Old August 4th, 2012, 11:19 AM   #1
blown transmission #2
blew the main output shaft bearing. also the used ebay transmission i bought has a bent output shaft. so i'm going to combine parts from the two since i have a straight output shaft and the other one has good bearings. already cleaned everything out and had put the "new" transmission in which supposedly was in perfect condition (****ing ebay liars) and notice a slight click when rotating the two gear sets together so i examined it more closely and its just slightly bent.
anyway heres some pics of the damage... you cant really tell from this angle but inside the bearing the bal cage is completely destroyed and pretty much disintegrated luckily nothing else was damaged by the debris
Old August 4th, 2012, 11:27 AM   #2
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
I envy your mechanical knowledge
AFM #676
Supersports are for n00bs
Old August 4th, 2012, 11:29 AM   #3
someone tells me its actually my lack of mechanical knowledge that gets me into these situations... sometimes i think that person might be right.
Old August 4th, 2012, 11:31 AM   #4
oh i forgot to mention. one of my chain links had started to freeze up and i thought it was acceptable to leave it for a little bit longer. i guess i was wrong. pretty sure it was freezing up because i pressed the master link too tightly. so there you go... improper chain link pressing and boom goes your tranny. but then i have been known to jump to conclusions.
Old August 4th, 2012, 11:33 AM   #5
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Well your miles ahead of me, the most involved thing I've done is carb work
AFM #676
Old August 4th, 2012, 11:38 AM   #6
cuong-nutz
cuong-nutz's Avatar
Damn and I thought I had some bad luck! How much did the eBay tranny cost you? I'd dispute the transaction or recoup some money back if it were possible.
HalfFast Racing Team
Old August 4th, 2012, 11:42 AM   #7
it was like $50 and came with a new internal breather protector thing (mine was damaged) and crank balancer and some other parts besides the transmission... really the only thing damaged was the output shaft itself. i'll keep the set for parts in the future. maybe i can get a buddy to straighten the shaft or something.
Old August 4th, 2012, 12:13 PM   #8
Sorry to see that, Alex.
Check that the outer ring didn't spin in the aluminum.
I have seen that damage in bikes abused with wheelies and over-tight chains.
Improper installation that introduces an axial load on the bearing can also destroy it, but I don't think this applies in this case.
I doubt that the shaft can be straighten up, but I hope I am wrong.
Old August 4th, 2012, 12:39 PM   #9
no intentional wheelies but plenty of quick starts and a -1 front sprocket added to the load. the chain was a bit too loose but the master link was binding a bit. i think i dun broke'd it
Old August 4th, 2012, 01:18 PM   #10
It is hard to believe that the binding link could add enough load as to be critical; before failure, it would have produced a lot of vibration and noise, I guess.
Time for autopsy:
http://www.skf.com/portal/skf/home/p...nk=5_15_022000
http://www.skf.com/files/099926.pdf
Old August 4th, 2012, 01:35 PM   #11
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
I got ceramic bearings from World Bearings for my trans. They make a full
Set for the 250 ninja. The owners wife rides a 250
Ninja.
Old August 4th, 2012, 01:52 PM   #12
Bob2010
Bob2010's Avatar
so, how is this happening? So others can avoid doing, whatever it is, that you are doing
2010 Red Ninja 250
2009 Black Ninja 250
Old August 4th, 2012, 03:21 PM   #13
Racer x
Racer x's Avatar
In my case I was on the dyno. I made a hard pull and turned off the motor. I wanted the talk to the dyno operator.The rear wheel was spinning and so is the chain and output shaft. Half the gear cluster is spinning when the engine is off and the rear wheel is turning. The problem is the engine oil pump lubricates the transmission as well as the engine. So turning off the engine cut the oil to the trams and it locked up.
Old August 5th, 2012, 08:36 AM   #14
Rudiger
Motorcycle(s): 2011 Ninja 250r(Sold) 2012 Ninja 1000 ABS
Is this true in gear clutch out, in gear with clutch in, neutral, or all the above?
So is coasting engine off something you should never do?
Rudiger is offline   Reply With Quote
Old August 5th, 2012, 08:49 AM   #15
Originally Posted by Rudiger View Post
..........is coasting engine off something you should never do?
Old August 5th, 2012, 09:41 AM   #16
Racer x
Racer x's Avatar
If you tow a bike like that you should remove the chain. The shaft that has the output sprocket is turning on a ball bearing. But inside the gears are turning on the shaft. When I turned off my engine the fifth sprocket welded itself to the output shaft.
I don't think drifting a short distance will hurt anything. On the dyno there is a 1000 lb drum . It nearly slows down. When you. Shut off your motor on the street . The bike drifts to a stop quickly.
Old August 5th, 2012, 10:25 AM   #17
lgk
Ninja.
been interested in these for a while.
i know there is less friction with these, but will they withstand more load than the standard bearing?
Old August 5th, 2012, 10:45 AM   #18
ryan.chin
Motorcycle(s): 2007 R6
Me too, man.
ryan.chin is offline   Reply With Quote
Old August 5th, 2012, 10:56 AM   #19
even if it wasn't firing wouldn't the rotating crank turn the oil pump and still pump oil? oh not if its in neutral.
Old August 5th, 2012, 10:59 AM   #20
**** now that i think about it, every day coming home from work i turn my engine off and coast in neutral about a quarter mile in my complex to my parking spot.................. i've been doing this for at least 2 years..................****.
Old August 5th, 2012, 01:03 PM   #21
n4mwd
n4mwd's Avatar
Alex, you and me seem to have a bad habit of buying stuff from ebay that turns out to be crap.
