February 7th, 2015, 12:11 AM | #1 |
New gas = faster bike?
Hey, why is it that each time I pump new gas, my bike feels and sounds much more responsive? Now, I know you guys are going to think I'm crazy and that it's all in my head, but after a day, the bike returns back to it's "bogged" down state. With new gas, the RPMs climb effortlessly and feels way more responsive. My bike is around 17,000 miles or so. I only commute about 5 miles or less most days total, and most of the time, it's only in third or fourth gear because I'm in Vietnam, and most roads only allow for 20-30 miles an hour speeds.
Thank you |
February 7th, 2015, 02:22 AM | #3 |
Freedom for Germany
Lucas your feeling is right and totally normal, because since the gas is stored underground it's colder than the environment and cold gas gives higher energy or just say more power.
February 7th, 2015, 07:56 AM | #4 |
Poor gas vent?
February 7th, 2015, 08:19 AM | #5 |
modaholic junkie
Join Date: Sep 2012 Motorcycle(s): 2001 ZX-12R, 2009 ninja 345cc and plenty of others in the past... Posts: 438
when I want some "natural" extra performance I put a whole gas tank in the fridge for 4 hours at least and for the next 15' I get better throttle response and quicker revving without any gas boosters or any other tricks... when temps here get to 35deg C or more it makes a huge difference...that's why I have two gas tanks lol
I 've seen greek tuners on the dragstrips use dry ice around the plenum and gas tank of turbo busas and claim that this can make a winner... I think that gas also loses some of its octane grading with time so it is good to always have fresh gas in the tank... if it takes you 2 weeks to empty a tank it is impossible to have well burning gas during the second week...
If noone has tried it before, I will !!! |
February 8th, 2015, 05:21 PM | #6 | |
Join Date: Apr 2014 Motorcycle(s): '10 Kawasaki Ninja 250ARRRR (Sold), '13 Kawasaki Ninja 300 (Crashed), '07 Triumph Daytona 675 Posts: 45
Cold gas is denser gas. Denser gas has more energy per unit volume. Cooling off the gas before running it will create potential for more power.
OP you are probably feeling the effects of cool gas. You can always test this theory. Fill up a tank with fresh gas, let it sit in the sun and warm up and go for a ride. Drain the tank, hit up the gas station again and see how it runs with cooler gas. Quote:
I'm not sure about the gas in Greece, but here in the US we have 10% ethanol in the gas. Ethanol is hygroscopic and will absorb moisture from the air. Adding water to your fuel will not increase the energy density. If left to sit, ethanol will coat the fuel system with a nasty film and if left long enough solid clumps will form and plug the fuel system. This will definitely hinder the performance of your motorcycle. These are both good reasons to use a fuel stabilizer if your bike will be sitting or a great excuse to ride your bike more often. Last futzed with by Lemonfresh; February 9th, 2015 at 08:37 AM. |
February 9th, 2015, 02:57 AM | #7 |
Join Date: Jan 2012 Motorcycle(s): 2012 ninja 250r se Posts: 435
Does your fuel tank sound like a "cat meowing" when the bike has been ridden or in the shade??
If it does that's good, it means that the breather on the side of the tank is releasing the vacuum in the tank. If not the fuel lines to and from the carbs and the breather need changing, something is blocked. Cold fuel more power, only in a testing lab. Realalistically, no real change becasue the engine is hot, the small amount of fuel that is passed to the carbertuer will warm up by the heat of the engine, even when you have coolant lines running through the carbs at operating temps 80-90 deg Celsius. And that small amount will not increase power by a measurable amount. Hot fuel, cold air :-) |
February 9th, 2015, 01:47 PM | #8 | |
modaholic junkie
[faster and faster] - First official photograph of the 2015 Suzuki MotoGP bike reveal | Ninjette Newsbot | Motorcycling News | 0 | June 18th, 2013 01:50 AM |
ninja feels FASTER right after i put gas??? WTF | venmichaels | 2008 - 2012 Ninja 250R Tech Talk | 6 | July 21st, 2011 07:56 AM |
[faster and faster] - Jeremy Burgess: ‘Valentino develops the bike, the other guy jus | Ninjette Newsbot | Motorcycling News | 0 | October 9th, 2009 11:30 PM |
[faster and faster] - A3W Motiv: Julien Rondino’s three-wheeled concept bike | Ninjette Newsbot | Motorcycling News | 0 | March 21st, 2009 05:25 AM |
[faster and faster] - Ducati Streetfighter wins ‘most beautiful bike’ poll at the EIC | Ninjette Newsbot | Motorcycling News | 0 | November 10th, 2008 06:18 AM |
