM |
