Old May 7th, 2014, 06:39 AM   #1
Ninja Bob
Certified Slacker
Ninja Bob's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R SE
Cargo Cowl Bracket?
Is it possible to modify a cowl? Do they make brackets that mount where the cowl mounts? If so, how reliable would that be? It's only held on by that one pin. Finally, if it's not reliable, any recommendations on a frame mounted bracket?
Ninja Bob
Ninja Bob is offline   Reply With Quote
Old May 14th, 2014, 03:54 PM   #2
Technically, it mounts in two places: The locking pin and the plastic nipple in the rubber grommet. The grommet is almost always missing from the metal plate that goes across the underside of the passenger seat.
Mounting anything the way the seat cowl mounts is asking for trouble. The passenger seat itself mounts securely enough that I would just buy one of those and modify it for a securely mounted tail cargo box.
Last futzed with by CZroe; May 14th, 2014 at 07:42 PM.
Old May 14th, 2014, 04:32 PM   #3
Ninja Bob
Certified Slacker
Ninja Bob's Avatar
Mounting anything the way the seat cowl mounts is asking for trouble. The passenger set itself mounts securely enough that I would just buy one of those and modify it for a securely mounted tail cargo box.
Haha. Thanks for responding. I was thinking the same. I guess I thought the passenger seat was called a cowl.
Ninja Bob
Which cargo net should I get for the Pregen? agentbad 1986 - 2007 Ninja 250R Farkles 6 February 1st, 2015 07:00 PM
Is this real cargo space? salcuta88 Cargo Space 8 October 3rd, 2014 08:27 PM
Need help removing front cowl bracket kashun84 2008 - 2012 Ninja 250R Tech Talk 5 March 29th, 2011 12:20 PM
