Old April 24th, 2012, 10:33 AM   #1
blown transmission?
a few minutes ago was on my way to work... wot, clutchless shift from 4th to 5th, then it slipped out... click click, boom. gear shift lever wont turn either way. stuck in false neutral. makes odd clicking sounds as i rolled it up a mile hill to work. havent had the chance to take anything apart yet as it literally just happened. ideas?
Old April 24th, 2012, 10:51 AM   #2
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
How big was the boom?
Sounds like a bent/broken valve.
What is with you and all these bike problems? LOL
Old April 24th, 2012, 10:56 AM   #3
zzrguy
zzrguy's Avatar
Motorcycle(s): 2002 ZZR 250
Thumbs up
Sucks if you blew your tranny the gears arnt cheap. Dont know why people clutchless shift. Do you see moto gp riders clutchless shifting.... nope because they are the best and dont need to.
Hope its not too bad
zzrguy is offline   Reply With Quote
Old April 24th, 2012, 10:58 AM   #4
engine runs fine. its definitely the transmission. shift lever wont move. clutch seems to work fine... i think the shift fork or the dogs on a gear are busted.
i think its funny when people try to say clutchless shifting is bad for these transmissions when they were designed to work that way. also what do you mean motogp riders dont use clutchless shifting? yes they do
Old April 24th, 2012, 10:59 AM   #5
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
First busted trans I've heard of. Pics of the aftermath!
Posted via Mobile Device
Old April 24th, 2012, 11:03 AM   #6
srs. clearly riding too much.
Old April 24th, 2012, 11:09 AM   #7
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Check your gear shift assembly and the gear shift linkage by the generator cover.
Old April 24th, 2012, 11:09 AM   #8
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
I think he ****s with stuff so much that it just breaks. Not that he's messed with the transmission but the whole bike is kind of a whore/mutant at this point anyway
Trailerboy531 is offline   Reply With Quote
Old April 24th, 2012, 11:11 AM   #9
the linkage is clear, i have the sprocket cover off and the shift tube going to the fork that connects to the gear change drum looks straight, but wont rotate. i think something broke off inside and is stuck in the shift drum with it between gears.
Old April 24th, 2012, 11:12 AM   #10
for a while my rearsets were adjusted ****ed up and i missed a lot of shifts. i think that did the damage and later on (this morning) the damage finally caused some real problems.
Old April 24th, 2012, 11:15 AM   #11
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Well, at least he got his NSR out of the way before said incident.
Old April 24th, 2012, 11:19 AM   #12
haha damn straight. next race ill push the 250 out to starting grid in the very back then at the start, do my best to push it as fast as i can to the end of hot pit... then turn around and walk back up hot pit.
Old April 24th, 2012, 11:36 AM   #13
Trailerboy531
I'd give you a short bus trophy for that!
Old April 24th, 2012, 11:38 AM   #14
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
AFM #676
Supersports are for n00bs
Old April 24th, 2012, 11:38 AM   #15
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Well, in the mean time why not give him a ride on your short bus.
Old April 24th, 2012, 11:40 AM   #16
zzrguy
zzrguy's Avatar
Never said clutchless shifting is bad for trannys, :P
Clutchless shifting if messed up can bend valves/forks, im guessing thats what happened.
Old April 24th, 2012, 11:42 AM   #17
Trailerboy531
No Asian genes/short bus here
Old April 24th, 2012, 11:43 AM   #18
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Take a few of my percocet, that'll give you a short bus
AFM #676
Old April 24th, 2012, 11:43 AM   #19
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Oh that's right...come here Alex. Daddy's calling ya!
Old April 24th, 2012, 11:44 AM   #20
Trailerboy531
Old April 24th, 2012, 11:45 AM   #21
*shiver*
Old April 24th, 2012, 12:15 PM   #22
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
You sure about that working fine??? Sure seems bad for the tranny to me
Old April 24th, 2012, 12:37 PM   #23
clutchless upshifting is how a sequential gearbox was designed to operate. poor shifting technique and missed shifts cause damage regardless of gearbox design.
Old April 24th, 2012, 01:20 PM   #24
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Sounds like a shift fork is broken . This is not as bad as it sounds. I have removed the trams at the track in my van. And still went out and ran at record speed. I also blew up my trams and got a new one on e bay for100 bucks.
You have to drain the engine. Pull both side covers and then the water and oil pump. That will give you access to most of the shifter stuff. If you don't find anything. Drop the engine and flip it upside down . There are a bunch of 12mm bolts and a couple 10mm bolts both top and bottom under the oil filter and under the starter. Once you have all that apart the case will split. Clean everything before you split it.
Can you do this?? Do you have a manual?
Old April 24th, 2012, 01:25 PM   #25
im waiting for a ride right now. once i get the bike home i will drop the engine and start pulling it apart. i should be able to handle it, but i dont have the service manual. maybe someone can link me a pdf for the transmission section?
thanks for your reply eric. makes me feel better already.
