Old May 20th, 2014, 09:48 PM   #1
dukeswift
dukeswift's Avatar
Motorcycle(s): 02 Aprilia RS70 97 Ninja 250
Fuel Evaporative System
This system, the faq doesn't say anything about servicing this.
1. Anything in particular I should look on it for problems?
2. Do any of the hoses coming off create a vacuum that could cause faulty starts?
3. Do I even need the damn thing?!
dukeswift is offline   Reply With Quote
Old May 20th, 2014, 09:50 PM   #2
dukeswift
dukeswift's Avatar
For reference...
Old May 21st, 2014, 02:53 PM   #3
Olie
New Old Guy
Olie's Avatar
Motorcycle(s): 2011 250R SE
That's the CA emissions stuff. I removed it along with the clean air system to clean up the engine bay. It's purpose is to reduce emissions given off by the motor by recirculating vapors and unburnt fuel back through the bike. The subject of it's removal is a heavily debated one, I chose to take it out.
Yes, it is part of the vacuum system and can cause problems if not capped off correctly.
The service manual does explain how to service the system. It's under the Fuel section labeled Evaporative Emissions Control System
Olie is offline   Reply With Quote
Old May 25th, 2014, 06:45 PM   #4
hobosmeller
Motorcycle(s): 1995 Kawasaki Ninja EX250 with 8500 miles!!
I removed mine even though I live in California because the hoses are almost 20 years old and I'm already fighting an idle problem. I just wanted to make sure this wasn't adding to the problem. there is an awesome write up on ninja250 about how to removed the emission stuff and take care of everything else so the bike still runs right
are you aware?
hobosmeller is offline   Reply With Quote
Fuel Tank & Vacuum System Questions RussInVegas 1986 - 2007 Ninja 250R Tech Talk 1 June 8th, 2013 08:17 AM
Fuel mileage with full system what to expect.. mkulchar 2008 - 2012 Ninja 250R Tech Talk 7 March 12th, 2012 07:31 PM
RedLine Fuel System Cleaner... cnichols79us 1986 - 2007 Ninja 250R Tech Talk 5 March 3rd, 2010 01:32 PM
[motorcycle.com] - Yoshimura introduces fuel management system Ninjette Newsbot Motorcycling News 0 October 15th, 2009 02:00 PM