Coasting a quarter mile may not be that good for it, but I have a hard time believing that it would cause the kind of damage you have. The tranny uses ball and roller bearings. Even with the oil pump off, I believe that there is still plenty of oil on the balls to run without out damage for 30 seconds or so with no load.
In your case, I believe that its related to the constant pounding from the bad link and also possibly because the chain may have been too tight. This is exactly the kind of damage I would expect from an excessively tight chain.
Anyhow, good luck with it. I know it sucks for sure.
My Ninja Blog
Old August 5th, 2012, 02:18 PM   #22
Racer x
Racer x's Avatar
I agree. A bad link will pound a ball bearing to bits. I really don't think coasting for even a quarter mile will hurt anything. What I did on the dyno was a fluke.
I don't think ceramic would be better. Maybe worse. But you should not have a stuck link in the first place.
Old September 11th, 2012, 03:53 PM   #23
she lives.
not a single trip to the machine shop, either.
kinda funny. the engine right now is spotlessly clean while the rest of the bike is dirty dusty and covered in ****. thats kinda rare!
Old September 11th, 2012, 03:57 PM   #24
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Jesus ****! Finally!
AFM #676
Old September 11th, 2012, 04:02 PM   #25
oh i forgot the best part.
i couldn't get the old remains of the bearing off with all the pullers and clamp presses i could get my hands on. i had a dream about it and i implemented the solution the dream gave me.
the dremel cut the bearing race off in about 30 seconds. something i had tried to do "properly" the past month but failed.
lesson learned: if it doesnt come off and you dont need it anymore, cut the ****er off.
Old September 11th, 2012, 04:42 PM   #26
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
Alex's guide to owning a 250:
1. Blow transmission up
2. ?????
3. Profit!
Old September 11th, 2012, 04:43 PM   #27
Old Lemon
Lays er down
Old Lemon's Avatar
Motorcycle(s): 2008 Lime green Ninja 250R
is that the same bike you crashed in ur avatar?
Old Lemon is offline   Reply With Quote
Old September 11th, 2012, 04:46 PM   #28
yes. she has been crashed 3 times. hit by a car once.
Old September 11th, 2012, 04:51 PM   #29
Old Lemon
Lays er down
Old Lemon's Avatar
dam man. good job. wish i could do that stuff.
and very nice yoshi
Old September 11th, 2012, 05:01 PM   #30
thank you. its not hard, if i can do it, you can do it.
Old September 11th, 2012, 06:30 PM   #31
n4mwd
n4mwd's Avatar
@alex.s - Just don't be tempted to put cheap Chinese bearings in there. They are half the price of European bearings, but only last a few weeks.
Glad its back up and running.
My Ninja Blog
Old September 12th, 2012, 09:17 AM   #32
I used a used oem bearing but something tells me ill be replacing it again at some point
Old September 12th, 2012, 10:14 AM   #33
bdavison
Wartown, USA
bdavison's Avatar
Can you change out that bearing without splitting the cases and opening up the bottom end? Just curious, I looked at mine last time I had the sprocket off...looked like I would have to press it out from the inside. Assuming it was still intact.
Fortunately, mine is still good, but this would be good to know.
Old September 12th, 2012, 10:48 AM   #34
the bearing locks into the case, so the case has to be split. you cant get a good grip on the bearing without disassembling the outer transmission half on the output shaft, so that needs to be disassembled. and if the bearing itsself is shattered, you wont be able to grip the bearing to pull the pressed on sleave for the outer oil seal, so you will need to cut it off in order to remove the broken bearing race.
the easy solution is buy a new transmission output shaft with a new bearing. if you are cheap like me, the new bearing is only $15. instead of $100 for a used transmission
its worth noting though there was other damaged caused by the transmission shaft knocking around, most notably the oil vent crankcase breather thingymabob on the inside of the case got all jacked up and had to be replaced
Old September 12th, 2012, 11:42 AM   #35
n4mwd
n4mwd's Avatar
Does anyone know how the oil breather thing works? Seems like they could have just used a PCV valve which is simpler.
Posted via Mobile Device
Old September 12th, 2012, 11:51 AM   #36
umm, theres a metal box that gets bolted to the top of the case.... hes got something inside... and a tube that runs to the bottom of the case.... outside of that, err... well... i have one i can cut open
Old September 12th, 2012, 11:54 AM   #37
2. ?????
3. Profit!
correction:
1. Crash
2. Blow transmission up
3. Crash again
4. Blow transmission up again
5. ?????
6. Profit!
Old September 12th, 2012, 12:16 PM   #38
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
Wait...so does this mean you're in for September's round?
Old September 12th, 2012, 01:18 PM   #39
n4mwd
n4mwd's Avatar
I saw that thing in mine, but have no clue what it does to the oil or how it works. Seems like it siphons oil into that little tank somehow.
My Ninja Blog
Old September 12th, 2012, 02:08 PM   #40
i think its just to try to keep oil from going out the vent
Blown fuse. Then another. mrudich 1986 - 2007 Ninja 250R Tech Talk 34 July 30th, 2020 08:26 AM
Help! Blown motor! JpSavage96 1986 - 2007 Ninja 250R Tech Talk 3 February 10th, 2015 09:32 PM
Blown gasket? Christofini 2008 - 2012 Ninja 250R Tech Talk 6 November 8th, 2013 10:48 AM
blown transmission? alex.s 2008 - 2012 Ninja 250R Tech Talk 71 May 4th, 2012 03:33 PM
Being Blown Off Your Ninja Slono Riding Skills 33 March 7th, 2012 12:44 PM