Old April 24th, 2012, 01:27 PM   #26
because when done right, it's faster. Watch my 0-60 video. In the first attempt, notice how much quicker the 2-3 shift is than the 1-2 shift. I used the clutch because I forgot not to the first time. The third attempt is the best example of how quick clutchless shifts are. Both of those shifts were without clutch in the third attempt.
Yessir. I see NASCAR guys doing it too when there's a camera in the cockpit.
Old April 25th, 2012, 10:24 AM   #27
Old April 25th, 2012, 10:32 AM   #28
Mocha Man
Blue Shell magnet
Mocha Man's Avatar
Motorcycle(s): 1997 Ninja 250
Dang, that looks all sorts of messed up
Mocha Man is offline   Reply With Quote
Old April 25th, 2012, 05:04 PM   #29
leed
leed's Avatar
Motorcycle(s): Time will tell
Something seems off about that bike...
Old April 25th, 2012, 06:03 PM   #30
sixer
no joy
sixer's Avatar
Motorcycle(s): Ninja 2006 636
Looks like my bike Alex.. But I haven't split my engine yet.. Post a how to split it as U go along - Pwease!
sixer is offline   Reply With Quote
Old April 25th, 2012, 06:51 PM   #31
Racer x
Racer x's Avatar
When all the bolts are out the case half's fall apart easy. Do not force it . I it is stuck there is still a bolt in it . Good luck.
Old April 26th, 2012, 01:19 AM   #32
got part of the way through but need to go buy the clutch hub removal tool thing... stupid thing spins and i cant take the hub nut off without the tool. the shift fork looks unbent but i cant see it clearly until get the hub off though. maybe theres a trick to getting it without the tool, but its 20$ at cyclegear, so i'll just pick it up on my way home from work tomorrow. so far the engine seems to be in great condition.
Old April 26th, 2012, 03:04 AM   #33
Racer x
Racer x's Avatar
Getting the hub off is tough. You will need an impact gun. Definitely get the tool and try,But you can get the stuff apart without it. But it is much easier if it is put of the way
Old April 26th, 2012, 05:03 AM   #34
n4mwd
n4mwd's Avatar
I don't agree that the Ninja 250 transmission was designed to be clutchless shifted. I have never seen anything from Kawasaki saying that. Do people do it? All the time. But its a lot of unnecessary wear and tear on the transmission - especially if its not done perfectly. Unless you are racing, it has no purpose.
Odd, but this is the second blown Ninja transmission I've heard about in a month. Fortunately its rare and the parts are cheap (supply and demand). Here is a complete gearset for $35.
I suggest you use the clutch from now on or buy a scooter.
My Ninja Blog
Old April 26th, 2012, 06:04 AM   #35
Racer x
Racer x's Avatar
Cars has synchro mesh transmissions. They are not meant to be clutch less shifted but you can do it. Motorcycles have a constant mesh transmission. Clutchless shifting is perfectly fine when done right. The factory does not need people trying to learn the technique Ina motorcycle under warenty.
Old April 26th, 2012, 06:57 AM   #36
n4mwd
n4mwd's Avatar
Car transmissions are also constant mesh except for reverse. The method of connecting the gears to the shaft is different from bikes, but the gears are all constantly meshed together. You can't make a car transmission grind in forward gears (reverse you can because its the only one not constantly meshed).
I bolded the part about being done right. True, but it can lead to problems when done wrong. Doing it wrong is abusive to the transmission. And its a lot easier to do it wrong. If the bike jerks even in the slightest, its being done wrong and the transmission is being abused.
Except for racing, what does it buy you? Nothing.
My Ninja Blog
Old April 26th, 2012, 09:09 AM   #37
Racer x
Racer x's Avatar
You are correct on all accounts, but some times in traffic I just do it. So far I have never ground a gear. But like you said doing it wrong is abusive.
Old April 26th, 2012, 09:20 AM   #38
chikenstrips
chikenstrips's Avatar
Motorcycle(s): ninja 250r
possibly bent a shift fork really bad and jammed it
chikenstrips is offline   Reply With Quote
Old April 26th, 2012, 09:30 AM   #39
everyone is entitled to their opinion, i guess.
Old April 26th, 2012, 09:30 AM   #40
ever stop to think, "maybe he is racing his 250?"
Blown fuse. Then another. mrudich 1986 - 2007 Ninja 250R Tech Talk 34 July 30th, 2020 08:26 AM
Help! Blown motor! JpSavage96 1986 - 2007 Ninja 250R Tech Talk 3 February 10th, 2015 09:32 PM
Blown gasket? Christofini 2008 - 2012 Ninja 250R Tech Talk 6 November 8th, 2013 10:48 AM
blown transmission #2 alex.s General Motorcycling Discussion 40 September 12th, 2012 02:08 PM
Being Blown Off Your Ninja Slono Riding Skills 33 March 7th, 2012 12:44 PM
