Old October 1st, 2013, 08:44 AM   #1
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Removing Rim Tape
My Ninjette is a special edition which came with rim tape on the wheels. Does anyone know how to cleanly remove it?
My plan is to heat one end of the tape with a hair dryer, pick it off the wheel and then slowly peel it back while applying more heat. I don't want to damage anything or leave horrible marks.
Thanks
Old October 1st, 2013, 08:50 AM   #2
That's a good start. Heat will usually loosen the glue so you can get the transfer off. Chances are there will be some glue left on the wheel after the tape is removed. Be careful what you use to remove it. Start with something gentle like WD-40. If that doesn't do it you can try a commercial Adhesive Remover or something like OOPS! or GOOF-OFF, but test it somewhere before wiping it all over the wheel.
Don't use anything like brake or carb cleaner on it.
Old October 1st, 2013, 09:10 AM   #3
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Thanks @jkv45. I've got surgical spirit handy too. Do you think that would be ok if the WD-40 doesn't get all the residue off?
Old October 1st, 2013, 10:09 AM   #4
Not sure exactly what that is, so I'm not sure.
Test it on an area that's not noticeable or important.
If it's cutting into the coating you will feel the rag start to drag and there will be color on it.
Typically Denatured Alcohol is good to use on cured coatings. Acetone is questionable and using MEK isn't a good idea.
EDIT: I personally wouldn't scrape the glue with anything. Another method of removing adhesive is using Duct Tape pushed down hard on the adhesive and pulled. Using a wiping or rolling motion with Duct Tape can also work.
Last futzed with by jkv45; October 1st, 2013 at 11:38 AM.
Old October 1st, 2013, 10:12 AM   #5
xSean13
xSean13's Avatar
Hair dryer + thin credit card or something to slide under it + alcohol
I used a dull razor blade to take mine off, only got a couple scratches but i don't really care.
Old October 1st, 2013, 11:27 AM   #6
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
I've heard plastic razor blades were helpful. Basically any sort of thin hard object that won't scratch the paint. I didn't feel like finding anything so I just picked at it for a long ass time. Peeling as slow as possible and as close the point where you're peeling is key. Basically just avoiding the length of tape from ripping.
Goo gone does wonders on the leftover adhesive though.
Old October 1st, 2013, 01:46 PM   #7
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
I'm guessing surgical spirits is the same as rubbing alcohol. That works great for getting adhesive off and since its on the rim it shouldn't wear off the color. Careful if you use that stuff on the paint or plastic though as it does fade those colors.
It's what i used when i pulled the duct tape off my rims before applying the paint.
<-- Linky
Old October 4th, 2013, 05:30 PM   #8
ChrisJuliano
Motorcycle(s): Ninja 250R
I just removed mine, if you have air tools they make these eraser discs that takes it off super quick if they dont peel easily.
ChrisJuliano is offline   Reply With Quote
Old April 17th, 2014, 03:59 PM   #9
FastrnU
Engine Room-> Dyno
Motorcycle(s): 08 YZFR6
starter fluid and a rag
FastrnU is offline   Reply With Quote
Pregen rim tape on silver rim? fr1dayn1ght 1986 - 2007 Ninja 250R Farkles 4 August 26th, 2013 04:45 PM
removing stock rim tape on special edition model LoneRonin General Motorcycling Discussion 8 August 27th, 2012 01:29 PM
"Rim wrap" + thin rim tape as an alternative to powder-coating? CZroe 2008 - 2012 Ninja 250R Tech Talk 6 July 21st, 2012 02:14 PM
Rim tape. blink General Motorcycling Discussion 14 March 31st, 2012 11:19 PM
Rim Tape??? tinng321 2008 - 2012 Ninja 250R Farkles 25 September 29th, 2009 01:31 PM
